By buying this product you get 119 loyalty points
This reference has been replaced by the new version: DENAFRIPS ARES 15TH R2R DAC.
To celebrate its 12 years of expertise, Denafrips presents the Ares 12TH-1, a high-performance, balanced NOS R2R DAC. The digital/analog conversion stage is made up of no fewer than 480 carefully selected precision resistors, and is combined with an Altera FPGA. The power supply stage of the Ares 12TH-1 is no exception, featuring a large 60VA O-core transformer with UP-OCC copper windings, eight LDO regulators and numerous high-performance capacitors. This ensemble enables the Denafrips Ares 12TH-1 to deliver sound reproduction of incredible precision, clarity and richness.
Key features:
The Ares 12TH-1's circuitry is housed in a sturdy, elegant anodized aluminum chassis. Its compactness makes for easy integration.
Le Denafrips Ares 12TH-1 profite d'une connectique complète. On y retrouve en entrée de l'USB-B associé à une interface STM32, de l'I2S via HDMI, de l'optique Toslink et du coaxial. Côté sortie on pourra compter sur du RCA stéréo asymétrique et du XLR stéréo symétrique.
1 | Balanced XLR output |
2 | Single-ended RCA output |
3 | Coaxial input |
4 | Toslink optical input |
5 | I2S input (HDMI) |
6 | USB-B input |
7 | Power connector |
Product type | Balanced NOS R2R DAC |
Inputs | 1x USB-B 1x I2S via HDMI 1x Coaxial 1x Optical Toslink |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Supported sampling rates | USB : PCM up to 1536kHz, DSD up to DSD1024 I2S / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Output level / impedance | RCA : 2Vrms @ 625Ω XLR : 4Vrms @ 1250Ω |
Sampling modes | Non-oversampling (NOS) Oversampling (OS) |
Filters | Slow Sharp |
Frequency response | 20Hz - 70kHz -3dB |
THD+N | 0.004% |
SNR | 115dB |
Dynamic range | > 119dB |
Crosstalk | -124dB |
Supply voltage | 100-240VAC 50/60Hz (switchable) |
Consumption | ≤ 20W |
Color | Silver |
Dimensions | 215 x 230 x 45mm |
Weight | 3.5kg |
Package | 1x Denafrips Ares 12TH-1 |
Input | I2S via HDMI |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | XLR |
Output | RCA |
Max sampling rate | 1536kHz |
Max sampling rate | DSD1024 |
Color | Silver |
Networking | No |
Remote Control | N/A |
