Sonido ce calidad
By buying this product you get 59 loyalty points
Please note that this device is not suitable for low-impedance headphones and IEMs.
DAC Amplificateur Casque à Tubes ES9038Q2M XMOS XU208 Bluetooth 5.0
The xDuoo TA-30 is a high-performance tube and DAC headphone amplifier combo, offering rich and detailed sound reproduction. Its headphone output amplified by a pair of power tubes is capable of developing a consequent power of 3000mW, allowing to accompany the vast majority of headphones on the market.
The digital/analogue conversion section is entrusted to a DAC ES9038Q2M chip, efficiently processing and converting the signal for the most transparent reproduction possible. This chip also supports high sample rates up to 32bit 768kHz PCM and DSD512.
The TA-30 offers a complete connectivity allowing it to be integrated into many audio systems. The TA-30 offers Coaxial, Optical, USB-B and Bluetooth 5.0 inputs. The SPDIF inputs are combined with an AKM AK4118 receiver supporting PCM sample rates up to 24bit 192kHz and DSD64 (DoP). The USB input uses a high-performance XMOS XU208 interface that can read PCM files up to 32bit 768kHz, DSD up to DSD512 and DXD up to 32bit 384kHz. The onboard Bluetooth chip supports the aptX HD and LDAC codecs, enabling high quality remote transmission.
On the output side, the TA-30 offers an amplified headphone output on the front panel on a 6.35mm jack connector and two stereo RCA outputs on the rear panel.
The xDuoo TA-30 is equipped with a Qualcomm CSR8675 Bluetooth 5.0 receiver chip. This high quality chip enables fast and stable remote broadcasting of your audio stream. The chip supports the aptX, aptX HD, aptX LL and LDAC codecs, providing near or better than CD quality playback.
This amplifier integrates 3 tubes. The first one, a 5Z3P tube serves as a high voltage rectifier, where the two others, ECC82, allow to process and amplify the audio signal. These tubes ensure a rich reproduction marked by a signature peculiar to tube devices.
The TA-30 uses two active oscillators with low phase noise, enabling highly accurate digital-to-analog conversion at any sampling rate.
A CPLD is directly associated with these clocks, processing the data and allowing an efficient synchronization of the clocks in order to reduce jitter as much as possible.
The coupling is ensured by custom polyester metal film capacitors and ELNA SILMIC (II) capacitors for a transparent and soft restitution.
Japanese Nichicon FW(M) capacitors are used for filtering, providing a soft and warm sound and excellent high-frequency reproduction.
The ES9038Q2M DAC for digital-to-analog conversion offers excellent audio performance, thanks in particular to its Time Domain Jitter Eliminator technology delivering a dynamic range of 129dB and a THD+N of -120dB. The DAC also incorporates 7 PCM filters and 1 DSD filter.
Product type | DAC Headphone tube amplifier |
DAC Chip | ES9038Q2M |
USB interface chip | XMOS XU208 |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial SPDIF Bluetooth 5.0 |
Outputs | 1x Jack 6.35mm headphone output 2x Stereo RCA |
Screen | OLED 1.3" |
System compatibility | Windows 7, 8, 10 Mac OS X Android |
Output power | 3000mW (32Ω) |
Frequency response | USB, Optical, Coaxial, Bluetooth : 20Hz - 20kHz (±0.5dB) Amplified output : 10Hz - 100kHz (± 0.5dB) |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DXD up to 32bit 384kHz, DSD up to DSD512 Optical, Coaxial : PCM up to 24bit 192kHz, DSD64 (DoP) |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, aptX LL, LDAC |
THD+N | 0.5% @ 1kHz |
SNR | 110dB (A-Weighted) |
Crosstalk | ≥ 65dB |
Case material | Aluminium |
Dimensions | 29 x 11 x 17cm |
Weight | 3kg |
Color | Black |
Package | 1x xDuoo TA-30 1x Power cable 1x USB cable 1x Bluetooth antenna 1x Jack 6.35mm adapter |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Class | Tube amp |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
