SMSL SU-9 PRO DAC ES9039MPro XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
Updated version of the SU-9, the SMSL SU-9 Pro takes the technical base of its predecessor while proceeding to an improvement of the integrated components in order to increase the performances. Thus, this new version embeds a new DAC ESS ES9039MPro, offering a sound restitution of a great richness and precision and allowing the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512 as well as the decoding of MQA files.
By buying this product you get 54 loyalty points
Reference : 16946
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 20-05-2025.
SMSL SU-9 Pro
SMSL SU-9 Pro DAC 2x ES9039MPro XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
The whole audio circuit shows a particular care in the selection of the components. There are no less than 11 OPA1612A, a USB XMOS XU316 interface, a CK-03 clock circuit for a significant reduction of jitter and a shielded and regulated power supply stage capable of providing a clean and stable electrical signal.
Comparison between SU-9 Pro, SU-9N and SU-9
SU-9 Pro
SU-9N
SU-9
Year of release
2022
2021
2020
Audio architecture
SDAA
MQA Decoder
Via USB / Optical / Coaxial
Via USB only
MQA-CD Decoder
Support
DoP Display
Support
USB Interface
XMOS XU316
XMOS XU208
XMOS XU216
DAC Chip
ES9039MPro
ES9038Pro
ES9038Pro
OPA
11* OPA1612A
3* OPA1612A
3* OPA1612A
Jitter elimination technology
CK-03
CK-02
THD+N
-124dB (@4Vrms) / -125dB (@5Vrms)
-121dB (@4Vrms) / -123dB (@5Vrms)
UI
SDAA Interface
Previous interface version
SDAA Interface
Screen
Color IPS
Color IPS
Color IPS
MQA & MQA-CD
The SMSL SU-9 Pro decodes MQA (Master Quality Authenticated) files, offering a sound quality as close as possible to the studio recording. It also supports the MQA-CD format, allowing to read this format from a CD player.
High quality Bluetooth reception
The SU-9 Pro, like its big brother, has a Bluetooth 5.0 receiver chip, allowing you to easily stream your music wirelessly from a smartphone or tablet, for example. In addition, it supports the aptX, aptX HD and LDAC transmission codecs for high-quality wireless sound reproduction.
1IR Receiver
2Screen
3Multi-function button
4Bluetooth antenna
5Optical Toslink input
6Single-ended stereo RCA output
7Power connector
8USB-B Input
9Coaxial input
10Balanced stereo XLR output
Product typeDAC
InputsBluetooth 5.0
1x USB-B
1x Optical Toslink
1x Coaxial
1x Balanced stereo XLR
DAC ChipES9039MPro
USB InterfaceXMOS XU316
OPA11* OPA1612A
Line out amplitudeXLR : 5.2Vrms
RCA : 2.5Vrms
THD+N0.00005% (-125dB)(Unweighted)
Dynamic rangeXLR : 134dB : RCA 128dB
SNRXLR : 134dB : RCA 128dB
USB transmission modeAsynchronous
USB compatibilitéWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 ou ultérieure
Linux
MQA DecoderUSB
Optical
Coaxial
MQA-CD DecoderOptical
Coaxial
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512
DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
LDAC
Supply voltage100-240VAC
Consumption< 10W
Standby consumption< 0.5W
Dimensions187.5*154*40mm
Weight790g
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
3 reviews
Excellent DAC
Acheté il y a 6 mois pour monter en gamme à partir d'un excellent smsl d300, il faut dire que le saut en qualité sonore se fait sentir dès les premières minutes. Tous les registres sont présentés d'une façon aérée, précise et dynamique.
Avec un ampli casque topping L30 neutre et un casque Sennheiser HD660S, je retrouve réellement un plaisir d'écoute que j'ai perdu et recherché depuis quelques temps.
L'interface est très fournie et fluide; Bonne télécommande.
je ne regrette pas mon achat.
This review has been posted for SMSL SU-9 PRO DAC ES9039MPro XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD
Surpris par son son.
Ce fut une expérience agréable d'acheter sur audiophonics.fr pour la première fois. Mon avis dessus SMSL SU-9PRO Mon avis c'est un bon rapport qualité prix je l'ai connecté au Reavon UBR-X200 qu'il contient avec un DAC très musical comme le Burr-Brown PCM1690 de Texas Instruments,j'ai un autre DAC le Cambridge Audio DacMagic 200M connecté à d'autres lecteurs et aussi au Reavon,après presque trois semaines d'écoute branché avec de bons câbles d'alimentation, le SMSL SU-9 PRO ne colore pas le son, ayant une excellent dynamique, n'étant pas un DAC symétrique ou haut de gamme, il répond bien à toutes les fréquences, je vous conseille de l'acheter.
achat conseillé
avis très positif après 3 semaines d'utilisation (écoute sur casque et ampli STAX): je ne vois pas de défaut, c'est dynamique, fluide, bien timbré et la scène sonore est très bien construite dans toutes ses dimensions.
J'ai comparé à plusieurs reprises à un autre DAC quatre fois plus cher acheté il y a quatre ans. Résultat : le nouveau venu est meilleur.
C'est dire les progrès enregistrés par les DACs (ou au moins certains DACs) en quelques années.
A signaler aussi que le produit me semble bien fini.
Updated version of the SU-9, the SMSL SU-9 Pro takes the technical base of its predecessor while proceeding to an improvement of the integrated...
