DENAFRIPS VENUS 15TH Balanced R2R DAC Silver
Denafrips returns with the 15th version of its Venus symmetrical R2R DAC, capable of converting signals up to PCM 24bit 1536kHz and DSD1024. This new version not only retains the excellent base of its predecessor, but also incorporates an AT-cut OCXO internal clock, an improved power supply stage and a new circuit architecture, all housed in a new chassis featuring two new IS2 RJ45 inputs. These new additions enhance the sound reproduction to offer an even more musical and richer rendering, devoid of any imperfections or distortion.
By buying this product you get 455 loyalty points
Reference : 20368
4 550,00 €tax incl.
3 791,67 € tax excl.
Denafrips Venus 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Silver
Denafrips Venus 15th : Front view
Denafrips
Denafrips Venus 15th: R2R DAC and FPGA
Each channel of the Venus 15th is equipped with an independent high-speed FPGA to facilitate decoding of the digital signal using 4 sets of R-2R networks with a tolerance of just 0.005%. The choice of such a design results in very low linearity error, high decoding speed and low digital noise, not only to ensure that the audio signal has extremely low distortion, but also to ensure very low background noise for the most accurate and transparent reproduction possible.
Denafrips Venus 15th : Resistance network
Denafrips Venus 15th : OCXO clock
Denafrips Venus 15th: FIFO buffer and OCXO clock
All Venus 15th digital inputs pass through a FIFO buffer and are reclocked by an OCXO AT-cut clock. The exceptional stability offered by the AT-cut crystal is reinforced by the OCXO architecture's temperature control, resulting in a signal with unrivalled stability, very low jitter and enhanced resolution.
Denafrips Venus 15th: O-core transformers
The Venus 15th's linear power supply stage uses two copper-silver-gold alloy O-core transformers coupled with filter capacitors to supply the digital and analog sections independently, ensuring a clean, stable power supply while avoiding interference.
Denafrips Venus 15th: Transformers
Denafrips Venus 15th: Pinout I2S
Denafrips Venus 15th Pinout I2S
Test of Denafrips Venus 15Tth by SoundNews
"The improvement in resolution is substantial, as are its dynamics and transient response. This is no longer the mellow, shy, overly smooth Denafrips sound I once knew; this version is much more polished, mature, and infinitely more fun to listen to."
badge soundnews
Product typeBalanced R2R DAC
Inputs1x Coaxial
1x Optical Toslink
2x XLR AES
1x HDMI I2S
2x RJ45 I2S
1x USB-B
Output1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesPCM up to 24bit 1536kHz
DSD up to DSD1024
Operating modesNon-oversampling (NOS)
Oversampling (OS)
Frequency response20Hz - 40KHz (-0.2dB)
Total harmonic distortion more noise (THD+N)0.001%
Signal-to-noise ratio (SNR)127dB
Dynamic range> 132dB
Crosstalk-110dB
Supply voltage100-240VAC, 50/60Hz
Consumption≤ 20W
Dimensions430 x 380 x 125mm
Weight19kg
ColorSilver
Package1x Denafrips Venus 15th
InputI2S via HDMI
InputAES/EBU
InputI2S via RJ45
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
ColorSilver
DENAFRIPS VENUS 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Silver
Denafrips returns with the 15th version of its Venus symmetrical R2R DAC, capable of converting signals up to PCM 24bit 1536kHz and DSD1024. This...
