TOPPING E30 USB DAC AK4493 32bit/768kHz DSD512 XMOS Silver
The E30 from Topping is a DAC with very advantageous compact dimensions and surprising performance given its small size.
4.9 / 5
Reference : 14492
149,00 €tax incl.
124,17 € tax excl.
Topping E30
USB DAC 32bit-768kHz / DSD512 XMOS
Topping's E30 is a USB DAC with very compact dimensions and surprising performances for its size. It uses a AK4493 DAC chip which is among the most famous compopents in High Fidelity Audio for this purpose. It also uses a Xmos interface providing a clear and transparent connection to any digital sources with a USB output.
This DAC has a volume control function which can be bypassed to use it either with a preamplifier or directly with active speakers or a power amplifier.
Topping has not forgotten to work on the product looks, since the E30 has an elegant and readable display accompanied by a beautiful touch control button.
Review by Audio Science Review
Distortion levels are incredibly low at -120 dB and lower. The addition of noise takes SINAD down to 112 dB which is most competent for a small little DAC like this:
 test by the measurement forum Audio Science Review
AK4493 DAC & XMOS USB
Digital to Analog audio conversion uses a AK4493EQ 32-bit Dac chip.  This modernized version of the famous AK4490EQ benefits from better distortion and signal-noise ration than its parent while keeping all the technologies that made it popular. It includes the famous Velvet Sound technology with increasingly accurate digital filters.
The USB input is controlled by a XMOS interface that enables to properly support very high sampling frequencies (up to 768kHz 16 and 32bit). This component also provides native DSD  compatibility up to DSD512 in addition to the DOP256 support.
These components are rigorously integrated and allow the E30 to achieve a clear signal with an extremely low distortion rate of 0.0003%, less than -130dB crosstalk, 121dB signal noise ratio and 119dB measured dynamic range. This kind of performance is usually found in more expensive and bulky equipment.
Impressive connectivity for its size
Unlike the majority of compact DACs that use a micro USB port, Topping gave its E30 an USB-B port. Thus giving it is a great advantage in terms of robustness and lifespan over its competitors.
The eneregy requirements are low enough to allow direct power supply through the USB port. There is also a DC jack which is ideal for connecting the E30 to any Hi-Fi grade power-supply (LPSU) without using any adapter.
A Coaxial SPDIF and an Optical SPDIF input enable the DAC E30 to work with external digital sources. Multiple devices (CD player, TV, media platform or game console) can be connected and enjoy its excellent audio decoding capability.
Its SPDIF interface use a CS8416 low-jitter chip, which supports digital audio streams up to 24-bit / 192kHz.
The touch button on the front panel can be used to change the active source. The source selection can also be done using the included infra-red remote control.
The output is a simple RCA stereo connector with variable volume.
Dimensions
Infrared remote control
The E30 comes with an sober infra-red remote to control all its functions remotely. This is a very rare feature in this price range.
TypeDAC
DAC chipAK4493
Sample rate (USB)PCM: 44.1-768kHz 16-32bit
DSD: DSD64-512 (native)
Sample rate (Optical & Coax)PCM: 44.1-192kHz
DOP: DOP64-256
THD + N0.0003%
CrosstalkLess than -130dB
Ratio signal / noise121dB
Dynamic119dB
Dimensions3.2 x 10 x 12.5cm
Package content
DAC E30x1
Male USB-A to Male Jack DC cable 5.5/2.1mmx1
Male USB to Male USB-A cablex1
Remotex1
Manual (EN)x1
Warranty Cardx1
DAC / ADC ChipAK4493EQ
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
11 reviews
Bon produit
Petit dac performant et pas cher. Attention tout de même si comme moi vous voulez transformer votre platine en drive. Ma platine de 1998 n'avait pas un flux assez régulier et cela engendrer des micros coupures. Pas de souci en usb ou avec des appareils récents.
This review has been posted for TOPPING E30 USB DAC AK4493 32bit/768kHz DSD512 XMOS Silver
Ravi de mon achat!
Merci à Audiophonics pour le sérieux!
Ce petit DAC correspond tout à fait à mes attentes, compact, beau son, look bien sympa, facile à installer!
En ce qui me concerne et à ce tarif rien à redire!
Un super DAC
Après avoir lu divers articles et commentaires sur ce topping, ainsi que basé sur mon expérience du D10, j’ai franchi le pas.
Je ne suis vraiment pas déçu de ce petit E30 dont la musicalité est un cran au-dessus du D10. Un prix imbattable pour une qualité pareil, et un super look discret pour l’insérer dans un système même HDG!
Topping reste pour moi une valeur sûre dans le domaine Hifi.
Produit excellent
J'ai lu des avis sur ce site et c'est ce qui m'a amené à acheter ce produit.
Produit excellent, Topping est une marque à prendre au sérieux.
Easy to use, quality DAC
I'm using the E30 in a stack with the L30 HP Amp and both convinced me that probably I won't need to upgrade anytime soon. Both with a Hifiman Sundara and an AKG 240 I get nothing but transparent AS-IS quality.
It sure reveals huge differences in how each music is recorded/mixed/mastered but this is not a problem at all! It just shows how many different approaches find ways to appeal to the listener. Don't waste your money if you are only looking for a more transparent sounding DAC. Only spend more if you are after more features and a better design.
