FIIO M15S Digital Audio Player DAP ES9038Pro Snapdragon 660 Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA
With the M15S, FiiO unveils a top-of-the-range audiophile digital music player. An improvement on the M15, it features a new Qualcomm Snapdragon 660 processor, more powerful amplification and an ES9038Pro 8-channel DAC. Versatile, it can play files on micro SD, on a local network or online via music streaming services such as Spotify, Amazon music, Deezer, Apple music, Qobuz or Tidal, for example. It can decode up to PCM 32bit 768kHz, DSD512 and MQA.
By buying this product you get 99 loyalty points
Reference : 17965
990,00 €tax incl.
825,00 € tax excl.
FIIO M15S
Digital Audio Player DAP ES9038Pro Snapdragon 660 Bluetooth 5.0 32bit 768kHz DSD512 MQA
FIIO M15S Baladeur Numérique HiFi DAP ES9038PRO Snapdragon 660 Bluetooth 5.0 32bits 768kHz DSD512 MQA
With the M15S, FiiO unveils a top-of-the-range audiophile digital music player. An improvement on the M15, it features a new Qualcomm Snapdragon 660 processor, more powerful amplification and an ES9038Pro 8-channel DAC. Versatile, it can play files on micro SD, on a local network or online via music streaming services such as Spotify, Amazon music, Deezer, Apple music, Qobuz or Tidal, for example. It can decode up to PCM 32bit 768kHz, DSD512 and MQA. Its Bluetooth 5.0 QCC5124 chip also enables it to transmit and receive SBC, AAC, aptX, aptX HD, aptX Adaptive and LDAC formats. With its capabilities, 10.5 hours of battery life and 3 outputs (balanced and single-ended), the FiiO M15S is an extremely versatile, high-performance DAP.
ES9038Pro DAC chip
An excellent digital/analogue conversion chip, the ESS ES9038Pro DAC on board this M15S benefits from proprietary Hyperstream II technology. As well as delivering highly accurate sound reproduction, this technology supports high-resolution streams up to PCM 32bit 768kHz and DSD256. The M15S also incorporates an MQA decoder, so you can enjoy this high-quality audio format.
M15S architecture: a clean clock signal
The M15S incorporates a PLL (phase-locked loop) FGPA operating with NDK Japanese femtosecond crystal oscillators, enabling it to transmit a highly accurate, low-jitter clock signal to all its components.
The use of an 8-core Qualcomm Snapdragon 660 processor coupled with Android 10 will give you access to third-party applications so you can enjoy the best music streaming services thanks to the Google Playstore, all accessible via a 5.5" HD 720P touchscreen.
The best in wireless transmission
The FiiO M15S benefits from AirPlay and DLNA network transmission protocols. It is also equipped with a Bluetooth 5.0 QCC5124 chip for wireless reception and transmission from and to a smartphone or tablet. The following Bluetooth codecs are supported:
  • Bluetooth 5.0 reception formats: SBC, AAC, aptX, aptX HD, LDAC et LHDC.
  • Bluetooth 5.0 transmission formats: SBC, AAC, aptX, aptX HD, aptX LL, LDAC et aptX Adaptive.
M15S: effective connectivity
The FiiO DAP M15S has 2 balanced headphone outputs, one in Jack 2.5mm and the other in Jack 4.4mm, plus a single-ended output in Jack 3.5mm. With 1200mW of power and 5 available gain levels (Low/Medium/High + Over-ear: Super High/Ultra High), it is compatible with the majority of audiophile headphones and earphones on the market.
A high-performance battery
FiiO has incorporated a 6200mAh battery into its M15S, enabling you to enjoy a listening experience lasting up to 10.5 hours. The battery can be fully recharged in around 3.5 hours using the QC3.0+PD fast charging protocols. Moreover, the M15S power supply circuit is designed to reduce crosstalk and interference and feed the amplifier stage cleanly using low-noise LDO regulators. Another advantage is that it can be used in 'desktop' mode, meaning that instead of recharging the battery, the current will directly supply the M15S, thus preserving battery life.
Product typeDigital Audio Player (DAP)
Dac chipES9038Pro
SoCQualcomm Snapdragon 660 + Android 10
RAM4GB
Storage64GB
OPAOPA926
Inputs1* USB-C 3.0 (Charge + OTG, USB DAC, USB Audio)
1* Micro SD slot
Bluetooth 5.0
WiFi (DLNA, AirPlay)
Outputs1* Single-ended Jack 3.5mm
1* Balanced Jack 2.5mm
1* Balanced Jack 4.4mm
1* Coaxial (shared with Jack 3.5mm headphone output)
Touchscreen5.5" HD 1440*720px
Volume control
Gain settingsLow / Medium / High
Over-ear: Super High / Ultra High
Equalizer (EQ)Adjustable 10-band dynamic equalizer (±12dB)
8 built-in preset equalizers
Custom EQ support
Recommended headphone impedance8-150Ω (single-ended output)
8-350Ω (balanced outputs)
Supported sample ratesNative: PCM up to 32bit 384kHz, DSD up to DSD256
USB DAC: PCM up to 32bit 384kHz, DSD up to DSD256
USB Audio: PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial: PCM up to 32bit 384kHz, DSD up to DSD128 (DoP)
Supported audio formats
MP3, OGG, WMA, AAC, DSD, DXD, APE Fast/High/Normal, APE Extra High, APE Insane, Apple Lossless, AIFF, FLAC, WAV, WMA Lossless, DTS, MQA
WiFiWiFi 2.4GHz/5GHz
DLNA
AirPlay
Roon Ready
Supported Bluetooth codecsReception: SBC, AAC, aptX, aptX HD, aptX LL, LDAC and aptX Adaptive
Transmission: SBC, AAC, aptX, aptX HD, LDAC and LHDC
Single-ended Jack 3.5MM OUTPUT measurements
Output power2* 535mW (16Ω / THD+N<1% / Ultra high gain)
2* 580mW (32Ω / THD+N<1% / Ultra high gain)
2* 93mW (300Ω / THD+N<1% / Ultra high gain)
2* 475mW (16Ω / THD+N<1% / Super high gain)
2* 395mW (16Ω / THD+N<1% / Super high gain)
2* 57mW (16Ω / THD+N<1% / Super high gain)
Crosstalk≥ 80dB (1kHz/32Ω)
Frequency response20Hz-20kHz (-0.15dB)
20Hz-50kHz (-1.0dB)
Output impedance≤ 1.4Ω (32Ω)
THD+N≤ 0.0005% (1kHz/32Ω)
SNR≥ 122.5dB (A-weighted)
Noise≤ 3.2μV (A-weighted)
Balanced Jack 2.5mm / 4.4mm outputs measurements
Ouput power2* 531mW (16Ω / THD+N<1% / Ultra high gain)
2* 1200mW (32Ω / THD+N<1% / Ultra high gain)
2* 368mW (300Ω / THD+N<1% / Ultra high gain)
2* 531mW (16Ω / THD+N<1% / Super high gain)
2* 990mW (16Ω / THD+N<1% / Super high gain)
2* 226mW (16Ω / THD+N<1% / Super high gain)
Channel separation≥ 105dB (1kHz/32Ω / Ultra high gain)
≥ 105.6dB (1kHz/32Ω / Super high gain)
20Hz-50kHz (-1.0dB)
Output impedance≤ 2.3Ω (32Ω)
THD+N≤ 0.00075% (1kHz/32Ω)
SNR≥ 121.5dB (A-weighted / Ultra high gain)
≥ 120.5dB (A-weighted / Super high gain)
Noise≤ 5.2μV (A-weighted)
Battery
Power supplyVia USB-C (QC3.0, QC4.0 / PD2.0, PD3.0 quick charge support)
Battery capacity6200mAh
Charging time3.5h
Battery life9h-10h30
Dimensions140*80*18.9mm
Weight345g
ColorNoir
Package1* FiiO M15S
1* Leather protective cover
1* Stand with heat dissipation system
1* USB 3.0 OTG power cable
1* Power cable for stand
1* USB adapter
Courbe de réponse en fréquence 1
Conditions de test : signal sinusoïdal -5dB, 20Hz-20kHz, sortie casque asymétrique (charge 32 Ohm)
FiiO M15S Baladeur Numérique HiFi DAP ES9038Pro Snapdragon 660 Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA
Courbe de réponse en fréquence 2
Conditions de test : signal sinusoïdal -5dB, 20Hz-20kHz, sortie casque symétrique (charge 32 Ohm)
Courbe de réponse en fréquence 3
Conditions de test : signal sinusoïdal -5dB, 20Hz-20kHz, sortie ligne (charge 10 kOhm)
Courbe de réponse en fréquence 4
Conditions de test : signal sinusoïdal -5dB, 20Hz-20kHz, sortie ligne symétrique (charge 10 kOhm)
Courbe de réponse en fréquence 5
Conditions de test : signal sinusoïdal -5dB, 20Hz-50kHz, sortie casque (charge 32 Ohm)
Courbe de réponse en fréquence 6
Conditions de test : signal sinusoïdal -5dB, 20Hz-50kHz, sortie casque symétrique (charge 32 Ohm)
Courbe de réponse en fréquence 7
Conditions de test : signal sinusoïdal -5dB, 20Hz-50kHz, sortie ligne (charge 10 kOhm)
Courbe de réponse en fréquence 8
Conditions de test : signal sinusoïdal -5dB, 20Hz-50kHz, sortie ligne symétrique (charge 10 kOhm)
Courbe de distorsion 1
Conditions de test : signal sinusoïdal -6dB, 20Hz-20kHz, sortie casque (charge 32 Ohm)
Courbe de distorsion 2
Conditions de test : signal sinusoïdal 0dB, 20Hz-20kHz, sortie ligne asymétrique (charge 10 kOhm)
Courbe de distorsion 3
Conditions de test : signal sinusoïdal -8dB, 20Hz-20kHz, sortie symétrique (charge 32 Ohm)
Courbe de distorsion 4
Conditions de test : signal sinusoïdal -4dB, 20Hz-20kHz, sortie ligne symétrique (charge 10 kOhm)
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 2.5mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
With the M15S, FiiO unveils a top-of-the-range audiophile digital music player. An improvement on the M15, it features a new Qualcomm Snapdragon...
