By buying this product you get 649 loyalty points
The Denafrips Terminator 15Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design, conceived to offer the best possible musical experience!
Key features :
The Denafrips Terminator digital/analog conversion module and its R2R ladder networks are perfectly isolated. The two boards are physically linked by the OCXO clock module. Physical isolation reduces background noise and improves the signal-to-noise ratio.
The Terminator II is equipped with two OCXO clocks operating at 45.1584MHz and 49.152MHz. Encapsulated in a metal housing located in the center of the DAC, these OCXOs are specially designed for high-end audio applications with ultra-low phase noise and very high precision. Both OCXOs are powered by the completely redesigned power supply circuit, providing constant current to the clocks. Adequate power reserves guarantee the linearity and stability of the clock signal.
Jitter is also reduced by reclocking the FIFO buffer. The adaptive FIFO buffer stores digital audio data. These are read directly using the ultra-low phase noise OCXO located directly in the DAC.
The Terminator also features an OCXO clock output for perfect synchronization of multiple audio devices.
The Denafrips Terminator 15Th incorporates its own linear power supply stage, located beneath the DAC board and separated from it by a steel partition to avoid any interference. The power supply itself uses two large O-Core toroidal transformers for the digital and analog sections, and low ESR capacitors to provide an electrical signal to all the audio circuits.
To ensure the shortest possible signal path, I2S and SPDIF signals are processed by an FPGA chip, without any additional conversion chips.
The Denafrips Terminator 15Th also boasts comprehensive connectivity, enabling easy integration into the vast majority of audio systems. Inputs include USB-B, I2S RJ45 LVCMOS, I2S RJ45 LVDS, I2S HDMI LVDS, AES/EBU, Toslink optical and coaxial. Outputs include unbalanced stereo RCA and balanced stereo XLR. Two clock outputs enable the Terminator and another audio device to be perfectly synchronized for optimum system performance.
| 1 | Balanced XLR output |
| 2 | Single-ended RCA output |
| 3 / 4 | Clock output |
| 5 | Coaxial input |
| 6 | Toslink optical input |
| 7 / 8 | AES/EBU input |
| 9 | I2S HDMI LVDS input |
| 10 / 11 | I2S RJ45 LVDS / LVCMOS input |
| 12 | USB-B input |
| 13 | Power connector |
Please note that the mains cable is not supplied.
| Specifications | |
| Product type | NOS balanced R2R DAC |
| Inputs | 1x USB-B 1x I2S via HDMI LVDS 1x I2S via RJ45 LVDS 1x I2S via RJ45 LVCMOS 2x AES/EBU 1x Optical Toslink 1x Coaxial |
| Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
| Supported sampling rates | USB / I2S : PCM up to 1536kHz, DSD up to DSD1024 Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
| Output level/impedance | RCA : 2.2Vrms @ 625Ω XLR : 4.Vrms @ 1250Ω |
| Sampling modes | Non-oversampling (NOS) Oversampling (OS) |
| Filters | Slow Sharp |
| Frequency response | 20Hz - 40kHz -0.2dB |
| THD+N | 0.002% |
| SNR | 120dB |
| Dynamic range | > 132dB |
| Crosstalk | -110dB |
| General | |
| Supply oltage | 100-240VAC 50/60Hz |
| Consumption | ≤ 20W |
| Color | Black |
| Dimensions | 430 x 380 x 125mm |
| Weight | 19kg |
| Package | 1x Denafrips Terminator 15TH |
| Input | I2S via HDMI |
| Input | AES/EBU |
| Input | USB |
| Input | Optical |
| Input | I2S via RJ45 |
| Input | SPDIF |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | R2R LADDER DAC |
| Max sampling rate | 1536kHz |
| Max sampling rate | DSD1024 |
| Color | Black |
| Networking | No |
| Remote Control | N/A |
