Let's not forget the sedentary, more expensive solutions.
Excellent player based on a double Sabre32 converter now very well known, this modern player combines an excellent touch interface, a compact format and an amazing audio quality.
With a surprising value for money, it is one of the major players in the DAP (digital audio player) scene and will serve as a high-quality digital source whether for nomadic or sedentary use.
Features:/ Strong>
- Bit Perfect: Supports sampling rates up to 24Bit / 192kHz
- DAC: One ESS Sabre32 ES9018K2M per channel
- Headphone amplifier: OPAMP OPA1611 x2, 2 x buffer BUF634 by Texas Instruments +/- 5V
- Display: -2.4 "IPS (320 * 240) Capacitive Touch
- Digital Output Coaxial: 24Bit / 192kHz  Li>
- Analog outputs: 3.5mm jack for headphones and line output
- USB: OTG (On The Go) function to use USB external storage
- Physical buttons: 3 buttons (Rewind, Play / Pause, Forward)
- Volume: digital control 256 steps
- Memory: 8 GB internal + support SDXC, SDHC and MicroSD up to 2 TB  Li>
- Play: Gapless
- Equalizer: 5 presets + "Custom"
- Gain: 3 settings per switch (to best fit all headphones)
- Supported formats: APE, FLAC, WAV, WMA, AAC,ALAC, AIFF, OGG, MP3
-  Battery: removable compatible I9300 2100mAh
-  Battery life: 8.5 hours
-  Charging time: 3h with AC adapter / 5.5h via USB
-  Dimensions: 64 x 100 x 17 mm
-  Weight: 140 g
 Specifications:
-  Line Output:-  Frequency response: 17Hz ~ 20KHz + / -0.1 dB
-  Noise Ratio: -119dB + / -1dB
-  THD + N: 0.0015%
-  Crosstalk: 115dB (1kHz)
-  Output Level: 1.7V rms (1kHz 0dB)
-  Headphone output:-  Frequency response: 17Hz ~ 20KHz + / -0.1 dB
-  THD + N: 0.0015% (32ohm charge)
-  Output Level: 1.3Vrms (Low gain), 2.0Vrms (Mid gain), 2.8Vrms (High Gain)
-  S / N: -118dB +/- 1dB (Low gain), -116dB +/- 1dB (Mid gain), -115dB +/- 1dB (High Gain)
-  Crosstalk: 75 dB (1 kHz 32 ohms)
-  Output Impedance: <0.1ohm
 Accessories :
-  USB cable: load and data
-  Coaxial cable
-  Screen Protectors
-  Black Silicone Case
  P>
 P>
 P>
 P>
 P>
In the package:
 P>
  P>
 P>
 P>
 P>
 P>
