This product has been replaced by the new version, the SHANLING M0 PRO DAP DAC 2xES9219C.
HiFi DAP Compact Music Player DAC ES9218P 32bit 384kHz DSD Blue
Shanling offers with its M0 a high fidelity digital walkman extremely compact with an original design. But the Shanling M0 is also a concentrate of technologies and features to offer you high definition sound, wherever you are!
The first thing that is obvious with this Shanling M0 is of course its particularly small size. Designed to follow you on all your travels, without cluttering you up, the DAP measures only 40 x 13.5 x 45mm. On the weight side, the M0 weighs only 38g. It will therefore easily be forgotten so you can fully enjoy your music.
However, Shanling does not make any concessions on ergonomics and integrates a magnificent 1.54" high definition touch screen from LG. This will allow you to easily access your music and act on all available parameters. A screen placed behind a curved tempered glass window and components protected by a superb 100% Aluminium CNC machined case.
If Shanling takes great care of the aesthetics of its product, this desire to offer a product that is both beautiful and easy to use is reflected in the software side of the MTouch OS operating system. Thus, the interface of the walkman allows quick and easy navigation, and access to many features.
On the sound side, the M0 incorporates an ESS ES9218P DAC ESS. This will allow a high quality Digital / Analog conversion in complete transparency. A converter combined with a powerful amplification section and analog volume control. A combination that allows this small DAP to offer an SNR of 118dB, a distortion of 0.004% and support sampling rates up to 32bit 384kHz, for accurate and detailed reproduction.
While the Shanling M0 of course has a Jack 3.5 format connector to connect it in the classic way to your headset, it also offers Bluetooth connectivity for a more comfortable use. Bluetooth connectivity with Sony LDAC and Qualcomm aptX technologies. This first technology, LDAC, allows you to enjoy Bluetooth Hi-Res Audio files, up to 24bit 96kHz 4.5Mbps, where conventional Bluetooth would only allow compressed 16bit 44.1Hz. The second technology, aptX, allows a transmission with less latency and more stable, in order to restore a clean signal.
In the same way, this portable player also offers a bi-directional USB-C port. Like Bluetooth, it will therefore be able to receive or send audio data. Ideal for enjoying the audio performance of the device.
The DAP includes a 630mAh battery for a 15h autonomy in reading, and days in standby. Perfect for enjoying your music without interruption during all your travels and trips.
| Specifications | |
| DAC | ESS ES9218P |
| Output power | 80mW @ 32 Ohm |
| Recommanded headphone impedance | 8 - 300 Ohm |
| Frequency response | 20Hz - 20kHz (-0.5dB) |
| Distortion | 0.004% (500mV) |
| SNR | 118dB |
| Output impedance | 0.16 Ohm |
| Channel resolution | 70dB |
| Dynamic range | > 105dB |
| Sampling rate | Up to 32bit 384kHz / DSD128 |
| Supported file formats | |
| DSD | DSD64, DSD128 (.iso, .dsf, .dff) |
| DXD | Up to 32bit 384kHz |
| APE | Up to 24bit 192kHz / 16bit 384kHz |
| FLAC | Up to 24bit 192kHz |
| ALAC | Up to 24bit 192kHz |
| WAV | Up to 32bit 384kHz |
| AIFF / AIF | 32bit 192kHz |
| DTS | - |
| Supported lossy file formats | MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, CUE |
| Général | |
| Dimensions | 40 x 13.5 x 45mm |
| Screen | 1.54" 240 x 240px Haute Définition |
| Weight | 38g |
| Autonomie | 15h |
| Standby autonomy | 30 jours |
| Charging time | 2h |
| Battery | 630mAh |
| Storage | Micro SD up to 512Go (not included) |
| Output | Jack 3.5mm |
| Color | Bleu |
| Input | Bluetooth |
| DAC / ADC Chip | ES9218P |
| Max sampling rate | DSD128 |
| Max sampling rate | 384kHz |
| Color | Other |
| Color | Blue |
