This model is also available in red : SHANLING M2X Red.
Stream all your favorite music in high quality with the TIDAL application integrated in the M2X!
The M2X uses a dual amplification circuit with balanced output to improve its audio performance. The result is better channel separation, detailed sound and superior overall sound quality. This balanced output uses a standard balanced connector in 2.5mm Jack format
The Shanling M2X has the particularity of being able to connect to a USB computer in order to give it the function of a Bluetooth transmitter.
The M2X is very versatile, and in addition to its classic use as a HiFi player, it also offers other very interesting features. Indeed, once connected to a computer, it will be able to work for it as a DAC and amplifier. If it is connected to an external DAC, it can then be used as a digital interface.
All the electronics of the M2X are integrated in a magnificent hull with soft curves for an improved grip and a curved 2.5D glass for the most beautiful effect. Everything has been designed to be very easy to use: its 147g weight, its reduced dimensions, the side buttons for playback control or the volume button also acting as an ON/OFF button.
With its 3.2-inch LG high-brightness touch screen, the M2X allows full control of all its features at the touch of a fingertip. The display has a sensitivity, offering high accuracy for easy navigation.
The Shanling M2X is based on the MTouch 2.0 operating system, specially designed by the brand and therefore perfectly adapted for a HiFi player. Attentive to user feedback, Shanling is constantly improving its system for an ever more transparent and advanced use. Whether it is a question of small adjustments or new features, these will be available via a simple firmware update.
The M2X supports DLNA* and AirPlay transmission protocols allowing you to stream your high-resolution audio files directly from your phone or computer.
* The M2X currently only supports the DLNA DMR class.
Simply connect the M2X to your local network for fast and easy file transfer.
With OTA (Over The Air) updates, you no longer need to use your computer to perform firmware updates.
The Shanling M2X supports Bluetooth protocols from Sony LDAC, Qualcomm aptX and AAC. The LDAC supports Hi-Res audio files with a sampling rate of up to 24bit 96kHz and a transmission rate 3 times higher than other Bluetooth technologies. The aptX is an advanced Bluetooth codec that offers CD-like sound quality and is compatible with more than 540 brands worldwide. Finally, AAC is an essential compression algorithm to ensure the best possible compatibility, especially with iOS devices.
DAC :
The M2X incorporates a Japanese AKM AK4490EN analog digital conversion chip, recognized by audiophiles and used in many HiFi products. This ensures a natural and rich restitution.
Restoring audio signal :
The M2X uses an FPGA with a coding technology specially developed by Shanling, coupled with two independent and high quality KDS clocks.
Amplification circuit :
With a TI OPA1912 AOP acting as a low-pass filter, two AD8397 ADI amplifiers and high quality Panasonic capacitors, the M2S offers clean, powerful and dynamic sound.
Shielding :
In order to limit the noise due to electromagnetic interference that can affect the sound reproduction, a part of the M2X circuit is shielded with copper plates.
The M2X, to allow you to enjoy your entire music library, supports a wide range of file formats: DSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, AIF, DTSMP3, WMA, ACC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8. The M2X accepts Micro SD cards up to 2TB to store all your audio files.
The M2X's battery allows it to offer a long battery life. Thus, the player to play your music for 10h30 on unbalanced output and 7h30 on balanced output, and this without the need to recharge it. If in standby mode, the M2X provides 39 days of battery life.
| Specifications | ||||||
| Product type | Digital Audio Player (DAP) | |||||
| Screen | Dimensions : 3.2" Resolution : 320 x 480px | |||||
| Supported file formats | DSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, ACC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8 | |||||
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 | |||||
| Adjustable gain | 2 Positions : High or Low | |||||
| Storage | External Micro SD card, up to 2TB (sold separately) | |||||
| DAC Chip | AK4490EN | |||||
| Bluetooth version | 4.2 | |||||
| Supported Bluetooth protocols | LDAC (bidirectionnal) aptX (transmit only) AAC (bidirectionnal) | |||||
| Single-ended output measurements | Output power | 180mW @ 16Ω / 106mW @ 32Ω | ||||
| Frequency response | 20Hz - 40kHz (-0.5dB) | |||||
| SNR | 117dB (A-Weighting) | |||||
| Output impedance | 1Ω | |||||
| Channel separation | 70dB (32Ω) | |||||
| Dynamic range | 116dB | |||||
| Distortion | 0.0015% | |||||
| Balanced output measurements | Output power | 212mW @ 16Ω / 120mW @ 32Ω | ||||
| Output impedance | 2Ω | |||||
| Channel separation | 107dB | |||||
| Distortion | 0.0016% | |||||
| WiFi Standard | IEEE 802.11b/g/n | |||||
| Supported WiFi protocols | DLNA AirPlay Tidal Streaming | |||||
| Autonomy | 10h30 on single-ended output 7h30 on balanced output | |||||
| Charging time | Approx. 2h30 | |||||
| Battery capacity | 2400mAh | |||||
| General | |
| Dimensions | 90 x 60 x 16mm |
| Weight | 147g |
| Charge | 5VDC 2A via USB-C |
| Color | Black |
| Input | USB |
| Input | WiFi |
| Input | Bluetooth |
| Output | Jack 3.5mm |
| Output | Bluetooth |
| Output | Jack 2.5mm |
| Output | WiFi |
| DAC / ADC Chip | AK4490 |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Black |
