XDUOO X-10T II DAP 32bit 384kHz DSD256 - Interface USB to S/PDIF
By buying this product you get 20 loyalty points
Reference : 13490
209,00 €tax incl.
174,17 € tax excl.
DAP XDuoo X10T II
Nomadic file player / Optical, Coax, AES, USB OTG, Bluetooth apt-X / 384kHz 32-bit DSD254
DAP XDUOO XD-10T II
The X10T XDuoo II is a high-fidelity mobile digital audio player (DAP). Extremely complete, it has a variety of connections with rare features in its price range. With many possibilities, good overall design and 2.4 "high quality display (IPS), it is a pleasant device for every day. It will delight fans of high definition music anywhere and anytime.
DAP HIFI
Built for high-definition music
The X10T2 has wide audio compatibility. He is able to read PCM files up to 384kHz / 32-bit and DSD up to DSD256.
Moreover, the device supports all major common file encocding types such as FLAC, APE, WAV, ALAC, AIFF and DSD HD.
Equipped with a micro-SD / TF card reader that handles up to 256GB, the DAP can carry a substantial music library for long hours of high definition listening.
Advanced connectivity
Xduoo X10TII's connectivity has been wisely though for optimal compatibility.
On input, the DAP has a micro SD / TF card reader, a USB-C port as well as Bluetooth connectivity.
On Output, there is a USB port-C also supports S / PDIF Coaxial. The device is also equipped with AES output on mini-XLR port. Finally, finally a SPDIF Optical / Coaxial through a Jack 3.5mm port.
DAP AES USB-C
Xduoo XD-10T II DAP autonomous battery
Tough and compact
The device is equipped with a rechargeable Lithium-Ion battery 2400mAh. The latter offers nearly 15 hours of continuous playback and recharges in less than 3 hours.
Despite its generous capacity, the device remains very compact and easy to carry with dimensions of 103.3 x 54.3 x 15.2mm and weighs 130g only.
Support Hibby Link
If it is not already busy exchanging the audio stream with your smartphone, the DAP can communicate with devices running Hiby LINK.
This function is particulary useful when used with home-speaker
DAP Hiby
Stand alone file transfert
DAP USB file player
The USB-C port supports OTGand allows the X10TII to communicate directly with an Android device (smartphone, tablet ... etc.). It is thus possible to upload music files to DAP from external apppareil and vice versa.
Please note that this feature is not available with devices running IOS.
DAP USB file player
If connected to a computer, the digital audio player can be used as a digital interface. When this feature is active, the device can connect a computer that only has USB outputs with a Hi-Fi chain that only have S / PDIF inputs.
Please note that X10 TII can not interface USB to Bluetooth.
Bluetooth apt-X
DAP Bluetooth transmitter and receiver
This DAP has Bluetooth connectivity with apt-X standard. It can act as transmittter and receiver and offer a restitution close to CD quality. This particular technology provides smart compression ratio. That is to say, a file that has already been compressed files will be submitted to further compression, while non-compressed files will only receive the compression ratio that is absolutely necessary to meet from the demands of wireless transmission.
The processor is powerful enough to simultaneously process the Bluetooth Audio and file playback. In transmitter mode, the same signal can be routed to S / PDIF and Bluetooth output. On receiver mode the Bluetooth X10TII input can be processed in real time toward SPDIF.
DAP X-10T II & POKE DAC
Matching with XDUOO POKE
Xduoo X-10T's fiorm factor matches the POKE a high-performance DAC / headphone amplifier from Xduoo as well.
TypeDAP (digital audio player)
Screen2.4 inches. IPS Full HD vision
240x320 pixels
Materialsmast aluminum shell.
CPUINGENIC X1000
DrumsLithium-ion 3.7V / 2400mAh
Power supplyfemale USB-C.
5V / 2A DC
Loading timeapproximately 3H
battery playback timeapproximately 15H
inputsUSB-C female
Micro-SD / TF
Bluetooth
OutputsOptical / Coaxal
USB-C
AES
Bluetooth
Internal memoryNo
external memoryTF Card / Micro SD up to 256GB
Weight130g
Dimensions103.3 x 54.3 x 15.2mm
cable accessories provided X10T2 parts included
Accessories
The XT-10II comes with many accessories to make it more enjoyable user experience.
Are delivered, a charging cable, an optical cable, coaxial cable, USB cable to USB-C-C-C cable USB to micro-USB, mini XLR to XLR cable (AES).
The set also comes with an elegant case and two plastic covers of protection for the screen.
Package Contents
Xduoo X10T-IIx1
Charging cablex1
Optical cablex1
Coaxial cablex1
USB cable to USB-C-Cx1
USB-cable C to Micro-USBx1
Mini XLR to XLR Cablex1
Casex1
Film Screen Protectorx2
OutputUSB
OutputBluetooth
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rate384kHz
Max sampling rateDSD256
Interface chipNC
Great idea
It does what it says. Great set of cables. It is more practical to use it with Mojo than Poly. Navigation could be improved as well as manual but for the price - equivocally a 5 star product.
This review has been posted for XDUOO X-10T II DAP 32bit 384kHz DSD256 - Interface USB to S/PDIF
