Un mot !
FANTASTIQUE.
DAC AK4499 I2S XMOS Bluetooth aptX-HD LDAC UAT Balanced 32bit 768kHz DSD512 MQA
The SMSL VMV D2 is a high-end DAC, embedding high-end components within a neat architecture, for exceptional performances. At the heart of the DAC, the digital to analog conversion stage is based on a AKM AK4499 chip. Furthermore, the D2 is also very versatile, with a full range of connectors and practical functions.
The SMSL VMV D2 embeds an AKM AK4499EQ conversion chip to provide excellent performance and a precise, lively and rich sound reproduction. The Velvet Sound architecture of these DACs allows to reach a very low distortion level and a THD+N measured at -123ddB.
The chip is produced using Premium Audio LSI and non-magnetic encapsulation technology. These improve the performance in terms of noise, especially in the low frequencies.
The D2 benefits from a total support of MQA (Master Quality Authenticated), allowing the device to decode these files in order to reach a sound quality as close as possible to the original recordings. Moreover, the digital output (Optical or Coaxial) of a CD player can be transmitted to the SMSL VMV D2 MQA decoder. The latter will be able to restore the original high resolution signal and confirm it using the MQA signature authentication system.
Integrating a Bluetooth 5.0 Qualcomm CSR8675 receiver, the D2 allows you to broadcast your music wirelessly, directly from a connected smartphone. With the support of the codecs of transmission Bluetooth aptX, aptX-HD, LDAC and UAT, it is moreover possible to benefit from a quality of restitution equal or superior to that of the CD.
The USB-B input of the SMSL VMV D2 is associated to a second generation 16 cores XMOS interface: the XU216. This one ensures the reception and the decoding of audio streams via USB while supporting high resolution files up to PCM 32bit 768kHz and DSD512.
All the circuits of the SMSL VMV D2 benefit from a careful and optimized design, using only high quality components dedicated to audio. In addition to the AK4499EQ DAC or the XMOS XU216 USB interface, the DAC is equipped with two Accusilicon ultra-low phase noise clocks or an ultra-low noise power supply stage with an output noise floor of only 1.8µVrms embedding two Noratel toroidal transformers, to independently power the digital and analog circuits.
A rare but very useful feature, the SMSL VMV D2 allows you to invert the phase of the balanced XLR output. Thus, the pinout of this output adapts to your system for an optimal compatibility.
| 1 | Screen |
| 2 | IR Receiver |
| 3 | Input selector |
| 4 | FN Button |
| 5 | LED Indicator |
| 6 | Multifunction knob |
| 7 | RCA Output |
| 8 | Optical input |
| 9 | Bluetooth antenna |
| 10 | Balanced XLR output |
| 11 | AES/EBU input |
| 12 | Coaxial input |
| 13 | I2S input |
| 14 | USB input |
| 15 | External clock input |
| 16 | Power connector (100-240VAC) |
| Specifications | ||
| Product type | DAC | |
| DAC Chip | AKM AK4499 | |
| USB Interface | XMOS XU216 | |
| Bluetooth receiver | Qualcomm CSR8675 | |
| Inputs | 1x AES/EBU 1x SPDIF Coaxial 1x I2S via HDMI 1x Optical Toslink 1x USB-B Bluetooth 5.0 1x BNC input for external clock (50Ω) | |
| Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR | |
| Supported sampling rates | USB, I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA Coaxial, Optical, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA CD Bluetooth : PCM up to 24bit 192kHz (UAT) / 24bit 96kHz (LDAC) / 24bit 48kHz (aptX HD), MQA | |
| Clock frequency | 10MHz / 11.2896MHz / 12.288MHz / 16.9344MHz 25MHz / 27MHz / 33.8688MHz | |
| THD+N | 0.000068% (-123dB) 0.000058% (-124dB, A-Weighting) | |
| Dynamic range | XLR : 131dB RCA : 125dB | |
| SNR | 131dB | |
| USB Transmission | Asynchronous | |
| USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX Linux | |
| Supported Bluetooth codecs | AAC, SBC, aptX, aptX-HD, LDAC, UAT | |
| General | |
| Supply voltage | 1002-240VAC (power cable included) |
| Consumption | < 10W Standby : < 0.5W |
| Dimensions | 280 x 240 x 39mmmm |
| Weight | 3kg |
| Housing material | Aluminum |
| Color | Black |
| Package | 1x SMSL VMV D2 1x Power cable 1x Bluetooth antenna 1x Remote control 1x USB Cable Spikes |
| Input | Optical |
| Input | I2S via HDMI |
| Input | AES/EBU |
| Input | SPDIF |
| Input | Bluetooth |
| Input | BNC |
| Input | USB |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | AK4499 |
| Max sampling rate | MQA |
| Color | Black |
| Networking | No |
| Remote Control | Yes |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pierre F.
Luc V.
Mathieu W.
