By buying this product you get 266 loyalty points
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier based on MOSFET transistors to deliver natural sound reproduction and 10W of power at 32Ω.
The Prelude features Class A amplification based on MOSFET transistors in a fully discrete balanced circuit. To take full advantage of this architecture, the circuit incorporates a signal balancer, transforming the RCA input signal into a fully balanced signal, drastically reducing noise and interference. The result is a natural-sounding signal with a power handling of 10W at 32Ω.
To achieve precise control over channel balance for its pre-amplifier, HIFIMAN uses a 4-voice potentiometer from ALPS, known for its high quality and precision, enabling the brand to fine-tune this parameter without coloring the sound in any way.
Specially designed for the Prelude, the high-power, low-noise toroidal transformer provides a clean, stable power supply at all levels of the headphone amplifier, helping to improve the quality of the final output. The amplifier housing is made from a single piece of aluminum, isolating harmful resonances that can degrade audio performance, guaranteeing a clean sound output.
1 | XLR/Jack 6.35mm output |
2 | Input selector |
3 | Gain selector |
4 | Output selector |
5 | XLR 4-pin output |
6 | 4.4m jack output |
7 | Volume control |
8 | RCA inputs |
9 | Power supply connector |
10 | XLR Pre-amp output |
11 | Pre-amp RCA output |
12 | XLR input |
Product type | Headphone amplifier Preamplifier |
Inputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
Outputs | 1x Combo XLR balanced / 6.35mm jack single-ended 1x XLR 4-pin balanced 1x Balanced 4.4mm jack 1x Balanced XLR pre-amp output 1x Single-ended RCA pre-amp output |
Frequency response | 20Hz-50kHz |
Signal-to-noise ratio (SNR) | -113dB @ 1kHz |
Total harmonic distorsion more noise(THD+N) | 0.0009% @ 1kHz, low gain |
Power output | 10W @ 32Ω 6W @ 64Ω 2.5W @ 150Ω 1W @ 300Ω 560mW @ 600Ω |
Power supply voltage | 220V AC 50/60Hz |
Power consumption | < 50W |
Dimensions | 330 x 56 x 260mm |
Weight | 6.5kg |
Color | Black |
Package | 1x HIFIMAN Prelude 1x Power cord |
Input | XLR |
Input | RCA |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
Color | Black |
Class | Class A / AB |
Remote Control | No |
