TOPPING D90 III SABRE Balanced DAC Silver
Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced performance and a better user experience. This D90 III DAC incorporates an ESS ES9039SPRO DAC chip per channel, a USB XMOS interface upgraded to an XU-316 and a new Qualcomm QCC5125 Bluetooth 5.1 receiver chip.
By buying this product you get 89 loyalty points
Reference : 18582
899,00 €tax incl.
749,17 € tax excl.
Last items in stock !
Shipping date: 07-04-2026.
TOPPING D90 III SABREBalanced DAC 2x ES9039SPro Bluetooth 5.1 32bit 768kHz DSD512 MQA Silver
DAC TOPPING D90 III SABRE picture
Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced performance and a better user experience. This D90 III DAC incorporates an ESS ES9039SPRO DAC chip per channel, a USB XMOS interface upgraded to an XU-316, a new Qualcomm QCC5125 Bluetooth 5.1 receiver chip and a 12V trigger input and output on the rear panel. The high-end components present on the previous version, such as the Altera Max CPLD, are also present. The evolutions made to the D90 III enable it to achieve better SNR, better dynamic range and an even lower level of distortion. The extensive connectivity of this balanced DAC makes it a versatile device with high-end audiophile features.
TOPPING D90 III SABRE DAC highlights
Topping D90 III: two ESS ES9039SPRO DAC chips
Topping's balanced DAC is equipped with one ESS ES9039PRO DAC chip per channel for independent signal processing. These DAC chips enable it to support high-resolution PCM 32Bit 768kHz and native DSD streams up to DSD512, while maintaining excellent performance. This is also reflected in the D90 III's THD+N of less than 0.00006% (RCA) and 0.000045% (XLR), and SNR of 129dB (RCA) and 135dB (XLR).
Photo of ESS ES9039SPRO DAC chip
MQA Logo
Topping D90 III: support for high-resolution MQA streams
The D90 III is equipped with an MQA decoder that performs the entire MQA decoding process in-house, so you can enjoy audio files as close as possible to the original studio recordings, on a multitude of its inputs: USB, coaxial, optical and AES/EBU.
Topping D90 III: XU316 XMOS USB interface
The D90 III DAC is equipped with a third-generation XU-316 USB XMOS interface, the performance of which has already been proven. This ensures excellent processing of digital signals passing through the device's USB port. It also offers a high level of Plug and Play compatibility (Win10, Win11, MAC, Linux, IOS, Android) and excellent stability thanks to a Thesycon driver.
A driver and settings are still required for ASIO on Windows.
Computer interface photo
Bluetooth 5.1 connectivity
Topping D90 III: Bluetooth 5.1
Topping has chosen to replace its Bluetooth chip with Qualcomm's flagship Bluetooth 5.1 QCC5125 receiver chip, enabling the D90 III to support high-resolution codecs: SBC, ACC, aptX, aptX HD, aptX Adaptive and LDAC. So you can enjoy a wireless connection supporting streams up to PCM 24bit 96kHz, a higher resolution than the CD quality standard.
Topping D90 III: Altera MAX II CPLD
The D90's Altera MAX II CPLD is used to process the clock signal and optimize the quality of the digital sound signal, considerably reducing jitter.
Photo of CPLD Altera MAX II
Topping D90 III: Selectable output
The D90 III features a selectable output system. Audio can be routed to the XLR output, to the RCA output, or to both. In addition, an output level can be selected. For example, the XLR output can operate at 4V or 5V, and the RCA output at 2V or 2.5V.
Topping D90 III: Preamplifier function
In addition to the DAC mode with fixed output level, the D90 III offers a DAC + preamplifier mode. In this mode, you can control the volume level. In this way, the D90 III can be directly combined with a power amplifier or active loudspeakers.
Topping D90 III: Custom filters
The D90 III lets you switch from one mode to another with ease. So you can quickly switch from default mode to valve mode or transistor mode, and enjoy a different listening experience.
Topping D90 III DAC filters
Photo of the 12V trigger on the rear panel of the DAC D90 III
Topping D90 III: 12V trigger for an enhanced user experience
This function enables the D90 III to be controlled, or to control other devices so that they can be switched on and off simultaneously.
DAC D90 III connectivity overview
DAC Topping D90 III connectivity diagram
1XLR balanced stereo output
2RCA single-ended stereo output
3I2S input via HDMI
4Toslink optical input
5SPDIF coaxial input
6USB-B input
7Bluetooth antenna connector
8AES EBU input
9Trigger in/out 12V
10Power connector and power switch
Topping D90 III: High I2S compatibility
The Topping D90 III SABRE supports various I2S transmission protocols: I2S PHASE STD, I2S PHASE REV, I2S DSDR DATA, I2S DSDR LRCLK, DSD FLAG 14 and DSD FLAG 15. It is therefore compatible with most digital interfaces on the market.
I2S compatibility diagram
Product typeBalanced DAC
DAC chip2x ES9039SPRO
USB interfaceXMOS XU-316
Inputs1x USB-B
1x AES/EBU
1x SPDIF Coaxial
1x Optical Toslink
1x I2S via HDMI
Bluetooth 5.1
Outputs1x RCA stereo
1x XLR stereo
Supported sample ratesPCM 32bit 768kHz
DSD512
MQA
Supported Bluetooth codecsSBC, ACC, aptX, aptX HD, aptx Adaptative, LDAC
Trigger
DAC + preamplifier function
RCA LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.00006% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0003% @20Hz-20kHz
SNR @ A-Weighted129dB @ 1kHz
Dynamic range @ A-Weighted129dB @ 1kHz
Frequency response20Hz - 20kHz (+/- 0.1dB)
20Hz - 40kHz (+/- 0.3dB)
Output level2.1Vrms @0dBFS (mode 4V)
2.6Vrms @0dBFS (mode 5V)
Noise @ A-Weighted< 1.1uVrms
Channel crosstalk-133dB @ 1kHz
Channel balance0.3dB
Output impedance50 Ohm
XLR LINE OUTPUT MEASUREMENTS (USB IN @96KHZ)
THD+N @ A-Weighted< 0.000045% @ 1kHz
THD @ No-Weighted, 90kBw< 0.0001% @20Hz-20kHz
SNR @ A-Weighted135dB @ 1kHz
Dynamic range @ A-Weighted135dB @ 1kHz
Output level4.2Vrms @0dBFS (mode 4V)
5.2Vrms @0dBFS (mode 5V)
Channnel separation-149dB @ 1kHz
Output impedance100 Ohm
Dimensions222 x 160 x 45mm
ColorSilver
Package1x Topping D90 III Sabre Silver
1x Bluetooth remote control
1x USB cable
1x Bluetooth antenna
1x Power cable
Measurements of the Topping D90 III SABRE DAC
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ColorSilver
ClassN/A
Remote ControlYes
2 reviews
Un DAC au top pouvant servir de préampli
Le son produit par ce DAC est au top (cf. la review sur ASR). Difficile d'affirmer que la qualité audio produite est meilleure que mon ancien DAC Gustard X16. Subjectivement, je dirais que le son est encore un peu plus détaillé, clair et transparent.
J'ai acquis ce modèle surtout pour ses fonctions afin de m'en servir comme préampli :
_ 2 mémos volume+entrée+sortie(s) accessibles directement via la télécommande
_ mise en veille
_ trigger
_ écran lisible de loin
Les seuls points négatifs :
_ il manque un "safe volume"
_ le manque de réactivité de la télécommande en mode bluetooth
Mon utilisation :
_ Streamer sur entrée USB
_ PC sur entrée I2S via interface PO100pro
_ Caisson actif sur sortie RCA
_ Ampli de puissance sur sorties XLR et trigger
_ enceintes Kef LS 50 meta
This review has been posted for TOPPING D90 III SABRE Balanced DAC 2x ES9039SPro Bluetooth 5.1 32bit 768kHz DSD512 MQA Silver
New DAC
This DAC is as good as all the reviews say. Incredible open throughout the frequency range, without any listenig fatique. But prefers good source material . Very much recommended for quality systems ( class A amps + electrostatic speakers)
Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and...
