The BerryBak BDC-U multi-functional interface under reference Wondom AA-AB41165 is a Bluetooth/USB to RCA/Optical Toslink/SPDIF coaxial interface. It features audiophile components such as an ES9018K2M DAC chip, a Qualcomm QCC5171 Bluetooth 5.3 receiver chip and a WM8804 SPDIF interface. This enables it to support 24bit 96kHz streams, as well as high-resolution Bluetooth codecs: aptX, aptX HD, aptX Lossless and LDAC. Its inputs, outputs and components make it a versatile, high-performance interface of choice. It boasts a dynamic range of 127dB and a THD+N of -120dB thanks to the ES9018K2M chip, as well as low jitter thanks to the WM8804 chip. On the power supply side, there's a 5V 0.5A USB port and a 12V 0.5A Molex Micro Fit CKT port. The latter port provides an easy connection for those wishing to use this interface within a motorized vehicle such as a car to enhance the existing audio system, by enabling the interface to be powered directly from the vehicle's battery.
This interface benefits from a Qualcomm QCC5171 Bluetooth chip, enabling it to support very high-resolution codecs: SBC, AAC, aptX, aptX HD, aptX Lossless and LDAC. The BerryBak BDC-U interface supports wireless transmission up to 24bit/96kHz with LDAC, and a transmission rate of up to 1Mbps with the aptX Lossless codec. These features offer the very best in wireless transmission.
Equipped with a USB input, the BerryBak BDC-U interface can easily use a source such as a smartphone or computer. This USB input supports sampling rates up to PCM 24bit 96kHz, thanks to the ES9018K2M DAC chip. This DAC chip also gives it a dynamic range of 127dB and a THD+N of -120dB. The WM8804 SPDIF transmitter with advanced jitter attenuation guarantees reliable signal transmission for the clearest, most accurate sound reproduction..
Designed for easy integration into a car audio system, the BerryBak BDC-U features not only a USB-C power port (5V DC 0.5A), but also a 12V 0.5A power port on a Molex Micro Fit 2x2 CKT connector. The latter enables the interface to be connected directly to a vehicle battery. The ACC command synchronizes vehicle and interface starting. It also prevents the interface from drawing energy from the battery unnecessarily when the vehicle is not running.
1 | Bluetooth pairing LED indicator |
2 | USB Audio input |
3 | RCA output |
4 | Bluetooth antenna |
5 | SPDIF coaxial output |
6 | Optical toslink output |
7 | 12V DC MOLEX Micro Fit power port |
8 | 5V DC USB-C power port |
Product type | DAC/Bluetooth receiver interface |
Bluetooth chip | QCC5171 |
DAC chip | ES9018K2M |
SPDIF interface | WM8804 |
Inputs | 1x USB-C input Bluetooth |
Outputs | 1x Stereo RCA output 1x Coaxial output 1x Toslink optical output |
Supported sample rates | 24bit 96kHz |
SUpported Bluetooth codecs | AAC, SBC, aptX, aptX HD, aptX Lossless et LDAC |
RCA output level | 2Vrms |
DNR | 127dB |
THD+N | -120dB |
USB compatibility | Windows, Linux, Mac OSX (whitout driver) |
USB standard | UAC 2.0 |
Power supply | 5V DC 0.5A Via USB-C 12V DC 0.5A via Molex micro fit |
Energy consumption | 0.48W |
Color | Silver |
Dimensions | 96 x 66 x 24.5mm |
Weight | 248g |
Package | 1x Berrybak BDC-U AA-AB41165 1x Bluetooth antenna 1x Molex micro fit connector cable to bare wires 1x Toslink optical cable |
Input | Bluetooth |
Input | USB |
Output | RCA |
Output | Optical Toslink |
Output | Coaxial SPDIF |
DAC / ADC Chip | ES9018K2M |
Max sampling rate | 96kHz |
Color | Silver |
Interface chip | WM8804 |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
