SMSL SP200 Balanced Headphone Amplifier THX AAA-888 2x 3W 32 Ohm Black
A symmetrical headphone amplifier with exceptional performance, the SMSL SP200 has the particularity of integrating THX AAA-888 technology. The latter allows the reproduction of a sound incredibly faithful to the original signal, while offering a significant energy reserve and a very low level of crosstalk.
4.8 / 5
By buying this product you get 27 loyalty points
Reference : 14170
279,00 €tax incl.
232,50 € tax excl.
SMSL SP200
SMSL SP200 Amplificateur Casque Symétrique THX AAA-888 2x3W 32 Ohm Noir
A symmetrical headphone amplifier with exceptional performance, the SMSL SP200 has the particularity of integrating THX AAA-888 technology. The latter allows the reproduction of a sound incredibly faithful to the original signal, while offering a significant energy reserve and a very low level of crosstalk. Extremely versatile, the SP200 will be just as comfortable accompanying low impedance headphones as it is accompanying headphones with higher impedance or requiring higher current and sensitivity. Equipped with high-precision resistors for high stability and ultra-low noise power supply, the SP200 has been carefully designed for rich and detailed sound reproduction.
For its connectivity, the SP200 offers unbalanced stereo RCA and balanced XLR input. On the headphone outputs side, it offers on its front panel a 4-pole balanced XLR and an unbalanced 6.35mm jack. A switch on the front panel allows you to simply select the desired input. A second switch allows it to adjust the gain level to +6dB or +18dB.
THX AAA Technology : Achromatic Audio Amplifier
THX Achromatic Audio Amplifier technology (THX AAA™) delivers an uncompromising, ultimate headphone listening experience, delivering incredibly accurate sound with very low noise and distortion levels.
THX-AAA Features:
  • Patented feed-forward error correction topology that nulls convetional distorsion machanisms.
  • Reduction of harmonic, intermodulation, and crossover distortion by up to 40dB, resulting in a realistic and fatigue-free listening experience.
  • Enables maximum output power for greater dynamic range and sound pressure level (SPL).
SMSL SP200 review by Amir  from Audio Science Review
" THX seems to have revolutionized to high-priced headphone amplifier market. It provides a winning combination of vanishingly low distortion and tons of power. "
" Great to see a new price point also in THX amps. You can add a 100$ DAC to SP200 and still be cheaper than the other THX offerings. "
" Needless to say, it is my absolute pleasure to recommend the SMSL SP200. It makes THX headphone amplifiers more affordable and gets rid of clutter on your desk to boot. "
Test du SMSL SP200 par Audio Science Review
Amplification technologyTHX AAA-888
Inputs1x Balanced XLR
1x Single-ended RCA
Outputs1x 4 poles balanced XLR
1x Single-ended Jack 6.35mm
Power2x6W @ 16Ω
2x3W @ 32Ω
2x440mW @ 300Ω
2x220mW @ 600Ω
SNR130dB (A-Weighted)
Output noise2.8µV (A-Weighted)
THD+N-122dB, 0.00007% (1kHz, 32Ω)
-117dB, 0.00013% (20Hz - 20kHz, 32Ω, -3dB)
THD-125dB, 0.00006% (1kHz, 16Ω, -3dB)
Output impedanceNear to 0Ω
Frequency response0.1Hz - 500kHz (-3dB)
GainLow : +6dB
High : +18dB
Supply voltage100-240VAC, 50/60Hz
Consumption24W
Standby consumption< 0.1W
Dimensions160 x 149 x 73mm
Weight722g
Housing materialAlumnium
InputXLR
OutputJack 6.35mm
5 reviews
POWER and THX quality combined!
This is trully an afordable, serious piece of equipment capable of producing the cleanest of sounds with enough power to drive ANYTHING you give it.
This review has been posted for SMSL SP200 Balanced Headphone Amplifier THX AAA-888 2x 3W 32 Ohm Black
Un ampli casque étonnant
De petite taille, mais avec sa propre alimentation et des entrées XLR, une puissance étonnante permettant de dériver toute sorte de casque, une forme qui peut déplaire avec ses côtés légèrement inclinés. Vaut largement des produits 3 à 4 fois plus chers. Mérite ses 5 étoiles.
My endgame Headphone Amp for now...
Had this Headphone amp for almost for month and after week use, I can totally recommend this Amp over anything else similiar priced Amp. Using this with Khadas Tone Board and sound so clean and detailed with my Fostex T60RP headphones. Also I had grounding loop issues, which I fixed with Ifi Defender and putting Khadas to separated power source, instead of powered by My PC USB-port.
silencieux
Je m'attendais à mieux suite à ce que j'ai lu sur différent forum . Silencieux : oui
puissant : non
champ sonore rétrécit
je l'utilise avec un plenue L avec casque Denon AH-D9200 qui est que 24 ohms et mon plenue L à un champ sonore plus large et surtout plus puissant .
Car au-delà de la moitié de son volume il commence à crier plutôt que d'assurer ...
Pour amplifier un smartphone çà va .
mais son son est propre , pas de distorsion , quand même agréable mais pas audiophile car même le plenue L avec le casque Denon n'est pas audiophile . Ne vous fier jamais à ce que les gens comme moi puisse dire , essayé là si vous le pouvez . Valable pour tous les matériels .
Strong uncolored beast!
Very capable to drive youre headphones easily.. Cant found anything cons here! I totally rec this amp! Tested with Sennheiser HD 800 and low gain!
A symmetrical headphone amplifier with exceptional performance, the SMSL SP200 has the particularity of integrating THX AAA-888 technology. The...
