SHANLING M0 HiFi DAP Compact Music Player DAC ES9218P 32bit 384kHz DSD Blue
Shanling offers with its M0 a high fidelity digital walkman extremely compact with an original design. But the Shanling M0 is also a concentrate of technologies and features to offer you high definition sound, wherever you are!
Reference : 13464
99,00 €tax incl.
82,50 € tax excl.
This product has been replaced by the new version, the SHANLING M0 PRO DAP DAC 2xES9219C.
Shanling M0
Shanling M0 DAP Baladeur Numérique Haute Fidélité Compact DAC ES9218P Bleu
xxx
Un DAP qui tient dans le creux de la main
The first thing that is obvious with this Shanling M0 is of course its particularly small size. Designed to follow you on all your travels, without cluttering you up, the DAP measures only 40 x 13.5 x 45mm. On the weight side, the M0 weighs only 38g. It will therefore easily be forgotten so you can fully enjoy your music.
However, Shanling does not make any concessions on ergonomics and integrates a magnificent 1.54" high definition touch screen from LG. This will allow you to easily access your music and act on all available parameters. A screen placed behind a curved tempered glass window and components protected by a superb 100% Aluminium CNC machined case.
xxx
An intelligent interface
If Shanling takes great care of the aesthetics of its product, this desire to offer a product that is both beautiful and easy to use is reflected in the software side of the MTouch OS operating system. Thus, the interface of the walkman allows quick and easy navigation, and access to many features.
xxx
xxx
A technique at the service of sound
On the sound side, the M0 incorporates an ESS ES9218P DAC ESS. This will allow a high quality Digital / Analog conversion in complete transparency. A converter combined with a powerful amplification section and analog volume control. A combination that allows this small DAP to offer an SNR of 118dB, a distortion of 0.004% and support sampling rates up to 32bit 384kHz, for accurate and detailed reproduction.
Unlimited connectivity
While the Shanling M0 of course has a Jack 3.5 format connector to connect it in the classic way to your headset, it also offers Bluetooth connectivity for a more comfortable use. Bluetooth connectivity with Sony LDAC and Qualcomm aptX technologies. This first technology, LDAC, allows you to enjoy Bluetooth Hi-Res Audio files, up to 24bit 96kHz 4.5Mbps, where conventional Bluetooth would only allow compressed 16bit 44.1Hz. The second technology, aptX, allows a transmission with less latency and more stable, in order to restore a clean signal.
xxx
xxx
USB-C bi-directional
In the same way, this portable player also offers a bi-directional USB-C port. Like Bluetooth, it will therefore be able to receive or send audio data. Ideal for enjoying the audio performance of the device.
Une batterie pour vous suivre partout
The DAP includes a 630mAh battery for a 15h autonomy in reading, and days in standby. Perfect for enjoying your music without interruption during all your travels and trips.
xxx
DACESS ES9218P
Output power80mW @ 32 Ohm
Recommanded headphone impedance8 - 300 Ohm
Frequency response20Hz - 20kHz (-0.5dB)
Distortion0.004% (500mV)
SNR118dB
Output impedance0.16 Ohm
Channel resolution70dB
Dynamic range> 105dB
Sampling rateUp to 32bit 384kHz / DSD128
Supported file formats
DSDDSD64, DSD128 (.iso, .dsf, .dff)
DXDUp to 32bit 384kHz
APEUp to 24bit 192kHz / 16bit 384kHz
FLACUp to 24bit 192kHz
ALACUp to 24bit 192kHz
WAVUp to 32bit 384kHz
AIFF / AIF32bit 192kHz
DTS-
Supported lossy file formatsMP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, CUE
Dimensions40 x 13.5 x 45mm
Screen1.54" 240 x 240px Haute Définition
Weight38g
Autonomie15h
Standby autonomy30 jours
Charging time2h
Battery630mAh
StorageMicro SD up to 512Go (not included)
OutputJack 3.5mm
ColorBleu
OutputJack 3.5mm
DAC / ADC ChipES9218P
Max sampling rateDSD128
Max sampling rate384kHz
ColorOther
ColorBlue
Shanling offers with its M0 a high fidelity digital walkman extremely compact with an original design. But the Shanling M0 is also a concentrate of...
