By buying this product you get 44 loyalty points
Open Circumaural Planar Magnetic Headphone 99dB 10Hz - 50kHz 16 Ohm
The Audeze LCD-1 has been meticulously designed and engineered to provide high quality sound reproduction to satisfy the most demanding audiophiles. This headset integrates Audeze's renowned Planar Magnetic technology into an open, foldable and lightweight design. Versatile, the LCD-1 is the ideal ally for enjoying excellent audio quality on the go, for listening at home and even for mixing and mastering audio.
Indeed, for decades, professional musicians and sound engineers from all over the world have placed their trust in Audeze headphones. This heritage inspired Audeze to create the LCD-1, a new benchmark in studio listening and audiophile listening.
The LCD-1 combines the sound quality of the LCD range with improved comfort and portability. Its 90mm Planar Magnetic membranes allow a wide frequency range from 10Hz to 50kHz to be reproduced with incredible precision and clarity, ideal for both audiophile listening and professional applications. With only 250 grams on the scale and incorporating shape memory cushions, the LCD-1 has been designed to allow long listening sessions without fatigue. The cable specially designed for the headset has reversible connectors so that the LCD-1 provides the right information for the left and right channels in all situations.
The LCD-1's open circumaural design allows it to reveal a large sound scene to immerse you in the depths of your music. At the heart of the headset, the Fluxor™ magnets and Uniforce™ coils work together to deliver finely tuned, distortion-free sound with impressive power. From its impressive musical presence to its flawless transparency, the LCD-1 has been designed for a faithful reproduction of the original message.
Each LCD-1 membrane is handcrafted with great precision in the Audeze workshop in Southern California. Using Audeze's patented engineering techniques and state-of-the-art laser engraving technology, each step of the manufacturing process is carefully carried out
| Specifications | |
| Product type | Open-circumaural, over-ear headphone |
| Transducer type | Planar Magnetic |
| Magnetic structure | Single-sided Fluxor™ magnet array |
| Phase management | Fazor |
| Magnet type | Neodymium N50 |
| Diaphragm type | Ultra-thin Uniforce™ |
| Transducer size | 90mm |
| Maximum power handling | 5W RMS |
| Maximum SPL | > 120dB |
| Frequency response | 10Hz - 50kHz |
| THD | < 0.1% @ 100dB |
| Impedance | 16Ω |
| Sensitivity | 99dB/1mW (@ Drum Reference Point) |
| Ear pads | Memory foam + leather |
| Foldable headphone | |
| Weight | 250g |
| Color | Black |
| Package | 1x Audeze LCD-1 1x Jack 3.5mm to dual Jack 3.5mm cable 2m 1x Jack 3.5mm to Jack 6.35mm adapter 1x Zippered travel case 1x Certificate of Authenticity |
| Color | Black |
| Impedance (Ω) | 16 |
| Efficiency / Sensitivity (dB) | 99.0 |
| Lowest frequency (Hz) | 10 |
| Highest frequency (Hz) | 50000 |
