WONDOM PS-SP12159 Car SEPIC DC / DC Converter 12V DC to 9V-24V DC 100W
The Wondom PS-SP12159 is a SEPIC DC/DC converter (Single Ended Primary Inductor Converter), which converts a 12V DC DC voltage into an adjustable voltage via a DIP switch from 9V DC to 24VDC.
Reference : 13727
24,90 €tax incl.
20,75 € tax excl.
SEPIC DC/DC Converter
Convertisseur SEPIC pour voiture 12V DC vers 9V-24V DC 100W
The Wondom PS-SP12159 is a SEPIC DC/DC converter (Single Ended Primary Inductor Converter), which converts a 12V DC DC voltage into an adjustable voltage via a DIP switch from 9V DC to 24VDC. To perform this conversion, this type of converter modifies the closing duty cycle of transistors.
The module is equipped with a status LED and has undervoltage and overload protection.
Voltage output selection
The module's DIP switch allows you to change the value of the output voltage from 9V to 24V DC. The table below details the different possible values and switch positions to be used. This table is also available on the back of the PCB.
Tension de sortieK1K2K3K4
9V DCONONONON
10V DCOFFONONON
11V DCONOFFONON
12V DCOFFOFFONON
13V DCONONOFFON
14V DCOFFONOFFON
15V DCONOFFOFFON
16V DCOFFOFFOFFON
17V DCONONONOFF
18V DCOFFONONOFF
19V DCONOFFONOFF
20V DCOFFOFFONOFF
21V DCONONOFFOFF
22V DCOFFONOFFOFF
23V DCONOFFOFFOFF
24V DCOFFOFFOFFOFF
All dimensions are millimeters
Product typeDC/DC SEPIC Converter
Input voltage12V DC
Output voltageAdjustable from 9V to 24V DC
ProtectionsUnder voltage
Overload
Dimensions68.5 x 91.5 mm
Spacings2mm / M3.5
Measurements
ParameterMinTypMax
Supply voltage11V12V27V
Under voltage protection-11V-
Output power-100W-
Overload protection-120W-
Operating temperature0°C20°C80°C
Thermal protection-150°C-
Output voltage (V)21.0
Output voltage (V)19.0
Output voltage (V)23.0
Output voltage (V)11.0
Output voltage (V)9.0
Output voltage (V)14.0
Output voltage (V)12.0
Output voltage (V)20.0
Output voltage (V)18.0
Output voltage (V)22.0
Output voltage (V)10.0
Output voltage (V)15.0
Output voltage (V)13.0
Output voltage (V)24.0
Output voltage (V)17.0
Output voltage (V)16.0
Output current (A)NC
Input voltage (V)12.0
The Wondom PS-SP12159 is a SEPIC DC/DC converter (Single Ended Primary Inductor Converter), which converts a 12V DC DC voltage into an adjustable...
