By buying this product you get 419 loyalty points
With the Soloist Voyager, Burson Audio presents the flagship of its headphone amplifiers. Loyal to themselves, Burson Audio offers us a class A dual-mono amplifier equipped with 3 Vivid Pro AOP V7s per channel, coupled with their ultra-quiet SP02 power supply modules, offering crystal-clear sound reproduction coupled with the total absence of background noise. This DELUXE model is also accompanied by the brand's SUPER CHARGER 5A power supply.
As Burson Audio's ambition is to offer the very best, the Soloist Voyager is equipped with the brand's latest innovations. First of all, in order to provide the cleanest possible power supply for all other components, the Soloist Voyager is equipped with SP02 modules, offering an incredibly low noise level of just 0.8nVrms. To complete its dual-mono structure and Class A amplification, the Soloist Voyager also features 3 Vivid Pro AOP V7 per channel for crystal-clear sound reproduction. On the cooling side, the Soloist Voyager swaps the Noctua ventilation system of its predecessor for a much quieter cooling system involving a massive heatsink coupled with a tiny fan under the PCB.
In addition to the quality of its components, the Soloist Voyager is also characterized by its flexibility of use. In fact, it comes with a host of features to perfect the listening experience by adapting to each listener. For example, the hardware crossfeed for headphones and speaker balancing give you total control over the soundstage. Furthermore, you can experiment with headphone listening combined with a subwoofer, thanks to the dedicated socket on the back of the amplifier. Last but not least, the Soloist Voyager has been designed to grow with you over time. In fact, the DIP8 mounting of the AOPs and the design of the power supply modules mean that you can easily replace them, so you can upgrade your machine to keep you at the forefront of Hi-fi.
Product type | Headphone amplifier |
Inputs | 2x Stereo XLR 2x Stereo RCA 1x Mic Bypass |
Outputs | 1x Stereo XLR 1x Stereo RCA 1x Subwoofer output 1x Balanced 4 poles XLR headphone output 1x Single-ended Jack 6.35mm headphone output 1x Single-ended Jack 3.5mm headphone output |
Input impedance | 38kΩ |
Frequency response | 0Hz - 48kHz ±1dB |
Total harmonic distortion (THD) | ≤ 0.0015% |
Output impedance | Amplificateur casque : 0.5Ω Pre-Out : 25Ω |
Power (Balanced) | 10W @ 16Ω, SNR 116dB, Channel separation 99% 8W @ 32Ω, SNR 111dB, Channel separation 99% 3.8W @ 100Ω, SNR 110dB, Channel separation 99% 1.3W @ 150Ω, SNR 110dB, Channel separation 99% 640mW @ 300Ω, SNR 109dB, Channel separation 99.5% |
Power (Single-ended) | 5W @ 16Ω, SNR 116dB, Channel separation 99% 4W @ 32Ω, SNR 111dB, Channel separation 99% 1.9W @ 100Ω, SNR 110dB, Channel separation 99% 650mW @ 150Ω, SNR 110dB, Channel separation 99% 320mW @ 300Ω, SNR 109dB, Channel separation 99.5% |
Dimensions | 260 × 270 × 85mm |
Weight | 7kg |
Housing material | Aluminum |
Package | 1x Burson Audio Soloist Voyager Deluxe 1x Remote control 1x Burson Super Charger 24V 5A 2x XLR to RCA adapters |
Input | XLR |
Input | RCA |
Output | XLR |
Output | Subwoofer |
Output | Jack 3.5mm |
Output | Jack 6.35mm |
Output | RCA |
Color | Silver |
Class | Class A / AB |
Remote Control | Yes |
