AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optical Coaxial Galvanic Insulation 24bit 192kHz
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and Ian Canada's discrete reclocking technology, it perfectly resynchronizes S/PDIF signals to achieve very low jitter. The result is a sound reproduction of an incredible clarity and precision.
Reference : 18113
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 10-07-2025.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Module Optical Coaxial Galvanic Insulation 24bit 192kHz
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and Ian Canada's discrete reclocking technology, it perfectly resynchronizes S/PDIF signals to achieve very low jitter. The result is a sound reproduction of an incredible clarity and precision. It features both optical Toslink and coaxial input and output connections, supporting sampling rates up to 192kHz. It also supports Dolby Digital and DTS audio formats. An automatic signal detection function automatically locks the active input, with status LEDs indicating the latter.
Most consumer devices, such as TV sets, set-top boxes or consoles, but also many audio devices such as DACs or CD players, can feature SPDIF outputs. However, these can suffer from poor signal transmission quality due to high jitter. The Audiophonics DIGIRescue, with its high-precision clock and circuitry, resynchronizes the signals to ensure optimum, error-free transmission quality and clear sound reproduction.
This interface benefits from a meticulously optimized overall architecture, based on high-end components. With its high-performance power supply filtering networks (organic polymer/MLCC capacitors totaling 1500µF) and ultra-low-noise LDO, the Audiophonics DIGIRescue is capable of delivering a clean, stable electrical signal to all its circuits. Optical and coaxial inputs and outputs benefit from galvanic isolation to protect the signal from unwanted interference.
In addition to its reclocker and isolator functions, the DigiRescue can also be used as an optical Toslink to coaxial converter and vice versa.
In short, the Audiophonics DIGIRescue acts as reclocker, galvanic isolator and EMI/RFI filter, performing each of these tasks effectively.
Key features:
  • Reclocks S/PDIF signals using a local audio clock with very low jitter.
  • Improves S/PDIF signal quality or corrects poor-quality S/PDIF signals while isolating them.
  • Two inputs: Coaxial and Optical Toslink.
  • Two outputs: Coaxial and Optical Toslink.
  • Standard 5VDC power supply via USB-C.
  • Automatic detection and selection of input signals.
  • Supports sampling rates up to 24bit 192kHz.
  • Two bi-color LEDs indicate the selected input signal and the S/PDIF signal lock status.
Using the Audiophonics DIGIRescue
  1. Connect a 5VDC power supply to the interface via its USB-C connector (J4). Status LED D3 lights up green. The Coaxial input is selected by default.
  2. Connect a DAC to either the coaxial output (J3) or the optical output (U6).
  3. Connect an audio source to either the interface's coaxial input (J1) or optical input (U5).
When using the interface's coaxial input, when a valid digital audio signal is locked, the color of LED D3 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal received by the interface on its coaxial input.
When using the interface's optical input, if a signal is detected, the optical input is automatically selected. LED D2 then lights up. When a valid digital audio signal is latched, the color of LED D2 changes to blue. The DAC connected to the DIGIRescue will then receive the audio signal on its optical input.
U5Optical Toslink input
J1Coaxial input
U6Optical Toslink output
J4USB-C 5VDC power supply input
J3Coaxial output
D2Optical Toslink input status LED
D3Coaxial input status LED
LED indicators
  1. D3: Coaxial input status LED (J1)
    • Green: Coaxial input is selected as input.
    • Blue: Digital signal locked.
    • Off: Not selected.
  2. D2: Optical Toslink input status LED (U5)
    • Green: Optical input is selected as input.
Product typeReclocker
EMI/RFI filter
Galvanic isolator
Supported sampling ratesPCM up to 24bit 192kHz
Inputs1* Coaxial (RCA)
1* Optical Toslink
Outputs1* Coaxial (RCA)
1* Optical Toslink
Automatic input signal detection
Local clock jitter1ps RMS
SPDIF reclocking jitter20ps RMS
Supported audio formatsPCM 24bit / 192kHz
Dolby Digital
DTS
Supply voltage5VDC via USB-C
Total dimensions96.5*48*20mm
Chassis dimensions70*48*20mm
Weight80g
Package1x Reclocker SPDIF Optique Coaxial Isolation Galvanic AUDIOPHONICS DIGIRESCUE
1x USB-A to USB-C power cable with switch
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
Interface chipNC
5 reviews
Awesome!
Currently running a wiim pro plus into Klipsch 'The sevens'. The digirescue made an amazing difference to the clarity. My wife even asked what I had done to the stereo! Highly recommended
This review has been posted for AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optical Coaxial Galvanic Insulation 24bit 192kHz
What an awesome surprise. This is just great.
I was completely caught off guard by this. I bought it more out of curiosity than anything else, quite certain of a return. Well, the Digirescue is not going anywhere. With a 5v IfI IPower 2 power supply, the sound of out of the reclocked coax tap was much improved compared to the sound obtained from my Elac ds s101g previously. But after connecting the Digirescue to my Keces P3 lps upgraded with a SR Orange fuse, the sound coming out of of my Rotel 1592 mk ii just exploded…it is way above anything I could expect. For me the lps is a must do upgrade. The imaging, the depth and width of the soundstage, the dynamics, and musicality, have just gone from adequate to really, really good. I know it probably sounds silly to use such an expensive lps with a component at this price point, but if you already have a power supply and are thinking about upgrading your streamer, just give this a go, you might have a surprise. I was not expecting anything given there weren’t many reviews, but I’d give this a 6/5. Well done audiophonics! I guess Ian Canada stuff is really that good. I’d recommend using good cables as well, totally deserving of them.
Great value CD-player upgrade!
Audiophonics did a fantastic job again with this DigiRescue Reclocker. I have the reclocker connected to a quite 'regular' 1990s Sony cd-player that has a Toslink output, and I power it with Audiophonics' 5V linear powersupply, on which I still had an unused USB 5V out. I use the "Canare by Audiophonics" digital coax cable to connect it to my DAC's s/pdif in, and a glass-based Toslink cable between the cd-player and the DigiRecue.
Before getting the Digirescue, I was not able to hear a difference between the cd-player's internal DAC and my external DAC. I am happy to report this is no longer the case now!
This device feels very well built, with metal housing and nice sturdy RCA connections. The reclocker has not only increased clarity and precision as advertised, but I can also clearly notice better dynamics and imaging. Overall, I experience more presence and enjoy my CD's more now. One thing to note in my setup, is that the bass not only gained presence, but also somehow feels significantly louder. That could/should be just due to either perceptual change as a result from better clarity and dynamics, or perhaps my smaller room size now more prominently interacting with these frequencies from the former. Either way, it's not on a level that's disturbing me but it was unanticipated and interesting.
Toslink to Coax conversion/ port choice is fully automatic, so you can tuck this small device also in difficult to reach spaces, should you want to.
The web-shopping experience has room for improvement: it is not cool that the product suddenly increased by 6 Euros in price during shopping/looking around. I wish that the advertised product price would be what you see the first time, and the web-store leaves out the marketing trickery.
Parfait
Comme cité précédemment ...
Petit appareil qui m'a permis de corriger facilement la qualité de sortie douteuse d'une TV 4K d'entrée de gamme.
Fonctionne à la perfection.
Parfait !
J'avais des problèmes de coupure de son et de décalage avec ma télé en Optique. Ce "Reclocker" a résolu le problème au premier branchement. Je l'alimente directement en USB avec ma télé, comme cela pas besoin d'un autre chargeur sur la multiprise.
Peut-être même que le son est meilleur...
Rien à dire fait le job, parfait !
 (3)
This Audiophonics DIGIRescue reclocker interface has been designed in association with Ian Canada. Using a high-precision local clock and...
