GUSTARD U26 Digital Interface Black
The Gustard U26 is a high-precision USB digital interface designed to deliver ultra-high-resolution audio quality to audiophiles and professionals. Developed in collaboration with Amanero Technologies, it transmits digital audio signals with exceptional accuracy and stability, minimizing jitter and electrical interference. With its isolated architecture, low-phase-noise OCXO clocks, and compatibility with PCM formats up to 32-bit 1536kHz and DSD2048, the U26 fits perfectly into high-end audio setups, whether for home or professional use.
By buying this product you get 99 loyalty points
Reference : 21301
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 07-04-2026.
Gustard U26 Digital Interface USB I2S SPDIF 32bit 1536kHz DSD2048 Black
Gustard U26
Gustard U26: Key features
Gustard U26: Cutting-edge technology for optimal audio quality
The Gustard U26 uses an ARM Cortex-M7 processor and a custom USB solution, the result of collaboration between Gustard and Amanero. This technology enables real-time management of very high-resolution audio streams, with reduced latency and increased stability.
Gustard U26: USB Amanero interface
Gustard U26: OCXO clock
Gustard U26: High-precision clock
The Gustard U26 is also equipped with an OCXO clock as its clock source, combined with K2 PLL technology, ensuring ultra-precise synchronization and significantly reduced jitter, which is essential for high-quality sound reproduction.
Gustard U26: Maximum compatibility
The U26's USB 2.0 interface provides Plug & Play compatibility with Mac, Windows, Linux, and mobile devices (OTG). For Windows users, a custom ASIO driver is available, allowing fine-tuning of latency and buffer settings, as well as phase and data alignment adjustments, for total optimization of the audio chain.
Gustard U26: Wiring diagram
Gustard U26: Optimized insulation and power supply
The Gustard U26 features a fully isolated power supply architecture, with a toroidal transformer and independent linear regulators for the USB and digital circuits. This physical and electrical separation eliminates noise and interference, ensuring a pure and stable audio signal. The U26 also incorporates a 200Mbps USB isolation chip, which effectively blocks electrical noise from the computer or streamer, preserving the integrity of the audio signal.
Gustard U26: Insulation and clock diagram
Gustard U26: Comprehensive connectivity
The U26 offers a wide range of digital outputs: Coaxial (RCA and BNC), Optical, AES (XLR), and I2S via HDMI, providing maximum compatibility with most DACs and audio systems. This versatility makes it an ideal choice for users who want to easily integrate the interface into their existing audio system, whether domestic or professional.
Gustard U26 : Connectors diagram
1I2S output (configurable pinout)
2AES output
3Power input connector
4USB input
510MHz clock input
6Optical Toslink output
7I2S-G output (Gustard pinout)
8Coaxial (RCA) output
9Coaxial (BNC) output
10220V/110V Power input switch
11Power switch
I2S pinout
Gustard U26: I2S pinout
Gustard U26: Robust and elegant design
The aluminum alloy chassis of the U26 combines robustness and minimalist aesthetics, while providing effective protection against electromagnetic interference. Its sleek design and high-quality construction make it a powerful yet discreet device that blends seamlessly into high-end audio installations.
Gustard U26: Exploded view of the chassis
Product typeDigital interface
Inputs1x USB-B 2.0
1x 50Ω Clock input (input level 0dBm to 20dBm)
Outputs1x I2S (configurable pinout)
1x I2S-G (Gustard pinout)
1x Optical Toslink
1x Coaxial 75Ω (RCA)
1x Coaxial 75Ω (BNC)
1x AES/EBU 110Ω
Supported sampling ratesCoaxial: PCM up to 24bit 384kHz, DoP64-128
AES/EBU: PCM up to 24bit 384kHz, DoP64-128
Optical: PCM up to 24bit 192kHz, DoP64
I2S: PCM up to 32bit 1536kHz, DSD up to DSD2048
Output levelCoaxial: 500mV P-P @ 75Ω
AES/EBU: 2.1V P-P @ 110Ω
I2S: LVDS
Supply voltageAC 115V / 230V, 50/60Hz (switchable)
Consumption< 15W
Dimensions (excluding feet and connectors)330 x 260 x 65mm
Weight4.8kg
Package1x Gustard U26
1x Power cable
InputClock (BNC)
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
Max sampling rateDSD2048
Max sampling rate1536kHz
Interface chipAmanero 384
Gustard U 26.
Le Gustard U26 associé à mon A26. Il a métamorphosé ce dernier tant au niveau des basses, de l’aération. Plus de hauteur et de profondeur. Des petits détails qui étaient enfouis ressortent mieux. Très belle amélioration dans mon système.
This review has been posted for GUSTARD U26 Digital Interface USB I2S SPDIF 32bit 1536kHz DSD2048 Black
The Gustard U26 is a high-precision USB digital interface designed to deliver ultra-high-resolution audio quality to audiophiles and professionals....
