CANARE DA202 AES/EBU Digital Cable 110 Ohm 2x0.18mm² Ø5mm
Reference : 13303
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 07-07-2026.
DA202 aes
Canare DA202
This CANARE cable is 110Ω kind. It is compatible with the standard AES / EBU and agree to transfer digital audio stream in applications requiring high precision. It will give excellent performance in a studio or high fidelity audio system.
This is the mini version of the cable CANARE DA206. It has two braided conductors 25AWG
TypeCable by the meter
Standardcoaxial 110ohm
Compatible AES / EBU
number drivers2
diameter conductors0.45mm
section driver0.18mm² / 25 AWG
armouringBraided
Cond. DCR<10.6ohm 100m
Mitigation5dB / 100m
ColorBlue
Diameter (mm)5.0
Length (m)Sold by length
Number of conductors2
Insulation materialNC
ShieldingYes
Section (mm²)0.18
Ground / ShieldingYes
Incredible Value
While this is a digital cable I am actually hacking it for analogue application.
DA202 (or DA202AT, if you need a smaller diameter with the same AWG or an extra lower capacitance) are perfect cables to mod my open reel tape decks with direct head out or redo the internal wiring of the deck.
More generally, they excel with analogue very low signals (mV) over short distance and mitigate the risk of hum with great construction and shielding.
100% recommended.
This review has been posted for CANARE DA202 AES/EBU Digital Cable 110 Ohm 2x0.18mm² Ø5mm
