SHANLING ONIX TOCATA XM2 Digital Audio Player DAP
The Shanling Onix Tocata XM2 is a compact digital audio player designed to deliver high-resolution playback and amplification suitable for demanding portable headphones. It is based on an advanced conversion architecture built around a Cirrus Logic CS4308P chip, compatible with 32bit 768kHz PCM and DSD512, to ensure extensive support for current formats while maintaining stable and accurate playback.
By buying this product you get 43 loyalty points
Reference : 21560
439,00 €tax incl.
365,83 € tax excl.
Shipping date: 19-11-2026.
Shanling Onix Tocata XM2 Digital Audio Player DAP CS4308P 32bit 768kHz DSD512
Shanling Onix Tocata XM2 : Front view
Designed for mobile use or as a complement to a stationary system, it combines controlled digital conversion, amplification capable of delivering 800mW at 32Ω, and comprehensive wired and wireless connectivity. This approach allows it to serve as a central portable source, while maintaining sufficient battery life for extended sessions thanks to its 3000mAh battery.
Shanling Onix Tocata XM2 : Product summary
Shanling Onix Tocata XM2: CS4308P DAC
The Shanling Onix Tocata XM2 is based on an 8-channel Cirrus Logic CS4308P chip, designed to ensure high-precision digital-to-analogue conversion. Compatible with 32bit 768kHz PCM and DSD512, it guarantees extensive support for high-resolution streams, allowing you to enjoy even the most demanding libraries without intermediate conversion.
Shanling also incorporates a proprietary Brighton I/V conversion architecture, developed around two OPA1612s, to ensure linear and stable current-to-voltage conversion. Upstream, an FPGA combined with a dedicated dual crystal oscillator stabilises the digital clock and reduces jitter, thereby preserving temporal accuracy and transient clarity.
Shanling Onix Tocata XM2 : DAC CS4308P
Shanling Onix Tocata XM2 : SGM8262 Amplifier
Shanling Onix Tocata XM2: SGM8262 amplifier chips
The output stage is based on a dual SGM8262 chip configured in parallel architecture. This configuration allows the Onix Tocata XM2 to deliver up to 800mW into 32Ω, providing ample power headroom for low-impedance headphones as well as more demanding models.
Shanling Onix Tocata XM2: 3000mAh battery
The Onix Tocata XM2 incorporates a 3000mAh battery, sized to support the entire digital and analogue architecture without power fluctuations. This capacity allows for up to 8.5 hours of continuous use, enabling extended mobile use.
Shanling Onix Tocata XM2 : 3000mAh
Shanling Onix Tocata XM2 : Bluetooth 5.2
Shanling Onix Tocata XM2: Connectivity
Designed for versatile use, the Onix Tocata XM2 combines two-way Bluetooth 5.2 connectivity, allowing both wireless reception and transmission, with single-ended 3.5mm and balanced 4.4mm headphone outputs, allowing the device to be adapted to different headphones and earphones.
This approach is extended by the presence of WiFi for access to services and the local network, while the bidirectional USB‑C port allows use as a USB DAC, digital transport or external audio device.
Shanling Onix Tocata XM2: Manufacturing quality
The Shanling Onix Tocata XM2 is characterised by its solid, high-end build quality. The player features a CNC-machined aluminium alloy chassis, four physical media control buttons, a gold-plated volume knob and a 3-inch OLED touchscreen.
Shanling Onix Tocata XM2 : Physical button
Product typeDigital Audio Player (DAP)
DAC ChipCirrus Logic CS4308P
Amplification chips2x SGM8262
Outputs1x Jack 3.5mm single-ended
1x Jack 4.4mm balanced
1x USB-C
ConnectivityWiFi
Bluetooth 5.2
Supported Bluetooth codecsLDAC, aptX HD, aptX, SBC, AAC
WiFi protocols supportedDLNA, Airplay, Online Tidal Streaming
Touch screenOLED 3" 720p
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Compatible file formatsDSD (iso, dsf, dff, DST not supported), ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DST, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS
Single-ended output powerLow gain: 51mW @ 32Ω
High gain: 204mW @ 32Ω
Balanced output powerLow gain: 200mW @ 32Ω
High gain: 800mW @ 32Ω
Signal-to-noise ratio (SNR)Single-ended output: 121dB
Balanced output: 124dB
Total harmonic distortion more noise (THD+N)0.0005% @ 32Ω
Output impedanceSingle-ended output: 0.4Ω
Balanced output: 0.7Ω
Channel separationSingle-ended output: 73dB
Balanced output: 112dB
Frequency response20Hz-40kHz (-0.5dB)
StorageSlot Micro SD (up to 2TB, not included)
Battery3000mAh
Autonomy8.5h
Dimensions82 x 65 x 18mm
Weight140g
Chassis materialAluminum
Package1x Shanling Onix Tocata XM2
1x USB-A to USB-C cable
InputMicro SD
InputWiFi
OutputUSB
OutputJack 4.4mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipCS4308P
Max sampling rate768kHz
Max sampling rateDSD512
SHANLING ONIX TOCATA XM2 Digital Audio Player DAP CS4308P 32bit 768kHz DSD512
The Shanling Onix Tocata XM2 is a compact digital audio player designed to deliver high-resolution playback and amplification suitable for...
