AUDIOPHONICS DAC MS8413 SPDIF Coaxial Optical 24bit 192kHz
This small, affordable DAC is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24-bit 192kHz.
Reference : 21432
9,90 €tax incl.
8,25 € tax excl.
Audiophonics DAC MS8413 SPDIF Coaxial Optical 24bit 192kHz
Photo du DAC MS8413 Audiophonics
This small, affordable DAC is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz. The module has a coaxial input and a Toslink optical port. The output can be either RCA or 3.5mm jack. The device is powered by 5V DC via a USB-C port.
Overview of the Audiophonics DAC MS8413
1USB-C power port
2Coaxial input
3Toslink optical input
43.5mm stereo jack output
5Stereo RCA output
Product typeDAC
DAC chipMS8413
Inputs1x Coaxial
1x Toslink optical
Outputs1x Jack 3.5mm stéréo
1x RCA stéréo
Supported sample ratesPCM up to 24bit 192kHz
Distorsion0.001%
Power supply5VDC via USB-C (power supply not included)
Dimensions68 x 63mm
Weight50g
ColorSilver
Package1x Audiophonics DAC MS8413
1x Stereo interconnect cable 3.5mm jack to RCA (1.5m)
OutputJack 3.5mm
DAC / ADC ChipMS8413
Max sampling rate192kHz
ColorSilver
