SINGXER SA-1 V2 Headphone Amplifier
The Singxer SA-1 V2 is a complete, high-performance headphone amplifier and preamplifier based on Class A architecture and fully symmetrical discrete circuits. Version 2 of the Singxer SA-1 features an optimized circuit design for lower output impedance and greater thrust.
Reference : 18558
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 15-05-2025.
Singxer SA-1 V2 Balanced Headphone Amplifier Preamplifier Class A
Singxer SA-1 V2 picture
The Singxer SA-1 V2 is a complete, high-performance headphone amplifier and preamplifier based on Class A architecture and fully balanced discrete circuits. Version 2 of the Singxer SA-1 features an optimized circuit design for lower output impedance and greater thrust.
Singxer SA-1 V2: a completely analog headphone amplifier
Completely analog, no EMI interference caused by digital control disturbs the audio signal. ROHM input transistors ensure very low noise and excellent performance. The output stage uses multi-stage current amplification, similar to that found in a high-power amplifier. Each channel incorporates 2 pairs of ON Semiconductor 4A transistors to ensure sufficiently low internal resistance and high output power. These circuits also incorporate comprehensive protection against overcurrent, overload and short-circuit, as well as thermal protection, DC protection and turn-on time delay.
Singxer SA-1 V2 inputs and outputs
The SA-1 V2 also features a full range of connectors. Inputs include unbalanced RCA and balanced XLR. For headphone outputs, the amplifier offers balanced 4.4mm jack and 4-pole XLR, and unbalanced 6.35mm jack. On the preamplifier output side, the SA-1V2 offers an unbalanced RCA output and a balanced XLR output.
Singxer SA-1 V2: gain switch, source selection and resistance (Ohm)
To adapt to all types of headphones, whether high-sensitivity or high-impedance models, the SA-1 V2 offers gain selection (low or high) via a bipolar switch on the front panel. A second switch selects the source (RCA or XLR). A third switch selects the impedance resistance mode for headphone outputs: LOW-Z is low resistance mode, HI-Z is high resistance mode. On the preamplifier outputs, the unbalanced output impedance is 22.5 ohms and the balanced output impedance is 45 ohms.
Singxer SA-1 V2 rear panel
Singxer SA-1 V2 rear panel picture
Singxer SA-1 test by Audio Science Review (Amir)
" Clearly the Singxer SA-1 is designed using instrumentation to make sure it delivers extremely low levels of noise and distortion. While our testing is stressful enough to show a slight weakness in driving low impedance headphones, the unit is nevertheless worthy of top of the class designation in my book. "
Test du Singxer SA-1 par Audio Science Review (Amir)
Preamplifier
Amplification typeClass A
Inputs1x Balanced XLR
1x Unbalanced RCA
Outputs1x Balanced XLR
1x Unbalanced RCA
1x Balanced 4.4mm jack headphone output
1x Balanced XLR 4-pole headphone output
1x Unbalanced 6.35mm jack headphone output
THD+N-120dB @ 1kHz, A-Weighting, 20Hz - 22kHz
-96dB @ low gain, 1kHz, A-Weighting, 20Hz-22kHz
Noise level0.66µV @ Niveau de sortie max, SNR / DNR 147dB
300nV RMS @ Gain faible, A-Weighting, 20Hz-22kHz
SNR147dB
Headphone output powerBalanced output: 10000mW @ 16Ω
Balanced output: 5500mW @ 32Ω
Balanced output: 3100mW @68Ω
Balanced output: 2000mW @ 120Ω
Balanced output: 380mW @ 600Ω
Unbalanced output: 500mW @ 16Ω
Unbalanced output: 1375mW @ 32Ω
Unbalanced output: 775mW @68Ω
Unbalanced output: 500mW @ 120Ω
Unbalanced output: 95mW @ 600Ω
Gain levelsUnbalanced input, unbalanced output: low gain 0db, high gain 11db
Unbalanced input, balanced output: low gain 6 dB, high gain 17 dB
Balanced input, unbalanced output: low gain -6db, high gain 5db
Balanced input, balanced output: low gain 0db, high gain 11db
Output impedance levelsLow-impedance output impedance is 1.4 ohms (balanced) and 0.7 ohms (unbalanced).
High-impedance output impedance is 11.4 ohms (balanced) and 10.7 ohms (unbalanced)
Power supply100-240V AC, 50/60Hz
Dimensions234 x 170 x 46mm
Chassis materialAluminum
Weight1.8kg
Conditionnement1x Singxer SA-1 V2
1x Power cable
Singxer SA-1 V2 measurement dashboard
Singxer SA-1 V2 measurements
Singxer SA-1 V2 THD+N vs. frequency measurements
Singxer SA-1 Amplificateur Casque Préamplificateur Symétrique
Singxer SA-1 Balanced headphone amplifier Preamplifier
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassClass A / AB
Facilement recommandable
Bonjour
J'ai été un peu surpris que personne ne parle de cet amplificateur, alros je me lance !!
Le net est plein de revues du modele initial la "V1" mais pas la celui-ci donc je me suis lancé en espérant que ce sera aussi bon.
Coté qualité du son, ce que je peux dire en tout cas pour moi qui utilisait un monolith thx 887 depuis un bon moment , c'est qu'il y a un zest de chaleur en plus et moins de largeur de la scene sonore..
La puissance est suffisente pour ma part ( pour un hd660s et un hifiman ananda).
Ce qui est bluffant par contre c'est le silence, meme avec un iem extremement sensible aux sons parasites comme le KZ ZS10.
Il ne chauffe pas beaucoup et est très bien construit.
Donc pour moi c'est un ampli facilement recommandable auquel je ne trouve pas de defauts particuliers.
This review has been posted for SINGXER SA-1 V2 Balanced Headphone Amplifier Preamplifier Class A
The Singxer SA-1 V2 is a complete, high-performance headphone amplifier and preamplifier based on Class A architecture and fully symmetrical...
