XDUOO XA-02 Balanced DAC Headphone Amplifier
The xDuoo XA-02 is a high-performance DAC and headphone amplifier based on audiophile components. It features an ESS ES9039Q2M DAC chip that supports sampling rates up to PCM 32bit 384kHz, native DSD up to DSD256 and MQAx8. It also features a Class A headphone amplifier circuit and a balanced headphone output capable of delivering an output power of up to 2000mW.
Reference : 19860
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 13-06-2025.
xDuoo XA-02 Balanced DAC Headphone Amplifier Bluetooth AptX HD LDAC ES9039Q2MPCM 32bit 384kHz DSD256 MQA
Photo du xDuoo XA-02
The xDuoo XA-02 is a high-performance DAC and headphone amplifier based on audiophile components. It features an ESS ES9039Q2M DAC chip that supports sampling rates up to PCM 32bit 384kHz, native DSD up to DSD256 and MQAx8. It also features a Class A headphone amplifier circuit and a balanced headphone output capable of delivering an output power of up to 2000mW. It also has Bluetooth functionality, enabling it to support the high-definition codecs aptX, aptX LL, aptx HD and LDAC for reliable, stable wireless transmission. As for connectivity, there's a USB-C input, a coaxial input and a Toslink optical input, while on the output side there's an RCA line output and, of course, two headphone outputs on the front panel: unbalanced 6.35mm jack and balanced 4.4mm jack. An attractive 1.3-inch OLED display and a digital volume control complete the package.
xDuoo XA-02: ES9039Q2M DAC and XMOS XU316 USB interface
The xDuoo XA-02 supports sampling rates up to PCM 32bit 384kHz and DSD256 via its USB-C input, thanks to its XMOS XU316 + ES9039Q2M chips. It also supports MQAx8. This Hi-Fi device therefore offers the possibility of enjoying high-resolution audio files for the most enjoyable listening experience.
Photo de la puce DAC ES9039Q2M
Puissance de sortie du xDuoo XA-02
xDuoo XA-02: a high-performance headphone amplifier
The XA-02 headphone amplifier DAC features a Class A amplifier circuit based on transistors. This enables it to develop power of up to 910mw on its 6.35mm jack headphone output and up to 2000mw on its balanced 4.4mm jack headphone output. This means it can drive a wide range of headphones, from 16 ohm to 600 ohm impedance.
xDuoo XA-02: balanced architecture
The XA-02 benefits from a balanced architecture that considerably reduces the noise level at its RCA line and headphone outputs. This is reflected in its performance, with a THD+N announced at 0.0005%, an SNR of 121dB and a crosstalk level of 118dB.
Photo de l'architecture du xDuoo XA-02
xDuoo XA-02: Bluetooth HD
The modern XA-02 features Bluetooth functionality, thanks to a Qualcomm QCC5125 chip that supports wireless transmission of high-definition codecs: aptX, aptX LL, aptX HD and LDAC. The result is reliable, stable wireless transmission.
Fonctionnalité Bluetooth du xDuoo XA-02
xDuoo XA-02: digital volume control and OLED display
The front panel of the XA-02 features an attractive 1.3” OLED display showing various operating mode information. In addition, a large red backlit potentiometer controls the output volume. The XA-02's volume control is digital. This avoids any problems of imbalance in the event of low volume.
Photo de l'écran et du potentiomètre du xDuoo XA-02
xDuoo XA-02 overview
Aperçu du xDuoo XA-02
1Single-ended jack 6.35mm headphone output
2Balanced jack 4.4mm headphone output
3OLED display
4Menu access button
5Bluetooth pairing button
6Volume control/Source selection/Navigation
7Stereo RCA output
8Coaxial input
9Optical input
10USB-C input
11Update port
12Bluetooth antenna
13IEC power supply/Power switch
Tachnical characteristics
Product typeDAC / Headphone amplifier
DAC chipES9039Q2M
USB interfaceXMOS XU316
Bluetooth chipQCC5125
Inputs1x USB-C input
1x Toslink optical input
1x Coaxial input
Bluetooth
Outputs1x RCA line output
1x Jack 6.35mm single-ended headphone output
1x Jack 4.4mm balanced headphone output
Supported sample ratesUSB: PCM up to 32bit 384kHz, DSD256, MQAx8
Optical and coaxial: PCM up to 24Bit 192kHz, DSD DoP64
Supported Bluetooth codecs SBC, AAC, aptX, aptX LL, aptX HD, LDAC
System compatibilityWindows, Linux, Mac OS X, IOS, Android system
DisplayOLED 1.3"
Recommended headphone impedance16-600 ohm
Jack 6.35mm single-ended headphone output specifications
Output power910mw @ 32 ohm
Frequency response20Hz-60kHz (±0.5dB)
Crosstalk≥ 71dB
SNR119dB (A-Weighted)
THD+N0.002%
Jack 4.4mm balanced headphone output specifications
Output power2000mW @ 32 ohm
Crosstalk≥ 118dB
SNR121dB (A-Weighted)
THD+N0.0004%
RCA line output specification (AUX)
Output level2.6Vrms
Crosstalk≥ 118dB
THD+N≤ 0.0004%
Power supply100-240V AC
Dimensions200 × 175 × 47mm
Weight0.9kg
ColorGrey
Package1x xDuoo XA-02
1x Mains power cable
1x Bluetooth antenna
1x USB-C cable
1x 3.5mm jack to 6.35mm jack adapter
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorGray
ClassClass A / AB
XDUOO XA-02 Balanced DAC Headphone Amplifier Bluetooth AptX HD LDAC ES9039Q2MPCM 32bit 384kHz DSD256 MQA
The xDuoo XA-02 is a high-performance DAC and headphone amplifier based on audiophile components. It features an ESS ES9039Q2M DAC chip that...
