SHANLING EH3 DAC ES9039PRO Headphone Amplifier Black
With the EH3, Shanling offers us an extremely versatile DAC with volume control, which can also be used as a headphone amplifier or as a streamer. Indeed, in addition to its ES9039PRO DAC chip, Shanling also offers an amplification system based on four OPA1612s, and the possibility of playing audio files directly from a local server or DLNA application thanks to its Wifi connection.
By buying this product you get 79 loyalty points
Reference : 19148
790,00 €tax incl.
658,33 € tax excl.
SHANLING EH3 DAC ES9039PRO Headphone Amplifier WiFi Bluetooth aptX LDAC 32bit 768kHz DSD512 Black
SHANLING EH3 DAC ES9039PRO Headphone Amplifier WiFi Bluetooth aptX LDAC 32bit 768kHz DSD512 Black : Front view
Shanling EH3 : Cutting edge sound processing
At the heart of the EH3 is an ESS ES9039PRO DAC chip. This high-performance 8-channel chip, based on Hyperstream IV technology, enables the EH3 to decode up to 32bit 768kHz PCM and up to DSD512, and to do so symmetrically so as to limit the interference created by the influence of one channel on the other.
Management of USB connectivity is entrusted to an XMOS XU316 chip, enabling transparent sound reproduction while ensuring support for the above-mentioned sampling formats.
On the amplification side, this is ensured by four OPA1612s, recognized as operational amplifiers with very low noise density (1.1-nV/√Hz ) and virtually zero distortion (0.000015% at 1kHz ). As a result, Shanling's EH3 deploys power ranging from 126 mW to 1900 mW at 32 Ω unbalanced, and up to 5300 mW at 32 Ω balanced.
Shanling EH3 : Versatile connectivity
Shanling's EH3 offers a wide variety of inputs and outputs. Indeed, it is possible to use a wired input in coaxial, optical, USB-A, USB-B, RCA or HDMI I2S, but you also can connect to the device via Bluetooth 5.0 or link it to your local network via Wifi. Finally, the EH3 is also compatible with the Airplay protocol, so it can receive music from any Apple device.
On the output side, there are four headphone outputs on the front panel: an unbalanced 6.35mm jack output, an unbalanced 3.5mm jack output, a balanced 4.4mm jack output and a balanced 4-pins XLR output. The rear panel features an RCA output and a 3-pins XLR output, which can bypass the volume control if desired. Finally, the EH3 can be controlled remotely via Shanling's proprietary Eddict Player application.
Product typeDAC with volume
Headphone Amplifier
Streamer
ConnectivityWiFi Dual Band 2.4/5Ghz
Bluetooth 5.0
DLNA
AirPlay
Inputs1x Optical Toslink
1x Coaxial SPDIF
1x USB-B
2x USB-A
1x RCA
1x HDMI I2S
Outputs1x Balanced XLR 4 pins headphone output
1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 3.5mm headphone output
1x Single-ended Jack 6.35mm headphone output
1x RCA (line-out or pre-amp)
1x XLR 3 pins (line-out or pre-amp)
DAC ChipESS ES9039PRO
Supported Bluetooth codecsLDAC, aptX HD, aptX, AAC and SBC
Supported sampling ratesDSD : up to DSD512
PCM : up to 32 bits / 768 kHz
Single-ended output power1900mW @ 32Ω
Balanced output power5300mW @ 32Ω
Total harmonic distortion (THD)⩽0,0005 %
Signal-to-noise ratio (SNR)123dB
Channels separation73dB
Frequency response20Hz - 40kHz
Dimensions238 x 59 x 188mm
Weight2.8kg
InputI2S via HDMI
OutputJack 4.4mm
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
NetworkingYes
Streaming services & Network protocolsDLNA
With the EH3, Shanling offers us an extremely versatile DAC with volume control, which can also be used as a headphone amplifier or as a streamer....
