produit de qualité et conforme à mon attente, aucune difficulté pour le branchement. résultat satisfaisant après essai.
Power Cable Jack DC 2.1mm to DC 2.1mm 1m
This cable has been assembled by us in the Audiophonics workshops in order to allow you to enjoy the quality of the ELECAUDIO range at a lower cost. The choice of materials has been carefully studied and the smallest details are checked to offer you a top-of-the-range cable. Particularly robust and well finished, the ELECAUDIO DC DC-2.1G jack has a clamping system and the contacts are 24K gold plated.
The conductors are composed of 147 0.12mm strands with a cross-section of 1.6mm² made of OFC Copper with FEP insulation. These conductors are then protected by a Viablue sheath with impeccable finishes. In a concern for quality and performance, we have opted for a Mundorf Supreme Silver 10% solder. This cable has been developed for music lovers looking for optimal quality without losses for high efficiency above all.
Product type | Power Cable Jack DC 2.1mm to Jack DC 2.1mm |
Cable model | Elecaudio FC116TC |
Cable conductor | OFC Copper Ø 2.2mm |
Section | 1.6mm² |
Connectors model | Elecaudio DC-2.1G |
Connectors plating | Gold 24k |
Welding used | Mundorf Supreme Argent 10% |
Insulation | FEP |
Color | Gray, white, yellow, black |
Length | 1m |
Input | NC |
Output | NC |
Length (m) | 1.0 |
Shielding | No |
Section (mm²) | 1.6 |
Connector | Jack DC |
Output voltage (V) | NC |
Output current (A) | NC |
Input voltage (V) | N/A |
Power Supply | NC |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 4.8 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Geneviève S.
Leandros B.
Christian G.
Vincent P.
jean francois F.
