Connector
Material
Connectic
Length
0 m - 3 m
Section (mm²)
0 mm - 2 mm
Conductors material (Cable)
Mounting type
Color
Conductors Plating (Cable)
Number of conductors
Shielding
Walter V.
Great product!
Joli mais non..
NAEL C.
Marvelous !
DC power cables
Discover all our DC jack cables, allowing the supply of many audio devices.
