RME ADI-2 PRO FS R BLACK EDITION ADC DAC Headphone Amplifier Balanced SteadyClock FS 768kHz DSD256
The ADC / DAC RME ADI-2 Pro FS R Black Edition is the combination of several professional quality devices in a single package. An extremely compact unit with great functionality, excellent technical performance, clear and transparent sound reproduction and two extremely powerful headphone outputs.
By buying this product you get 199 loyalty points
Reference : 14587
1 999,00 €tax incl.
1 665,83 € tax excl.
RME ADI-2 Pro FS R BLACK EDITION
RME ADI-2 Pro FS R BLACK EDITION DAC ADC Amplificateur Casque Symétrique SteadyClock FS 768kHz DSD256
The ADC / DAC RME ADI-2 Pro FS R Black Edition is the combination of several professional quality devices in a single package. An extremely compact unit with great functionality, excellent technical performance, clear and transparent sound reproduction and two extremely powerful headphone outputs. The ADI-2 Pro FS R Black Edition includes an AK4493 conversion chip and a handy remote control for remote control of the device.
The RME ADI-2 Pro FS R Black Edition in a few key points:
  • A professional quality AD (ADC) / DA (DAC) converter
  • A dual high-end headphone amplifier
  • An extremely versatile USB DAC
  • An ADC / DAC and headphone amplifier with iPad / iPhone compatibility
  • A multi-format converter (AES, SPDIF, ADAT) with monitoring function
  • A DSD recording and playback solution
  • A converter supporting sampling rates up to 768kHz
Very High Fidelity
Extremely versatile, the ADI-2 Pro FS R Black Edition offers balanced and unbalanced inputs and outputs, two Extreme Power headphone outputs, a SteadyClock III, hardware input and output level control, DSP-based signal processing, external power supply, USB input and support for sampling rates up to 768kHz in PCM and DSD recording and playback up to DSD256 (11.2MHz).
Analog or Digital
The ADI-2 Pro FS R Black Edition features two servo-symmetric analog inputs on XLR / Jack 6.35mm TRS combo connectors, two separate balanced and unbalanced outputs on XLR and Jack 6.35mm TS, two Extreme Power stereo headphone outputs on the front panel and an ADAT-compatible optical SPDIF input/output. The device also includes SPDIF Coaxial (RCA) and AES input/output (XLR) via a 9-pin splitter cable provided. This complete panel of inputs and outputs allows this ADI-2 Pro FS R Black Edition an impressive flexibility of use.
The USB-B 2.0 port offers full compatibility (UAC 2), including the ability to connect iOS devices. This USB port also allows you to update the device's firmware. The ADI-2 Pro FS R Black Edition uses an external switched-mode power supply with lockable connector but can also be powered by a battery for mobile use.
As a computer interface, the ADI-2 Pro FS R Black Edition offers a stereo mode (2 inputs / 2 outputs) and a multi-channel mode (6 inputs / 8 outputs). Mac OS X compatibility is native. On Windows, simply install the RME MADIface drivers for full ASIO and WDM compatibility.
Perfect Capture and Restitution
Aiming for the most neutral and faithful sound possible, every detail of the ADI-2 Pro FS R Black Edition has been designed and adjusted. The main PCB has a 10-layer design with copper circuits, guaranteeing undisturbed sound and allowing efficient power supply to the different stages. Internal power stages and high-precision controllers use a very low-noise design to avoid degrading performance on the power rails. The selected SoundPlus operational amplifiers maintain high SNR, low THD and high scanning speed in all situations. The entire analog circuit is symmetrical, balanced and DC coupled. The only capacitors in the signal path provide DC protection at the analog input connectors and have been carefully selected to avoid any impact on the sound.
The 4-channel Analog-to-Digital (ADC) converter, supporting 768kHz PCM and DSD recording, is used in a dual mono design with an improved signal-to-noise ratio of 3dB. Two premium DACs are used for two separate stereo outputs. Internal audio processing using equalizers, crossfeed and spectrum analysis is provided by a high-performance 2.17 Giga FLOPS (2882 MIPS) DSP, delivering enough computing power to operate even at sampling rates of 768kHz.
For ease of use, a high quality SRC (Sample Rate Converter) chip has been added, switchable to AES or SPDIF inputs, eliminating any potential clock problems. The latest version of RME clock technology, SteadyClock III, ensures perfect jitter reduction and a stable clock signal, whether you use internal or external clocks.
RME ADI-2 Pro FS DAC ADC Amplificateur Casque Symétrique SteadyClock FS 768kHz DSD256
High Definition Screen
RME has integrated into its ADI-2 Pro FS R Black Edition many unique features not available on other devices on the market, such as a 5-band parametric equalizer, bass/treble level control with quick access, binaural crossfeed, adjustable loudness filter, selectable ADC/DAC filters, 4 discrete I/O levels, automatic reference level adjustment, automatic balance mode and much more. The display not only allows you to check the device, but also displays warnings and advice.
Professional features are also available, such as Mid/Side processing, stereo width and phase inversion management to full control and storage of all available parameters, such as the RME spectrum analyzer, a 30-band biquad filtered analysis tool that provides a perfect complement to the high resolution IPS display.
Extreme Power Headphone Outputs
RME engineers have designed a headphone output stage to take full advantage of the DAC conversion quality, including the use of low impedance headphones. The Extreme Power architecture allows an output impedance of only 0.1Ω, a maximum output level of +22dBu and an output power of 1.5W per channel. The two completely separate headphone outputs provide an SNR of 120dBA and a THD well below -100dB (0.001%) even at full power for detailed, accurate and clear reproduction. Extreme Power technology also includes a current limiter, power monitoring, overload detection and overvoltage protection. High or low power modes are also available, allowing the ADI-2 Pro FS R Black Edition to work with both IEMs and planar headsets.
With 2 stereo headphone outputs, the ADI-2 Pro FS R Black Edition can also be used in balanced mode. RME has developed a new advanced symmetric operating mode for the ADI-2 Pro, eliminating many of the limitations of a standard symmetric link. This advanced balanced mode delivers a balanced signal directly from the DAC to the headphone outputs with a 3dB gain at the SNR, an optimized frequency response, an extremely low output impedance (0.2Ω) and a maximum output level of +28dBu.
High Performance Conversion
The ADI-2 Pro is the reference ADC/DAC converter, USB DAC, USB interface and RME headphone amplifier. Its many application possibilities make it an excellent choice for a wide variety of applications, whether it is for the individual who appreciates innovative and high quality solutions, the sound engineer looking for a reference ADC/DAC converter or the audiophile looking for a flexible solution that integrates a high-end headphone amplifier.
Femtosecond Clocks
With the SteadyClock FS, the ADI-2 Pro FS R Black Edition incorporates the latest RME clock and jitter reduction technology. Based on a femtosecond clock, SteadyClock FS technology reduces the jitter of the ADI-2 Pro FS R Black Edition to an extremely low level.
The ADI-2 Pro FS R Black Edition also integrates the AutoDark Mode of the ADI-2 DAC. It is thus possible to deactivate the lighting elements of the device if necessary, with the exception of the ON/OFF button, whose lighting makes it possible, particularly for use in the studio, to always know whether the device is in operation or not.
Remote control
The ADI-2 Pro FS R Black Edition is delivered with a remote control to control the unit remotely. It includes functions such as turning the ADI-2 Pro FS R Black Edition on and off, volume adjustment, bass, midrange and treble control, source selection (optical, coaxial, USB), activation or deactivation of Mute, Loudness and EQ modes. In addition, four programmable buttons provide access to 52 different functions for maximum flexibility.
RME ADI-2 PRO FS R BLACK EDITION ADC DAC Amplificateur Casque Symétrique SteadyClock FS 768kHz DSD256
Product typeADC / DAC
Analog inputsBalanced XLR (same connectors as Jack 6.35mm)
Balanced TRS Jack 6.35mm (same connectors as XLR)
Analog outputsBalanced XLR
Single-ended TS Jack 6.35mm
TRS Jack 6.35mm headphone output (can operate in balanced or single-ended mode)
Digital inputs1x Optical Toslink
Digital outputs1x SPDIF Optical Toslink (ADAT compatible)
Digital inputs/ outputsSPDIF Optical and XLR AES-3 (via included BO968 digital splitter cable)
Analog input : XLR
Servo-Balanced
Adjustable input sensitiviy+24dBu
+19dBu
+13dBu
+4dBu @ 0dBfs
SNR@ +13/19/24dBu : 120.xdB RMS unweighted, 124.xdBA
@ +4dBU : 119dB RMS unweighted, 123dBA
Frequency response@ 44.1kHz, -0.1dB : 5Hz - 20.5kHz
@ 96kHz, -0.5dB : 3Hz - 45.5kHz
@ 192kHz, -1dB : 2Hz - 92.7kHz
@ 384kHz, -1dB : < 1Hz - 124kHz
@ 768kHz, -3dB : < 1Hz - 180kHz
THD@ -1dBFS : -116dB, 0.00016%
@ -10dBFS : -125dB, 0.000056%
THD+N @ -1dBFS-112dB, 0.00025%
Channel separation> 110dB
Analog input : Jack 6.35mm TRS
Servo-Balanced
Adjustable input sensitivity+24dBu
+19dBu
+13dBu
+4dBu @ 0dBfs
THD @ -1dBFS-116dB, 0.00016%
TS and RCA compatible
Analog output : XLR
Adjustable output sensitivity+24dBu
+19dBu
+13dBu
+4dBu @ 0dBfs
SNR@ +13/19/24dBu : 120dB RMS unweighted, 124dBA
@ +4dBU : 117dB RMS unweighted, 120dBA
Frequency response@ 44.1kHz, -0.1dB : 0Hz - 20.2kHz
@ 96kHz, -0.5dB : 0Hz - 44.9kHz
@ 192kHz, -1dB : 0Hz - 88kHz
@ 384kHz, -1dB : 0Hz - 115kHz
@ 768kHz, -3dB : 0Hz - 109kHz
THD@ 0dBFS : -120dB, 0.0001%
THD+N@ 0dBFS : -115dB, 0.00018%
Output impedanceBalanced : 200Ω
Single-ended : 100Ω
Analog output : Jack 6.35mm TS (Single-ended)
+19dBu
+13dBu
+4dBu @ 0dBfs
Max. output level+19dBu
SNR@ +19dBu : 120dB RMS unweighted, 123dBA
@ +13dBu : 118dB RMS unweighted, 121dBA
@ +4dBu : 115dB RMS unweighted, 118dBA
Output impedance100Ω
Analog output : Headphone output 1/2 Jack 6.35mm TRS (Single-ended)
+19dBu
+13dBu
+4dBu @ 0dBFS
Max Power@ 0.001% THD : 1.5W per channel
Output level@ 0dBFS, reference level +19dBu, load 100Ω or up : +22dBu (10V)
@ 0dBFS, reference level +4dBu, load 8Ω or up : +7dBu (1.73V)
SNR@ +22dBu : 120dB RMS unweighted, 123dBA
@ +7dBu : 118dB RMS unweighted, 121dBA
THD@ +18dBu, load 32Ω, 1.2W : -110dB, 0.0003%
@ +14dBu, load 16Ω, 0.94W : -110dB, 0.0003%
THD+N@ +18dBu, load 32Ω : -107dB, 0.00045%
Output impedance0.1Ω
Analog output : Headphone output 3/4 Jack 6.35mm TRS (Single-ended)
+19dBu
+13dBu
+4dBu @ 0dBfs
Output level@ 0dBFS, Hi-Power Off : +7dBu
@ 0dBFS, Hi-Power On : +22dBu
SNR@ +22dBu : 117dB RMS unweighted, 120dBA
@ +7dBu : 114dB RMS unweighted, 118dBA
THD+N @ +18dBu load 32Ω-107dB, 0.00045%
Analog output : Balanced Mode Headphone Output
+19dBu
+13dBu
+4dBu @ 0dBfs
Output level@ 0dBFS, Hi-Power On, load 150 Ohm or up : +28dBu (19.5V)
@ 0dBFS, Hi-Power Off, load 8 Ohm or up : +13dBu (3.46V)
SNR@ +28dBu : 123dB RMS unweighted, 126dBA
@ +13dBu : 121dB RMS unweighted, 125dBA
THD+N @ +18dBu charge 32Ω-107dB, 0.00045%
Output impedance0.2Ω
Max power @ 0.001% THD2x 2.9W
Digital inputs : General
Lock range28kHz - 200kHz
Jitter suppression> 50dB (2.4kHz)
9 Pins connector compatibility (via included BO968 cable)AES/EBU
1x Galvanically isolated balanced XLR (AES3-1992)
SPDIF (IEC 60958)
ClocksInternal
AES input
SPDIF inpu
ADAT input
External clocks jitter suppression> 50dB (2.4kHz)
External clocks supported sampling rates28kHz up to 200kHz
Internal clocks44.1kHz up to 768kHz
Digital input : SPDIF Coaxial (via included BO968 cable)
Connector1x RCA
Balanced
IEC 60958 compliantAES/EBU Compatible (AES3-1992)
AES/EBU compliantAES3-1992
Digital input : SPDIF Optical
Connector1x Optical
IEC 60958 compliant
ADAT Compatible
Digital output : AES/EBU (via included BO968 cable)
Connector1x Galvanically isolated balanced XLR
AES3-1992 compliant
Sampling rate28kHz - 200kHz
Digital output : SPDIF Coaxial (via included BO968 cable)
Connector1x RCA
IEC 60958 compliant
Digital output : SPDIF Optical
Connector1x Optical
IEC 60958 compliant
Power supply (included)100-240V AC, 2A, 24W
Standby consumption50mW
Max. consumption22W
Dimensions215 x 130mm x 44mm
ColorSilver and black
Package1x RME ADI-2 Pro FS R Black Edition
1x Alimentation
1x Télécommande
1x Câble BO968 Digital Breakout (9 pins D-sub vers 2x XLR et 2x RCA)
InputJack 6.35mm
InputXLR
OutputJack 6.35mm
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipNC
ColorSilver
ClassN/A
The ADC / DAC RME ADI-2 Pro FS R Black Edition is the combination of several professional quality devices in a single package. An...
