LITTLE DOT MKVI + MK6 + Tubes Headphone Amplifier / Balanced Preamplifier
By buying this product you get 109 loyalty points
Reference : 5222
1 099,00 €tax incl.
915,83 € tax excl.
Including 1,00 € for green tax
Shipping date: 16-12-2025.
Little Dot Headphone Amplifier MKVI + MK6 +
Headphone amplifier and / or 100% symmetrical tube preamplifier.
The little Dot MK6 + has a large dynamic range, and can provide a signal up to 70V with a 120ohm load.
The Class-A Single-Ended Push Pull (SEPP) balanced output has no link capacitor for dynamic and detailed playback, as well as extended bass.
The components contained in this device have been selected for their quality you will find:
  • ALPS Potentiometer
  • Resistors Vishay DALE
  • WIMA, ERO and Chemi-Con Capacitors
Specifications:
  • Architecture 100% symmetrical
  • SEPP (Output CapacitorLess) in Class-A
  • Driver Tubes: 2x 6H9C
  • Power Tubes: 4x RCA 6080
  • Active ventilation 2 fans
  • Enter:
  • Symmetry: 2x 3-pin XLR
  • Asymmetric: 2x RCA
  • Exits:
  • Symmetrical: 4-Pin XLR
  • Symmetric Pre-Amp: 2x 3-pin XLR
  • Asymmetrical: 1/4 "(6.35mm) TRS Stereo jack
  • Frequency Response:
    • 5Hz - 80KHz (-3dB)
    • 10Hz - 30KHz (-1dB)
  • Input impedance: 50K ohms
  • Output impedance Pre-Amp: 600 ohms
  • THD + N:
    • 0.02% (2Vrms @ 1000Hz)
    • 0.06% (10Vrms @ 1000Hz)
    • 0.3% (20Vrms @ 1000Hz)
  • Signal to Noise Ratio: 92 dB
  • 2 gain settings:
    • Low (All Headphones)
    • High (suitable for AKG K1000)
  • Output Power:
    • 5W per channel in 120 ohms
    • Power Consumption: 25 VA
  • Dimensions:
  • 350mm (length) by 290mm (width) by 140mm (height)
  • Weight: 9.6 kg or 21 lbs
  • 220-240VAC
https://www.audiophonics.fr/images2/5222/5222_littledot_mk6_amplifier_3.jpg
https://www.audiophonics.fr/images2/5222/5222_littledot_mk6_amplifier1.jpg
https://www.audiophonics.fr/images2/5222/5222_littledot_mk6_amplifier2.png
InputXLR
OutputJack 6.35mm
ClassTube amp
