MUSICIAN PEGASUS Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Black
10%
The Musician Pegasus presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies, the device benefits from a low-noise power supply, a FIFO buffer, signal processing by FPGA and a FIR filter. It is thus capable of decoding very high sample rates, up to 32bit PCM 1536kHz and DSD1024 via its USB and I2S inputs.
Reduced price!
Reference : 15072
Limited special offer
1 349,00 €tax incl.
-10%
1 214,10 €tax incl.
1 011,75 € tax excl.
This product has been replaced by the Musician Pegasus II.
Musician Pegasus
Musician Pegasus DAC R2R Discret Symétrique 32bit 1536kHz DSD1024 Noir
The Musician Pegasus presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies, the device benefits from a low-noise power supply, a FIFO buffer, signal processing by FPGA and a FIR filter. It is thus capable of decoding very high sample rates, up to 32bit PCM 1536kHz and DSD1024 via its USB and I2S inputs. The USB interface is managed by a STM32F446 MCU with Thesycon driver. The whole unit is integrated in a massive Aluminium case.
A more than complete connection system
The Musician Pegasus provides you with most of the connections common to today's HiFi devices. We thus find at the input of USB-B, I2S via HDMI LVDS, AES/EBU, Toslink Optics and Coaxial. On the output side, the device offers unbalanced RCA and balanced XLR, the latter output being obviously recommended to take advantage of the full potential of the device.
It is not recommended to use the XLR and RCA outputs simultaneously, as these are shared.
1Input selector
2Power button
3NOS button
4RCA right channel output
5XLR right channel output
6XLR left channel output
7RCA left channel output
8I2S input via HDMI
9Coaxial input
10Optical Toslink input
11AES input
12USB-B input
13Power supply input
I2S pinout configuration
To make it compatible with most devices, the Musician Pegasus offers several configurations of its I2S pinout. To modify this setting, follow the steps below:
  1. Select the I2S input.
  2. Press and hold the NOS button for 3 seconds until the I2S indicator light flashes.
  3. Press the NOS button again to change to I2S mode.
  4. Once the correct mode has been selected, the device confirms the setting and automatically exits the parameterization mode.
If the setting does not produce satisfactory sound (e.g. a hissing noise), this cannot be considered a device malfunction, but simply an incompatibility. The recommended solution is to use a customized HDMI cable, adapted to the pinout of your device and the Pegasus.
Test of Musician Pegasus by Audio Science Review
Test du Musician Pegasus par Audio Science Review
Technical specifications
Product typeDAC R2R
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
1x AES/EBU
1x I2S via HDMI LVDS
Outputs1x Single-ended RCA
1x Balanced XLR
Supported sampling ratesI2S / USB : PCM up to 32bit 1536kHz, DSD up to DSD1024
Others inputs : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Frequency response10Hz - 60kHz
THD+N0.002%
SNR123dB (A-Weighted)
Dynamic range> 120dB
Output levelRCA : 2.2Vrms
XLR : 3.55Vrms
Supply voltage110-240VAC, 50/60Hz
Consumption≤ 20W
Dimensions280 x 250 x 50mm
Weight3.9kg
Package1x Musician Pegasus
1x Power cable
I2S Pinout
PINMode 1Mode 2Mode 3Mode 4Mode 5Mode 6Mode 7Mode 8
1DATA-DATA-DATA+DATA+DATA-DATA-DATA+DATA+
3DATA+DATA+DATA-DATA-DATA+DATA+DATA-DATA-
4BCK-BCK-BCK-BCK-BCK+BCK+BCK+BCK+
6BCK+BCK+BCK+BCK+BCK-BCK-BCK-BCK-
7LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+
9LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-LRCK+LRCK-
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipNC
Max sampling rate1536kHz
Max sampling rateDSD1024
4 reviews
Très bon dac
Une très bonne surprise, derrière un lecteur cd/sacs/dvd Cambridge avec volume numérique et devant un Audio research D70, c’est somptueux. C’est fluide, c’est timbré et pas du tout fatiguant sur des écoutes longues. Bref, ce dac me rempli de joie depuis son acquisition.
This review has been posted for MUSICIAN PEGASUS Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Black
Un très très bon DAC
Voici maintenant 13 jours que le Pegasus s’est installé chez moi. Il totalise donc environ 300H de fonctionnement car je l’ai laissé allumé en permanence depuis son achat. Le moment est donc venu de faire le point sur son apport dans mon système (Atoll IN300, KEF LS50 + caisson REL T5i, switch ETheregen, streamer Emerson digital + important travail sur l'élimination des vibrations et sur le câblage). Pendant cette période, mes nombreuses écoutes m’ont confirmé (s’il en était besoin car j’en était déjà convaincu) que la restitution évolue considérablement entre la sortie du carton et le cap des 300H ….en bien, bien entendu !
Par rapport au DAC AK4490 de l’Atoll, le Musician se démarque tout d’abord sur la profondeur, la hauteur et la précision de la scène sonore. Par exemple, l’environnement qui entoure la voix d’Anna Reid de London Grammar sur le titre « If you wait » est bien plus vaste qu’avec l’Atoll. Dans le même sens, les effets 3D sont nettement plus marqués (les enceintes disparaissent vraiment cette fois-ci) et positionner les musiciens sur l’enregistrement d’un concert est un jeu d’enfant. La taille des instruments (notamment le piano) paraît bien plus réaliste. Toutes ces qualités supérieures font que la musique est beaucoup plus impliquante. A de nombreuses reprises, mes poils se sont dressés à l’écoute des titres de ma playlist de test que je connais pourtant par coeur.
Ensuite, il prend nettement le dessus sur les instruments à cordes, le piano et les percussions type cymbales... leur grain est palpable et très réaliste. D’une manière générale, les harmoniques sont bien plus riches avec le Pegasus et il vous permet véritablement d’accéder à l’oeuvre de l’artiste, c’est à dire qu’il la restitue avec toutes ses nuances, ses variations, ses arrières plans... Il ne favorise aucun registre. Ainsi, les medium ne sont pas particulièrement mis en avant mais les voix sont bcp plus présentes et agréables puisque mieux détourées et elles possèdent désormais un grain que le dac de l’Atoll est incapable de restituer. Les graves profitent également de toutes ces améliorations.
Par ailleurs, je ne perçois aucune mollesse de sa part, défaut souvent attribué aux dac R2R. Sur le titre « the coil train » d’Hughes Masekela, les envolées de ce dernier sont retranscrites avec le même degré d’énergie que le dac de l’Atoll. Par contre, je ne le ressens pas exactement à l’identique. En effet, le Pegasus paraît plus à l’aise dans ce domaine, moins « rentre dedans » pour caricaturer, dans le sens où il ne donne jamais l’impression de « forcer » par rapport à l’Atoll : Cela paraît plus naturel, plus décontracté, plus fluide en somme.
Enfin, la synergie de toutes ces qualités conduit tout naturellement à un écart important en terme de musicalité entre les deux appareil...vous arriverez sûrement au même constat que le mien si vous partez d'un DAC "honorable" comme celui de l'Atoll et à la condition que votre système soit suffisamment abouti (vibrations parasites maitrisées, câblerie et électroniques/enceintes au même niveau cad aucune ne devant faire "bouchon").
E.
Ce DAC est remarquable.
Le fabricant préconise un rodage de 300 heures pour ce produit. Et je confirme que cela est nécessaire. Je l'ai laissé en marche pendant deux semaines, mais Pegasus s'est révélé déjà au bout de 2-3 jours. Ensuite il n'a fait que se bonifier.
La scène sonore est large. La précision de la restitution sonore est excellente tout en étant musicale. Ayant toujours utilisé des DACs Delta-Sigma, c'était un bonheur de découvrir les avantages d'un bon DAC R-2R.
Je remercie M. David Aubert pour la pertinence de ses conseils son professionnalisme.
Satisfait
Voilà une semaine que je l ecoute via qobuz usbridge ampli atoll enceintes jmr.
Par rapport à mon ancien dac ds ess9018
Soundstage plus grand plus profond sans nul doute.
Timbres plus réaliste
Timing plus précis.
Je ne trouve pas que cela dégage une chaleur dans le son trop prononcé et il n est pas mou du genoux.
En résumé
Soundstage très bon ecoute plus live plus enveloppant
Timbre excellent instruments cuivre,cordes parfait.
Voix j aurais aimé plus de corps de grain encore.
tous les styles de musique passe je suis très ecliptique
Bref je suis refait .
Un belle achat
The Musician Pegasus presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the...
