XDUOO MU-604 Balanced DAC 2x ES9018K2M 32bit / 384kHz DSD256
The xDuoo MU-604 is a compact and very powerful symmetrical DAC. Thanks to its XMOS USB receiver and its ES918K2M dual DAC, this DAC will allow you to read audio files up to 32bit / 384kHz, as well as native files up to DSD256.
Reference : 16740
169,00 €tax incl.
140,83 € tax excl.
xDuoo MU-604
xDuoo MU-604 DAC symétrique
As for input connections, this device offers 4 different ones: SPDIF Coaxial, SPDIF Optical, USB 1.0 on the front (no driver required), USB 2.0 on the back (XMOS driver required).
On the output side you can choose between stereo RCA connectors, or balanced 3-pin XLR connectors.
On the front panel you will find a nice OLED display, showing you the input used, and the sample rate read.
xDuoo MU-604
Double DAC ES9018K2M
The digital/analogue conversion stage of the xDuoo MU-602 uses two ES9018K2M DAC chips. Used in many HiFi devices, these 32Bit chips allow the playback of Hi-Res audio files.
XMOS XU208
The USB XMOS interface operates in asynchronous transmission mode, and supports WASAPI, ASIO, KS Core modes, which greatly reduces the jitter of the device. This chip is located on the USB 2.0 input at the back of the product, and requires a driver to run under Windows (Attached download file).
xduoo MU-604 XMOS USB
Technical
Type of productDAC
Inputs1x Optical Toslink
1x Coaxial
1x USB-B
1x USB-C
Ouputs1x Stereo RCA
1x Balanced XLR
DAC chip2x ES9018K2M
USB chipXMOS XU208
Supported sampling ratesPCM up to 32bit / 384kHz & DSD256 (Via USB 2.0)
PCM up to 24bit / 192kHz (Via Coaxial / Optical)
Output levelRCA : 2V
XLR : 4V
SNRRCA : 120dB
XLR : 24dB
THD+NRCA : 0.0007% (@ 1kHz)
XLR : 0.0005% (@ 1kHz)
Crosstalk109dB
general
Power supply12VDC 2A via Jack DC
Chassis materialAluminium
Dimensions127x84x40mm
Net weight350g
ColorGrey
Package1x xDuoo MU-602
1x 12V DC power supply
1x USB-C to USB-C cable
DAC / ADC ChipES9018K2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorGray
2 reviews
perfect DAC for my ends
Got XDUOO MU-604 Balanced DAC in two days!
It is just what I expected it to be. It is connected to tube amp x7, I love the sound it gives (lossless files) - slightly different but as clear and clean as from turntable or CD player+ Vitalizer mk2T. Plus I can tailor the sound to my liking. I love it! Highly recomended!
This review has been posted for XDUOO MU-604 Balanced DAC 2x ES9018K2M 32bit / 384kHz DSD256
Significant upgrade from my older USB DAC
Initial impression is great clarity and very even tonality. This has excellent performance at a very good price. I am very satisfied. I can't compare with more expensive models as I don't have one to compare with, but this a very significant upgrade from a similarly priced DAC of a few years ago.
The xDuoo MU-604 is a compact and very powerful symmetrical DAC. Thanks to its XMOS USB receiver and its ES918K2M dual DAC, this DAC will allow you...
