Excellent appareil, belle écoute avec casque Focal Clear MG en cours de rodage, peut être par la suite acquisition d'un câble symétrique suite à vos conseils, mais déjà très satisfait.
Prix attractif et livraison rapide
By buying this product you get 149 loyalty points
Digital Audio Player DAP HiFi 4x ES9038Q2M Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Gray
The KANN series is a line of portable digital music players, particularly popular with audiophiles for their performance focused on high output and clear sound. The KANN MAX, the fourth product in the KANN series, builds on the advantages of the other models, with higher output levels and greater portability. It offers four gain levels and an output of up to 15Vrms, allowing it to accompany the vast majority of headphones in an optimal way, while maintaining a very low noise level. The KANN MAX is also equipped with four ESS ES9038Q2M digital-to-analog conversion chips and the unique Astell&Kern architecture, ensuring an exceptional level of performance.
The KANN MAX takes the identity of the range to a new level to offer a perfect audio experience, with high power and clear sound. It provides four gain levels to reach an output of 15Vrms, power normally reserved for sedentary headphone amplifiers. Thus, the KANN MAX has no difficulty in accompanying even the most demanding high-impedance headphones.
It is also more compact and lighter, ensuring better portability, without altering performance. Thus, all the components related to the power supply have been studied and the circuit redesigned to achieve a 13h autonomy in reading.
KANN MAX
KANN ALPHA
Output level (Super)
Single-ended : 8 Vrms / Balanced : 15Vrms
Output level (High)
Single-ended : 6Vrms / Balanced : 12Vrms
Output level (Mid)
Single-ended : 4Vrms / Balanced : 8Vrms
Output level (Low)
Single-ended : 2Vrms / Balanced : 4Vrms
Dimensions (LxHxP)
68.3 x 117 x 23.6mm
68.3 x 117 x 25mm
Weight
Approx. 305g
Approx. 316g
Playback time
13h
14.5h
The KANN MAX is equipped with a high level output capable of maintaining a very low noise level, reflecting Astell&Kern's philosophy of offering very high sound fidelity. To achieve this, the player uses an analog volume controller to provide a rich, lossless dynamic range. By configuring the power supply for each audio block separately, the KANN MAX is able to stably provide the required power for each audio circuit. With this design, parasitic ripple noise from the DC-DC power supply is eliminated.
The ultra-high efficiency and low noise levels of the KANN MAX were achieved through a different circuit design, including creating and dividing the PCB into 12 layers and repurposing the amplifier circuit.
The KANN MAX is the first player in the KANN range to be equipped with four ES9038Q2M DACs. Thanks to this design, one DAC can be allocated entirely to each channel, allowing the depth and realism of the sound source to be fully expressed. Combined with Astell-Kern's amplifier circuitry technology, which naturally and gently expands the DAC's capabilities to provide a clear and rich sound, the KANN MAX maintains a very low level of distortion.
The KANN MAX allows bit-perfect playback up to PCM 32bit 768kHz and DSD512, ensuring incredible sound quality, as close as possible to the original recordings.
TERATON ALPHA is Astell&Kern's sonic solution to provide playback as close to the original signal as possible through the use of effective background noise suppression as well as perfect power management and amplification with extremely low distortion.
The Bluetooth 5.0 standard offers a faster transmission speed and greater range than the 4.2 standard, providing a more stable wireless connection. The KANN MAX also supports the high-definition transmission codecs aptX HD and LDAC to provide audiophiles with high-quality wireless audio.
The BT Sink function allows the KANN MAX to be connected to an external device via Bluetooth, so that it can function as a source or receiver.
The KANN MAX's ReplayGain feature allows you to adjust sound sources of different levels to the same level. This allows you to enjoy your music seamlessly, without having to adjust the volume for each track.
The ReplayGain function supports sources up to PCM 24bit 192kHz.
The new AK File Drop function of KANN MAX makes file transfer easier and more convenient. With it, you can freely transfer your files wirelessly from a computer, smartphone or FTP software connected to the same network.
The volume knob of the KANN MAX incorporates an LED indicator to quickly and easily identify the bit-rate of the file being played.
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download. The KANN MAX has a built-in MQA decoder to play back these files to provide the best possible audio quality.
Product type | Digital audio player (DAP) |
Touchscreen | 720*1280px 4.1" |
Supported audio formats | WAV, FLAC, WMA, MP3, OGG, APE, AAC, ALAC, AIFF, DFF, DSF, MQA |
Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 |
Output level | Low : Single-ended = 2Vrms / Balanced : 4Vrms Medium : Single-ended = 4Vrms / Balanced = 8Vrms Élevé : Single-ended = 6Vrms / Balanced = 12Vrms Super : Single-ended = 8Vrms / Balanced = 15Vrms |
CPU | Quad Core |
DAC | 4x ESS ES9038Q2M |
Input | USB-C |
Outputs | 1x Single-ended Jack 3.5mm 1x Optical Jack 3.5mm 1x Balanced Jack 2.5mm (4 poles) 1x Balanced Jack 4.4mm (5 poles) |
WiFi | 802.11 b/g/n 2.4GHz |
Bluetooth | 5.0 |
Supported Bluetooth codecs | A2DP, AVRCP aptX HD, LDAC |
Frequency response | ±0.023dB @ 20Hz~20kHz, single-ended ±0.026dB @ 20Hz~20kHz, balanced ±0.035dB @ 20Hz~70kHz, single-ended ±0.072dB @ 20Hz~70kHz, balanced |
SNR | Single-ended : 114dB @ 1kHz Balanced : 115dB @ 1kHz |
Crosstalk | Single-ended : -124dB @ 1kHz Balanced : -135dB @ 1kHz |
THD+N | Single-ended : 0.0003% @ 1kHz Balanced : 0.0004% @ 1kHz |
IMD SMPTE | Single-ended : 0.0007% 800Hz 10kHz (4:1) Balanced : 0.0007% 800Hz 10kHz (4:1) |
Output impedance | Single-ended Jack 3.5mm : 1Ω Balanced : 1.6Ω |
Clock jitter | 25ps |
Reference clock jitter | 70ps |
Battery | Li-Polymer 5600mAh 3.6V |
Charging time | About 3.5h (9V 1.67A Quick charge) 5.5h (5V 2A Standard charge) |
Playback time | Approx. 13h (FLAC, 16bit 44.1kHz, single-ended, volume 40, LCD Off, LED On, low gain) |
Internal storage | 64GB NAND |
External storage | 1x Micro SD slot (Max 1TB, not included) |
OS Compatibility | Windows 7, 8, 10 Mac OS X 10.7 |
Body material | Aluminum |
Color | Anthracite grey |
Total dimensions | Ø21 x 54mm |
Input | USB |
Input | Micro SD |
Input | Bluetooth |
Input | WiFi |
Output | Bluetooth |
Output | WiFi |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Output | Optical Mini-Toslink |
Output | Jack 2.5mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Gray |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe K.
