XDUOO MT-602 Tube Headphone Amplifier Class A 2x 6J1
The xDuoo MT-602 is a compact, high-performance and affordable headphone amplifier. It is based on a Class A architecture, integrating transistors for its buffer and two 6J1 tubes for its preamplification stage, offering a beautiful musicality. Where the tubes bring a certain warmth and softness, the transistors offer them a beautiful dynamics and precision.
4.5 / 5
Reference : 15034
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 06-05-2025.
xDuoo MT-602
xDuoo MT-602 Amplificateur Casque à Tubes Class A 2x 6J1
Able to develop a power of 1300mW under 32Ω, it will be able to accompany high-sensitivity earphones as well as headphones with high impedance.
The MT-602 has a stereo RCA and a 3.5mm jack as inputs. On the output side, the front panel offers 6.35mm and 3.5mm jacks for headphone outputs, as well as an auxiliary output on stereo RCA on the rear panel. This last one allows to use the MT-602 as a preamplifier.
The MT-602 has been carefully designed and equipped with high quality components such as ELNA coupling capacitors and Rubycon filter capacitors. All connectors are gold plated.
Amplification typeTubes
Class A
Inputs1x Stereo RCA
1x Jack 3.5mm
Outputs1x Jack 6.35mm headphone output
1x Jack 3.5mm headphone output
1x Stereo RCA
Tubes2x 6J1
Output ppower1300mW @ 32Ω
THD+N≤ 0.1% @ 1kHz, 32Ω
Frequency response10Hz - 60kHz (±0.5dB)
Recommended headphone impedance16-600Ω
Gain+15dB
SNR115dB
Power supply12V DC 1A
Dimensions120 x 78 x 40mm
Weight380g
InputJack 3.5mm
OutputJack 6.35mm
OutputJack 3.5mm
ColorGray
ClassTube amp
ClassClass A / AB
4 reviews
UTILISATION PREAMPLI
BON PREAMPLI ENTRE UN DAC SMSL DO100 ET UN AMPLI AIYIMA A07 PRO AVEC AOP MUSES02 ET SPARKOS.
LE GAIN EN SORTIE EST ENORME PAR RAPPORT AU GAIN DU DAC J' AI MIS DU TUBE VOSHKOD DESSUS ET LES DETAIL ET LA DYNAMIQUE SONT AU RENDEZ VOUS.
J'AI FAIT DES TEST AVEC ET SANS CE PREAMPLI ET C'EST LE JOUR ET LA NUIT.
JE RECOMMANDE VIVEMENT CET APPAREIL !
This review has been posted for XDUOO MT-602 Tube Headphone Amplifier Class A 2x 6J1
Bon et élégant petit préampli
Un bon et élégant petit préampli (c'est comme ça que je l'utilise). Le son est propre, clair, détaillé. Cependant il est moins "tuby" que d'autres preamp, comme le Tube 03 de FX Audio. Pour le "roulement de tube", les tubes installés dépassent peu, et sont un peu difficiles à retirer cependant (actuellement j'utilise des Sylvania des années 60).
Very compact, powerful and smooth hybrid class A amp
I have a few headphone amps; some for clarity and details (THX789, Topping A90, ...) and some for richness and warmth - including class A ones (RebelAmp), OTL tube amps (DarkVoice) and hybrids (SMSL T1, Loxjie P20). This MT602 is a very nice addition to the collection. It provides a nice tuby warmth with some smoothness but does not loose in clarity and punchiness. Despite its very small size, the amp is very powerful and drives some demanding headphones quite well. As a hybrid, it is also quite nice for my planar headphones. It works also very well as a pre-amp in the chain. The build feels like quality. In total, the amp is absolutely worth its price.
I exchanged the two Chinese 6J1 tubes (which are not bad) with GE5654s and VOSKHOD 6J1P-EVs. I prefer the Voskhod ones since I feel the bass is more defined with them. Only small issue is that the switch-on delay is not working equally on both channels.
Belle construction de qualité apparente mais ou sont les radiateus qu'impose une class A
L'usage de FET aurait préférable aux transitors cela se ressent dans les écoutes la chaleur des lampes semble estompée
Class A tout de mème
Attention ce n'est qu'un ressenti personnel
The xDuoo MT-602 is a compact, high-performance and affordable headphone amplifier. It is based on a Class A architecture, integrating transistors...
