By buying this product you get 79 loyalty points
With the EH3, Shanling offers us an extremely versatile DAC with volume control, which can also be used as a headphone amplifier or as a streamer. Indeed, in addition to its ES9039PRO DAC chip, Shanling also offers an amplification system based on four OPA1612s, and the possibility of playing audio files directly from a local server or DLNA application thanks to its Wifi connection.
At the heart of the EH3 is an ESS ES9039PRO DAC chip. This high-performance 8-channel chip, based on Hyperstream IV technology, enables the EH3 to decode up to 32bit 768kHz PCM and up to DSD512, and to do so symmetrically so as to limit the interference created by the influence of one channel on the other.
Management of USB connectivity is entrusted to an XMOS XU316 chip, enabling transparent sound reproduction while ensuring support for the above-mentioned sampling formats.
On the amplification side, this is ensured by four OPA1612s, recognized as operational amplifiers with very low noise density (1.1-nV/√Hz ) and virtually zero distortion (0.000015% at 1kHz ). As a result, Shanling's EH3 deploys power ranging from 126 mW to 1900 mW at 32 Ω unbalanced, and up to 5300 mW at 32 Ω balanced.
Shanling's EH3 offers a wide variety of inputs and outputs. Indeed, it is possible to use a wired input in coaxial, optical, USB-A, USB-B, RCA or HDMI I2S, but you also can connect to the device via Bluetooth 5.0 or link it to your local network via Wifi. Finally, the EH3 is also compatible with the Airplay protocol, so it can receive music from any Apple device.
On the output side, there are four headphone outputs on the front panel: an unbalanced 6.35mm jack output, an unbalanced 3.5mm jack output, a balanced 4.4mm jack output and a balanced 4-pins XLR output. The rear panel features an RCA output and a 3-pins XLR output, which can bypass the volume control if desired. Finally, the EH3 can be controlled remotely via Shanling's proprietary Eddict Player application.
Product type | DAC with volume Headphone Amplifier Streamer |
Connectivity | WiFi Dual Band 2.4/5Ghz Bluetooth 5.0 DLNA AirPlay |
Inputs | 1x Optical Toslink 1x Coaxial SPDIF 1x USB-B 2x USB-A 1x RCA 1x HDMI I2S |
Outputs | 1x Balanced XLR 4 pins headphone output 1x Balanced Jack 4.4mm headphone output 1x Single-ended Jack 3.5mm headphone output 1x Single-ended Jack 6.35mm headphone output 1x RCA (line-out or pre-amp) 1x XLR 3 pins (line-out or pre-amp) |
DAC Chip | ESS ES9039PRO |
Supported Bluetooth codecs | LDAC, aptX HD, aptX, AAC and SBC |
Supported sampling rates | DSD : up to DSD512 PCM : up to 32 bits / 768 kHz |
Single-ended output power | 1900 mW @ 32Ω |
Balanced output power | 5300 mW @ 32Ω |
Total harmonic distortion (THD) | ⩽ 0,0005 % |
Signal-to-noise ratio (SNR) | 123dB |
Channels separation | 73dB |
Frequency response | 20Hz - 40kHz |
Dimensions | 238 x 59 x 188 mm |
Weight | 2.8 kg |
Color | Silver |
Input | RCA |
Input | Optical |
Input | USB |
Input | SPDIF |
Input | I2S via HDMI |
Output | Jack 6.35mm |
Output | RCA |
Output | XLR |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
Class | N/A |
Networking | Yes |
Remote Control | No |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | AirPlay |
