HOLO AUDIO MAY LEVEL 2 Balanced R2R DAC and Independent Power Supply 32bit 1536kHz DSD1024
After 3 years of research and development to achieve a whole new level of performance and sound quality, HoloAudio introduces the MAY Level 2 discrete balanced R2R DAC! Flagship of the brand, it offers a simply exceptional and uncompromising design, with the aim of providing the most faithful, musical and accurate sound reproduction possible. It is composed of two distinct blocks, the first corresponding only to the digital / analog conversion system and the second to its dedicated power supply.
By buying this product you get 526 loyalty points
Reference : 15777
5 269,00 €tax incl.
4 390,83 € tax excl.
Garantie 3 mois
HoloAudio May Level 2
HoloAudio May Level 2 DAC R2R Symétrique et Alimentation Indépendante 32bit 1536kHz DSD1024
The May is a dual mono DAC and therefore has a dedicated DAC module for each channel. Moreover, these are individually powered by flatwire type-O transformers, a model that surpasses all other types of transformers tested: almost zero leakage current, improved dynamics and spectacular overall performance, these are moreover handmade especially for this DAC.
Key features and technologies
HoloAudio May's next-generation linear compensation technology resolves accuracy errors caused by resistor tolerance after compensation, achieving a 0.05% variance in tolerance accuracy. The integrated proprietary anti-jitter system drastically reduces the level of jitter without increasing the background noise or negatively impacting the sound reproduction.
Based on this innovative design, the May is capable of delivering a SINAD of over 115dB and a dynamic range of over 130dB, corresponding to the highest performance that an R2R DAC can achieve today.
The May also takes advantage of the exceptional performance of PLL+FIFO technology for an ever lower jitter level. It uses a high-performance femtosecond VCXO as the PLL clock source.
On the power supply side, the two mono channels of the DAC are independently powered by their own dedicated transformer. An optimized construction allowing a better separation of the channels while limiting the interferences, in order to reveal a wide sound scene.
An architecture that also allows HoloAudio's DAC to natively support, via its USB and I2S inputs, high resolution streams up to PCM 32bit 1536kHz and DSD1024. The two XMOS XU208 USB interfaces use proprietary firmware developed to ensure very low latency and reliable data transmission. The May also features two independent I2S inputs over HDMI, each with an independent 4-channel circuit, making the clock signals less susceptible to interference and jitter than in a conventional LVDS system. Each I2S input can be configured with a different pinout for maximum compatibility.
NOS & OS Modes
The HoloAudio May offers several convenient configuration options. For example, a NOS mode can be activated to cancel any oversampling, with the original data going directly to the converter. This mode may allow for some distortion problems.
On the other hand, the OS mode allows oversampling of the PCM and DSD streams to reach higher frequencies, before digital/analog conversion. The OS PCM mode takes a PCM or DSD stream as input and oversamples it to PCM. The OS DSD mode will take a PCM or DSD stream and oversample it to DSD.
Custom PLL circuit
The May DAC features femtosecond clocks and ultra-high performance discrete voltage regulators. It features an advanced custom PLL (Phase Lock Loop) circuit designed for extremely efficient jitter cancellation. Even the highest jitter levels are almost completely suppressed. The Crystek CVHD-957 VCXO clocks in the device are responsible for recovering the digital signal and reclocking it. However, this function can be deactivated, allowing the performance of this system to be observed. A FIFO buffer allows the clock signals to be stored temporarily, making it possible to avoid using ASRC technology, which would have the effect of altering the audio data.
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typeDAC R2R
Inputs1x USB-B
2x I2S via HDMI
1x Optical Toslink
1x AES/EBU
1x Coaxial (RCA)
1x Coaxial (BNC)
1x Balanced stereo XLR
Supported sampling ratesUSB : PCM up to 32bit 1536kHz, Native DSD up to DSD1024, DSD DoP up to DSD512
I2S : PCM up to 32bit 1536kHz, Native DSD up to DSD1024
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.00017% @ PCM 48K NOS, 1K (-115dB)
0.00025% @ DSD128X, 1K (-112dB)
Dynamic range130dB @ PCM 48K NOS
115dB @ DSD128X
Output voltageRCA : 2.9Vrms @ PCM 48K NOS, 1.45Vrms @ DSD128X
XLR : 5.8Vrms @ PCM 48K NOS, 2.9Vrms @ DSD128X
ImpedanceRCA : 27Ω
XLR : 54Ω
Supply voltage220-230V 50/60Hz, fuse type 2A SB 5x20mm
110-115V 50/60Hz, fuse type 4A SB 5x20mm
(power cable not supplied)
Consumption60W
Housing materialAluminum
DimensionsDAC : 430 x 300 x 55mm
Power supply : 430 x 300 x 55mm
Total weight18kg
Remote controlIncluded
InputI2S via HDMI
InputAES/EBU
InputBNC
DAC / ADC ChipR2R LADDER DAC
Max sampling rate1536kHz
Max sampling rateDSD1024
ColorCopper
Remote ControlYes
2 reviews
Holo Audio May 2
Je rajoutera la comparaison suivante qui me semble assez judicieuse, le Holo Audio May 2 correspond très bien au jeu du violoncelliste Pierre Fournier jouant sur des cordes en boyaux argent. Un jeu d'une élégance extrême, raffiné, aristocratique, mais un poil moins spontané que celui de Daniil Chafran ou de Jacqueline Du Près. Mais surtout ne pas penser que c'est un DAC HiFI, les émotions sont bien là, simplement elles ne sont pas jetées à la face de l'auditeur. Pour une personne à la recherche d'un DAC dont la signature sonore se rapproche des grands interprètes ( violon, violoncelle, piano, ... ) des années 1950, ce convertisseur est exceptionnel, même en comparaison à des DAC comme MSB, Esoteric et C°.
This review has been posted for HOLO AUDIO MAY LEVEL 2 Balanced R2R DAC and Independent Power Supply 32bit 1536kHz DSD1024
Holo Audio May 2
Excellent appareil, extrêmement musical, très détaillé mais sans excès, l'intégration des différentes voies ( médium aigu ) est remarquable, aucune mise en avant particulier ! Certains peuvent trouver que le grave est très légèrement en retrait. Très très sensibles aux différents câbles ! Un mauvais choix peut amener à un léger manque d'entrain. Sur mon système entièrement à pavillon quatre voies ( SANS filtre ) utilisant uniquement des amplis single ended pure classe A à tube 20A, je suis terriblement satisfait. Mon DAC précédent était un DDDAC de Douede Douma recommandé par J.Hiraga. Très musicale mais moins que le Holo Audio May 2 ! Très hautement recommandé pour de la musique acoustique ( ! ), mais a essayer avant pour de la musique électronique.
Bonne écoute !
After 3 years of research and development to achieve a whole new level of performance and sound quality, HoloAudio introduces the MAY Level 2...
