By buying this product you get 119 loyalty points
Digital Audio Payer DAP Balanced 4x CS43198 FPGA Bluetooth 5.0 WiFi
A high-end digital music player, the iBasso DX300 features a neat architecture designed to deliver the best sound performance for a stunning music experience. Powerful and feature-rich, the DX300 is the perfect companion for listening on the go or at home.
At the heart of the DX300 is an FPGA-Master specifically designed for this model. The role of this FPGA-Master is to recover the audio data sent by the SoC in order to maintain a clean and stable signal. Associated with two Accusilicon clocks (22.5792M and 24.576M), it generates and perfectly synchronizes the clock signals. All in all, it ensures drastic jitter reduction to provide an extremely clean digital audio signal.
Qualcomm's integrated 8-core Snapdragon 660 processor, burned in 14nm, delivers incredible power to efficiently process audio signals while enabling smooth navigation within the device interface. This SoC comes with 6GB of RAM and 128GB of ROM storage (expandable via Micro SD card not included).
The power supply stage of the DX300 integrates two independent batteries. The first one powers the digital stage, where the second one powers the headphone amplifier. This separation of the power supplies limits possible interference between the digital and analog circuits in order to reduce the level of distortion as much as possible.
No less than four Cirrus Logic CS43198 QFN DACs are used in the iBasso DX300's digital-to-analog conversion stage for a total of 8 conversion channels. These combined channels provide the DAP with a fully symmetrical conversion circuitry while enhancing its sound performance.
A special feature of the DX300 is that the amplifier module's integrated circuit can be removed and replaced very easily. Changing this amplifier board thus allows you to modify the sound signature of the DAP to enjoy a reproduction in total adequacy with your type of listening or your headphones.
Featuring a gorgeous 6.5" borderless LTPS IPS touchscreen, with a resolution of 2340*1080 pixels and a pixel density of 397ppi, the DX300 offers fast and intuitive navigation. Above it, a thin LED indicator shows the status of the device.
The AMP11 amplifier module integrated with the iBasso DX300 is based on the brand's AMP8 and discrete component design. It delivers a high power output of 1240mW at 32Ω. In addition, the AMP11 offers multiple outputs, including two balanced outputs in 2.5mm and 4.4mm jacks and one unbalanced output in 3.5mm jacks.
In addition, the DX300 also features a 3.5mm Coaxial Jack output supporting audio streams up to PCM 384kHz and DoP DSD128 and can also be used as a USB DAC to take advantage of the device's conversion capabilities.
The iBasso DX300 interface is based on a fast and powerful Android 9.0 operating system, taking advantage of the hardware acceleration of the Snapdragon 660 GPU. In addition, the use of Android allows the installation of many applications. The independent reading system is based on Mango OS (5th generation), specifically developed for this use.
The DX300 benefits from extensive wireless connectivity, integrating a WiFi receiver using a 2x2 MIMO antenna. Thus, with two channels in and out, transmission speed and capacity is greatly improved.
Bluetooth 5.0 is also on board, with a high-performance associated antenna for increased transmission distance.
Product type | Digital Audio Player (DAP) |
Inputs | 1x Slot Micro SD |
Outputs | 1x Balanced Jack 2.5mm 1x Balanced Jack 4.4mm 1x Single-ended Jack 3.5mm 1x Coaxial Jack 3.5mm |
Other connectors | 1x USB-C 3.1 |
Connectivity | 802.11 b/g/n/ac (2.4GHz/5GHz) 2x2MIMO 5G WiFi Bluetooth 5.0 |
DAC Chip | 4x Cirrus Logic CS43198 |
FPGA | |
RAM | 6Go |
ROM (Storage) | 128Go |
Touch Screen | 6.5" IPS 2340 x 1080 pixels |
Batteries | 4000mAh 3.8V + 2000mAh 3.8V |
Charging time | 2.5h (Quick Charge QC 3.0 / USB-PD 2.0) |
Autonomy | 15h |
Supported audio formats | MQA, APE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST, CUE, ISO, M3U, M3U8 |
Balanced Jack 4.4mm / Jack 2.5mm Outputs Measures | |
Max output level | 7.1Vrms |
Power output | 1240mW @ 32Ω 168mW @ 300Ω |
Frequency response | 10Hz - 40kHz ±0.3dB |
SNR | 125dB |
Dynamic range | -125dB |
THD+N | -113dB (no load, 3Vrms) -109dB (300Ω) -101dB (32Ω) |
Channel separation | -120dB |
Impedance | 0.39Ω |
Single-ended Jack 3.5mm Output Measures | |
Max output level | 3.5Vrms |
Power output | 350mW @ 32Ω 34mW @ 300Ω |
SNR | 123dB |
Dynamic range | -123dB |
THD+N | -111dB (no load, 2Vrms) -107dB (300Ω) -95dB (32Ω) |
Channel separation | -103dB |
Impedance | 0.43Ω |
Balanced Jack 4.4mm / Jack 2.5mm Line Output Measures | |
SNR | 125dB |
THD+N | -111dB (no load, 3Vrms) |
Channel separation | -119dB |
Single-ended Jack 3.5mm Line output Measures | |
SNR | 123dB |
THD+N | -111dB (hors charge, 2Vrms) |
Power supply | Via USB-C |
Body material | Aluminum |
Color | Blue |
Dimensions | 162 x 77 x 17mm |
Weight | 300g |
Package | 1x iBasso DX300 1x USB-C Cable 1x Coaxial cable 1x Protective cover 1x Protective film for screen |
Input | WiFi |
Input | Micro SD |
Input | Bluetooth |
Output | Coaxial SPDIF |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
Output | Jack 2.5mm |
DAC / ADC Chip | CS43198 |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Blue |
