By buying this product you get 59 loyalty points
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for digital/analogue conversion up to PCM 32bit 384kHz and DSD256 and an output power of 1600mW at 32Ω. These top-of-the-range components ensure quality sound reproduction that's both warm and soft, all housed in a beautiful enclosure.
The RT-5000 features two ES9038Pro DAC chips using HyperStream II technology to deliver exceptionally accurate, jitter-free conversion. Thanks to ESS's SABRE chips, the RT-5000 is capable of supporting a high-resolution stream of up to 32bit 384kHz PCM and DSD256 while boasting a signal-to-noise ratio (SNR) of 125dB and a harmonic distortion rate (THD) of -112dB.
The RT-5000 also incorporates a total of 10 Texas Instrument OPA1612s. 8 of these are responsible for the I/V circuit and the remaining two act as LPF amplifiers, perfectly complementing the ESS DAC chips to produce HiFi sound reproduction with ultra-low distortion and impressive dynamics.
The RT-5000's amplifier stage is based on a pair of J-FET JRC MUSES01 transistors capable of delivering 1600mW of power at 32Ω balanced and 800mW at 32Ω single-ended. This top-of-the-range pair of transistors delivers warm, smooth sound with powerful bass and a wide soundstage.
To provide high-quality Bluetooth connectivity, the RT-5000 is equipped with Qualcomm's QCC5125 chip, which supports the high-definition LDAC, aptX Low Latency and aptX Adaptive protocols.
Furthermore, in addition to its excellent sound, the RT-5000 is as pleasing to the eye as it is to the ear. Its chassis skilfully combines a CNC-machined aluminium structure with a wooden front panel, leather covering for the upper part and gold plating for the interactive elements, offering a finish that is both classy and elegant.
1 | 6.35mm jack headphone output |
2 | 3.5mm jack headphone output |
3 | Balanced 4.4mm jack headphone output |
4 | Gain adjustment |
5 | Mute |
6 | EQs preset |
7 | Operating indicator |
8 | Volume potentiometer |
9 | USB-B input |
10 | Toslink optical input |
11 | Coaxial input |
12 | Bluetooth antenna / Pairing |
13 | RCA line output |
14 | XLR line output |
15 | Power on |
16 | DC power port |
Technical specifications
Type of product | DAC Headphone Amplifier |
Inputs | 1x Coaxial 1x Optical Toslink 1x USB-B Bluetooth |
Outputs | 1x Single-ended 3.5mm jack headphone output 1x Balanced 4.4mm jack headphone output 1x Single-ended 6.35mm jack headphone output 1x Single-ended stereo RCA line output 1x Balanced stereo XLR line output |
DAC chips | 2x ES9038Pro |
Amplification chips | 2x JRC MUSES01 |
LPF | 2x OPA1612 |
I/V circuit | 8x OPA1612 |
Bluetooth chip | Qualcomm QCC5125 |
Output power | Single-ended: 800mW @ 32Ω Balanced: 1600mW @ 32Ω |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
THD | -112dB (0.0005%) |
SNR | 125dB |
Channel separation | -115dB |
Supported Bluetooth codecs | DAC, aptX Adaptive, aptX HD, aptX, AAC, SBC |
Supported formats | MP3, WMA, FLAC, WAV, AAC, HE-AAC, Apple Lossless, AIFF, DSD, DXD, APE, MQA |
Power supply | 15V DC 3A |
Color | Green |
Weight | 825g |
Package | 1x Roseselsa RT-5000 1x Mains adapter 1x USB-B to USB-C cable 1x USB-B to USB-A cable |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Output | RCA |
Output | XLR |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Green |
Class | N/A |
Networking | No |
Remote Control | No |
