The FiiO Snowsky Echo Mini is a digital audio player (DAP) that combines a retro design inspired by 1980s cassette players with modern audio technology. Ultra-compact and lightweight, it fits easily into a pocket and features a 1.99-inch IPS screen that is bright enough for outdoor use. This model is positioned as an affordable solution for high-fidelity audio enthusiasts, offering excellent value for money.
The Snowsky Echo Mini is equipped with two Cirrus Logic CS43131 DAC chips. This allows it to support audio formats up to 24-bit 192kHz and DSD256, ensuring accurate and detailed sound reproduction. With a signal-to-noise ratio of 131dB and low output impedance (32 ohms), it provides precise control of transducers, even with demanding headphones or earphones. The player can deliver up to 100mW on its 3.5mm jack output and 250mW on its balanced 4.4mm jack output, providing sufficient power for many headphones and in-ear headphones.
The Snowsky Echo Mini features Bluetooth 5.3 with SBC codec, allowing wireless connection to Bluetooth headphones or speakers for portable listening. It also has 8GB of internal memory, expandable via microSD card up to 256GB (not included), and offers approximately 15 hours of continuous playback thanks to its 1100mAh battery. Its interface, inspired by cassette players, and retro buttons add a touch of nostalgia, while remaining functional and intuitive.
The Echo Mini's vintage design makes it as attractive as it is effective. The Snowsky Echo Mini can play audio files (DSD, WAV, FLAC, APE, MP3, M4A, OGG) from a microSD card or USB (DAC mode), and stream to Bluetooth headphones or earphones, making it a versatile companion for music lovers on the go. Despite its small size, it sacrifices neither audio quality nor robustness. What's more, its beautiful IPS screen allows you to enjoy various dynamic displays and even show album covers or song lyrics. The Echo Mini also provides access to features such as gain adjustment, a configurable equalizer, and 120-step volume control.
The Bluetooth AAC (Apple) codec is not supported.
| Specifications | |
| Product type | DAP |
| Inputs | Bluetooth 1x Micro SD slot (up to 256Go) 1x USB-C |
| Outputs | Bluetooth 1x Single-ended Jack 3.5mm headphone output 1x Balanced Jack 4.4mm headphone output |
| DAC chips | 2x CS43131 |
| Internal storage | 8GB |
| Screen | IPS 1.99" 170 x 320px |
| Battery capacity | 1100mAh |
| Battery lifetime | 15h |
| Supported Bluetooth codec | SBC |
| Supported file formats | DSD, WAV, FLAC, APE, MP3, WMA, M4A, OGG |
| Supported sampling rates | DSD jusqu'au DSD256 WAV, FLAC, APE jusqu'à 24bit 192kHz |
| Supported sampling rates in USB DAC mode | PCM jusqu'à 24bit 48kHz |
| Output powere | Single-ended: 2x 100mW @ 32Ω, THD+N < 1% Balanced: 2x 250mW @ 32Ω, THD+N < 1% |
| SNR | ≥ 131dB (32Ω, A-wt) |
| THD+N | 0.0004% |
| Noise floor | 0.8µV |
| Output impedance | < 0.4Ω |
| General | |
| Dimensions | 80 x 54.5 x 14.5mm |
| Weight | 55g |
| Color | Black |
| Package | 1x FiiO Snowsky Echo Mini 1x USB cable |
Frequency response curve
Test conditions: local playback, -5dB, sinusoidal signal -5dB, 20Hz-20kHz, PO (32Ω)
Blue: left channel / Red: right channel
THD+N curve
THD+N curve
Test conditions: local playback, -5dB, sinusoidal signal -5dB, 20Hz-20kHz, balanced output (32Ω)
Distortion amplitude
Test conditions: local playback, 0dB sine wave signal, PO (600Ω)
Test conditions: local playback, 0dB sine wave signal, balanced output (600Ω)
| Input | USB |
| Input | Micro SD |
| Input | Bluetooth |
| Output | Jack 3.5mm |
| Output | Bluetooth |
| Output | Jack 4.4mm |
| DAC / ADC Chip | CS43131 |
| Max sampling rate | DSD256 |
| Max sampling rate | 192kHz |
| Color | Black |
