TOPPING L70 Balanced NFCA Headphone Amplifier / Preamplifier Black
With the L70, Topping offers a highly engineered balanced NFCA headphone amplifier and preamplifier combo that delivers excellent sonic performance and is suitable for a wide range of use scenarios. Whether you are using demanding headphones, high sensitivity IEMs, or pairing with a power amplifier, the L70 is the ideal ally for pure, rich, dynamic listening.
By buying this product you get 27 loyalty points
Reference : 16950
279,00 €tax incl.
232,50 € tax excl.
Last items in stock !
Shipping date: 02-10-2025.
Topping L70
Topping L70 Amplificateur Casque NFCA / Préamplificateur Symétrique Noir
L70
L50
L30 II
A30 Pro
A90 Discrete
Structure
Balanced
Single-ended
Single-ended
Single-ended
Balanced
Amplifier
NFCA
NFCA
NFCA
NFCA
Discrete NFCA
Inputs
Single-ended + Balanced
Single-ended
Outputs
Jack 6.35mm
Jack 4.4mm
XLR 4 pins
Jack 6.35mm
XLR 4 pins
Jack 6.35mm
Jack 6.35mm
Jack 4.4mm
XLR 4 pins
Jack 6.35mm
Jack 4.4 mm
XLR 4 pins
Preamplifier
Yes
No
Yes
No
Yes
Smart independent outputs
Yes
No
No
No
No
Bypass
No
Yes
No
Yes
No
Gain
Single-ended output : 0/13.8dB
Balanced output : 6/19.8dB
-14 / 0 / 14dB
-14 / 0 / 16.5dB
-14 / 0 / 14dB
Single-ended output : 0/9.5dB
Balanced output : 6/15.5dB
Single-ended output power
2* 3500mW (16 Ohm)
2* 3400mW (16 Ohm)
2* 3500mW (16 Ohm)
2* 6000mW (16 Ohm)
2* 3300mW (16 Ohm)
Puissance symétrique
2* 6000mW (16 Ohm)
2* 9800mW (16 Ohm)
Impédance sortie asymétrique
< 0.1 Ohm
< 0.1 Ohm
< 0.1 Ohm
< 0.1 Ohm
< 0.1 Ohm
High performance NFCA amplifier modules
The L70 uses the same NFCA (Nested Feedback Composite Amplifier) module as the A90. Its hybrid voltage/current feedback architecture combined with UHGF (Ultra High Gain Feedback) technology offers excellent DC and AC performance, extremely low THD+N and an incredibly high dynamic range of 146dB. In addition, the L70 has a high output current and a very low output impedance and noise level, allowing it to drive the vast majority of headphones on the market, including the most demanding models.
Multiple headphone outputs
The L70 is compatible with most headphone connectors. It integrates a balanced XLR 4 pins, a balanced 4.4mm jack and an single-ended 6.35mm jack. The on-board balanced amplifier circuitry is suitable for both balanced and single-ended headphones. In addition, its high output voltage and current as well as its low output impedance allow it to accompany sensitive headphones and high-impedance headphones without difficulty.
Two levels of gain
The Topping L70 provides two levels of gain to cover most needs of different headphones.
Single-ended output : Low gain : 6.0dB / High gain : 19.8dB
Balanced output : Low gain : 0dB / High gain : 13.8dB
Preamplifier function
The L70 is not only capable of driving headphones but can also be used as a preamplifier. In this mode you get the same performance as with the headphone amplifier and the single-ended 20Ω and balanced 40Ω output impedances allow compatibility with many amplifiers. In addition, the L70 comes with a remote control for convenient control.
Custom volume control
Using an R2R volume control composed of relays and a resistor network, the L70 ensures a precise adjustment, a great durability and a perfect balancing of the channels. It also incorporates a memory for the volume and gain level according to 8 profiles that can be customized according to the connected equipment.
Ground loop eliminator
A ground loop can occur when multiple devices are used together. The L70 has a GND/LIFT switch to solve this problem. In normal use, simply set it to the GND position. When a ground loop is encountered, select LIFT mode to eliminate the ground loop.
12V Trigger
The L70 integrates a 12V trigger with active (trigger output) and passive (trigger input) control. With only a simple 3.5mm jack cable, the Topping L70 can be switched on and off in sync with your other equipment with a 12V trigger interface.
1ON-OFF / Input selector button
2Balanced XLR 4 pins headphone output
3Balanced Jack 4.4mm headphone output
4Single-ended Jack 6.35mm headphone output
5Volume button
6Single-ended stereo XLR / Jack 6.35mm combo input
7Single-ended stereo RCA input
8Single-ended stereo RCA output
9Balanced stereo XLR output
1012V Trigger input
1112V Trigger output
12Ground loop elimination switch
13Firmware update port
14Power connector
15Power switch
Preamplifier
Inputs1x Balanced stereo Jack 6.35mm / XLR combo
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
1x Balanced XLR 4 pins headphone output
1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 6.35mm headphone output
AmplifierNFCA
Headphone amplifier measurements
SE IN / SE OUTBAL IN / SE OUTSE IN / BAL OUTBAL IN / BAL OUT
THD+N @ 1kHz (A-wt)< 0.00006% @ 500mW, 32Ω
< 0.000055% @ 80mW, 300Ω
< 0.00007% @ 500mW, 32Ω
< 0.000065% @ 80mW, 300Ω
< 0.00006% @ 2000mW, 32Ω
< 0.000055% @ 320mW, 300Ω
< 0.00007% @ 2000mW, 32Ω
< 0.000065% @ 320mW, 300Ω
THD @ 20Hz-20kHz (90kBw)< 0.00008% @ 500mW, 32Ω
< 0.00007% @ 80mW, 300Ω
< 0.00015% @ 500mW, 32Ω
< 0.00015% @ 80mW, 300Ω
< 0.00009% @ 2000mW, 32Ω
< 0.00008% @ 320mW, 300Ω
< 0.0002% @ 2000mW, 32Ω
< 0.00015% @ 320mW, 300Ω
SNR @ Max Out, 1kHz (A-wt)143dB138dB146dB139dB
Dynamic range @ 1kHz (A-wt)143dB138dB146dB139dB
Frequency response10Hz-100kHz (±0.1dB)10Hz-100kHz (±0.5dB)10Hz-100kHz (±0.1dB)10Hz-100kHz (±0.5dB)
Output level26vpp26Vpp52Vpp52Vpp
AP Measured noise level (A-wt)< 0.7µVrms @ G=L
< 1.2µVrms @ G=H
< 0.7µVrms @ G=L
< 1.2µVrms @ G=H
< 0.9µVrms @ G=L
< 2.2µVrms @ G=H
< 0.9µVrms @ G=L
< 2.2µVrms @ G=H
Effective noise level* (A-wt)< 0.3µVrms @ G=L
< 1.1µVrms @ G=H
< 0.3µVrms @ G=L
< 1.1µVrms @ G=H
< 0.7µVrms @ G=L
< 2.2µVrms @ G=H
< 0.4µVrms @ G=L
< 2.2µVrms @ G=H
Crosstalk @ 1kHz-104dB-104dB-120dB-120dB
Input sensitivity9.6Vrms @ G=L
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
Gain0dB @ G=L
13.8dB @ G=H
0dB @ G=L
13.8dB @ G=H
6dB @ G=L
19.8dB @ G=H
6dB @ G=L
19.8dB @ G=H
Output impedance< 0.1Ω< 0.1Ω< 0.2Ω< 0.2Ω
Output power2* 3500mW @ 16Ω, THD+N < 0.1%
2* 2300mW @ 32Ω, THD+N < 0.1%
2* 1200mW @ 64Ω, THD+N < 0.1%
2* 290mW @ 300Ω, THD+N < 0.1%
2* 6000mW @ 16Ω, THD+N < 0.1%
2* 7500mW @ 32Ω, THD+N < 0.1%
2* 4700mW @ 64Ω, THD+N < 0.1%
2* 1150mW @ 300Ω, THD+N < 0.1%
2* 600mW @ 600Ω, THD+N < 0.1%
Load impedance> 8Ω
Preamplifier measurements
THD+N @ 1kHz (A-wt)< 0.000055%< 0.00006%< 0.000055%< 0.00006%
THD @ 20Hz-20kHz (90kBw)< 0.00007%< 0.00015%< 0.00008%< 0.00015%
SNR @ 1kHz (A-wt)143dB138dB146dB139dB
< 1.2µVrms @ G=H
< 0.7µVrms @ G=L
< 1.2µVrms @ G=H
< 0.9µVrms @ G=L
< 2.2µVrms @ G=H
< 0.9µVrms @ G=L
< 2.2µVrms @ G=H
< 1.1µVrms @ G=H
< 0.3µVrms @ G=L
< 1.1µVrms @ G=H
< 0.7µVrms @ G=L
< 2.2µVrms @ G=H
< 0.4µVrms @ G=L
< 2.2µVrms @ G=H
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
9.6Vrms @ G=L
1.9Vrms @ G=H
Gain0dB @ G=L
13.8dB @ G=H
0dB @ G=L
13.8dB @ G=H
6dB @ G=L
19.8dB @ G=H
6dB @ G=L
19.8dB @ G=H
Output impedance20Ω20Ω40Ω40Ω
*The effective noise level is obtained by boosting the noise of the L70 by 40dB using a low noise amplifier before the APx555B then dividing the measured noise by 100.
Dimensions200*138*44mm
Package1x Topping L70
1x Remote control
1x Jack 6.35mm to Jack 3.5mm adapter
1x Power cable
InputJack 6.35mm
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
Remote ControlYes
Topping L70
Very fine pre amp...
This review has been posted for TOPPING L70 Balanced NFCA Headphone Amplifier / Preamplifier Black
With the L70, Topping offers a highly engineered balanced NFCA headphone amplifier and preamplifier combo that delivers excellent sonic performance...
