SHANLING M2X DAP High Fidelity Digital Audio Player DAC AK4490 32bit 384kHz DSD256 Black
The Shanling M2X is a magnificent Hi-Res walkman with an AK4490 DAC and exceptional sound performance. Its many features make it a great companion for those who want to take their music with them everywhere.
Reference : 13956
219,00 €tax incl.
182,50 € tax excl.
This model is also available in red : SHANLING M2X Red.
Baladeur Haute Fidélité DAC AK4490 32bit 384kHz DSD256 NoirBaladeur Haute Fidélité DAC AK4490 32bit 384kHz DSD256 Noir
TIDAL Streaming
Stream all your favorite music in high quality with the TIDAL application integrated in the M2X!
Balanced output for an ever purer sound
The M2X uses a dual amplification circuit with balanced output to improve its audio performance. The result is better channel separation, detailed sound and superior overall sound quality. This balanced output uses a standard balanced connector in 2.5mm Jack format
Bluetooth USB Transmission
The Shanling M2X has the particularity of being able to connect to a USB computer in order to give it the function of a Bluetooth transmitter.
Bidirectionnal USB
The M2X is very versatile, and in addition to its classic use as a HiFi player, it also offers other very interesting features. Indeed, once connected to a computer, it will be able to work for it as a DAC and amplifier. If it is connected to an external DAC, it can then be used as a digital interface.
Design & Ergonomic
All the electronics of the M2X are integrated in a magnificent hull with soft curves for an improved grip and a curved 2.5D glass for the most beautiful effect. Everything has been designed to be very easy to use: its 147g weight, its reduced dimensions, the side buttons for playback control or the volume button also acting as an ON/OFF button.
Full tactil control
With its 3.2-inch LG high-brightness touch screen, the M2X allows full control of all its features at the touch of a fingertip. The display has a sensitivity, offering high accuracy for easy navigation.
MTouch 2.0, a system in constant evolution
The Shanling M2X is based on the MTouch 2.0 operating system, specially designed by the brand and therefore perfectly adapted for a HiFi player. Attentive to user feedback, Shanling is constantly improving its system for an ever more transparent and advanced use. Whether it is a question of small adjustments or new features, these will be available via a simple firmware update.
Built-in WiFi for increased connectivity
DLNA & AirPlay Support
The M2X supports DLNA* and AirPlay transmission protocols allowing you to stream your high-resolution audio files directly from your phone or computer.
* The M2X currently only supports the DLNA DMR class.
WiFi file transfer
Simply connect the M2X to your local network for fast and easy file transfer.
OTA updates
With OTA (Over The Air) updates, you no longer need to use your computer to perform firmware updates.
The best Bluetooth quality
The Shanling M2X supports Bluetooth protocols from Sony LDAC, Qualcomm aptX and AAC. The LDAC supports Hi-Res audio files with a sampling rate of up to 24bit 96kHz and a transmission rate 3 times higher than other Bluetooth technologies. The aptX is an advanced Bluetooth codec that offers CD-like sound quality and is compatible with more than 540 brands worldwide. Finally, AAC is an essential compression algorithm to ensure the best possible compatibility, especially with iOS devices.
A design based on more than 30 years of experience in HiFi
DAC :
The M2X incorporates a Japanese AKM AK4490EN analog digital conversion chip, recognized by audiophiles and used in many HiFi products. This ensures a natural and rich restitution.
Restoring audio signal :
The M2X uses an FPGA with a coding technology specially developed by Shanling, coupled with two independent and high quality KDS clocks.
Amplification circuit :
With a TI OPA1912 AOP acting as a low-pass filter, two AD8397 ADI amplifiers and high quality Panasonic capacitors, the M2S offers clean, powerful and dynamic sound.
Shielding :
In order to limit the noise due to electromagnetic interference that can affect the sound reproduction, a part of the M2X circuit is shielded with copper plates.
Many supported file formats
The M2X, to allow you to enjoy your entire music library, supports a wide range of file formats: DSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, AIF, DTSMP3, WMA, ACC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8. The M2X accepts Micro SD cards up to 2TB to store all your audio files.
Important battery life
The M2X's battery allows it to offer a long battery life. Thus, the player to play your music for 10h30 on unbalanced output and 7h30 on balanced output, and this without the need to recharge it. If in standby mode, the M2X provides 39 days of battery life.
Product typeDigital Audio Player (DAP)
ScreenDimensions : 3.2"
Resolution : 320 x 480px
Supported file formatsDSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, ACC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8
DSD up to  DSD256
Adjustable gain2 Positions : High or Low
StorageExternal Micro SD card, up to 2TB (sold separately)
DAC ChipAK4490EN
Bluetooth version4.2
Supported Bluetooth protocolsLDAC (bidirectionnal)
aptX (transmit only)
AAC (bidirectionnal)
Single-ended output measurementsOutput power180mW @ 16Ω / 106mW @ 32Ω
Frequency response20Hz - 40kHz (-0.5dB)
SNR117dB (A-Weighting)
Output impedance1Ω
Channel separation70dB (32Ω)
Dynamic range116dB
Distortion0.0015%
Balanced output measurementsOutput power212mW @ 16Ω / 120mW @ 32Ω
Output impedance2Ω
Channel separation107dB
Dynamic range116dB
Distortion0.0016%
WiFi StandardIEEE 802.11b/g/n
Supported WiFi protocolsDLNA
AirPlay
Tidal Streaming
Autonomy10h30 on single-ended output
Charging timeApprox. 2h30
Battery capacity2400mAh
Dimensions90 x 60 x 16mm
Weight147g
Charge5VDC 2A via USB-C
InputWiFi
OutputJack 2.5mm
OutputWiFi
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipAK4490
Max sampling rate384kHz
Max sampling rateDSD256
The Shanling M2X is a magnificent Hi-Res walkman with an AK4490 DAC and exceptional sound performance. Its many features make it a great companion...
