Compact HiFi DAP 24bit 192kHz DSD64
The Hifiman MegaMini is a compact, lightweight, affordable and high-performance DAP. It supports high resolution files, has a comfortable autonomy and a large storage capacity. Its small size will allow you to take it with you everywhere and enjoy your music on the move, without it being noticed. If you are looking for a DAP with a good price/quality ratio then MegaMini is most probably the right product for you.
To store all your high-resolution files, the MegaMini allows you to insert a Micro SD card (not included) for storage up to 256GB. This will allow you to store about 8000 lossless pieces and no longer have to choose between quality and quantity because of a storage capacity that is too limited.
The battery integrated in the MegaMini allows you to listen for about 15 hours non-stop, ideal for your travels. In addition, such an autonomy combined with the storage capacity of this portable player means that you no longer have to rely on your smartphone and therefore save the latter's battery.
A successful DAP must have an effective interface. Hifiman has therefore worked to offer an intuitive and aesthetic system. Navigation is simple and access to your music is extremely fast, so you can spend more time listening to your music rather than looking for it in your walkman.
Where smartphones are not compatible with high resolution files, the MegaMini can play your music up to 24bit 192kHz and even DSD64. This way you can enjoy high quality audio playback wherever you are.
While the small size of the MegaMini is surprising, it is still a powerful DAP capable of delivering 54mW. A power that allows it to be associated with the majority of helmets without any problem.
Product type | DAP |
Frequency response | 20Hz - 20kHz |
THD | 0.08% |
Max output power | 54mW (1.4V @ 36 Ohm) |
Supported sampling rate | PCM up to 24bit 192kHz DSD64 |
Output connector | Jack 3.5mm |
Autonomy | 15 hours |
Supported file formats | WAV, FLAC, ALAC, APE, AIFF, DFF, DSF, MP3, OGG, AAC, WMA |
Storage capacity | Up to 256GB via Micro SD (not included) |
Dimensions | 43 x 100 x 9mm |
Weight | 69g |
Color | Silver |
Input | Micro SD |
Output | Jack 3.5mm |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Max sampling rate | DSD64 |
Color | Silver |
