VEZZOSO DPC DELUXE Digital Interface
The Vezzoso DPC Deluxe is a digital interface designed to optimise the digital audio signal before its analogue conversion. Placed between a digital source (CD player, audio server, etc.) and a DAC, this device performs two essential functions: signal reclocking and oversampling to reduce jitter and improve the fidelity of the digital stream.
By buying this product you get 159 loyalty points
Reference : 21208
1 599,00 €tax incl.
1 332,50 € tax excl.
Vezzoso DPC Deluxe Digital Interface DDC USB I2S SPDIF AES 32bit 384kHz DSD512
Vezzoso DSP Deluxe : Front view
Vezzoso DPC Deluxe: Signal reclocking
The Vezzoso DPC Deluxe performs a complete reclocking of the incoming signal using an internal clock with very low drift of only ±0.3 ppm. This clock replaces the original stream clock, ensuring stable and accurate synchronisation before sending to the DAC. This process limits jitter and synchronisation errors that could alter the signal reproduction.
Vezzoso DPC Deluxe: Oversampling and format conversion
The device incorporates a DDC (Digital Direct Conversion) circuit capable of converting PCM and DSD streams on all of its inputs and outputs. Sampling frequencies can be selected from thirteen values, ranging from 44.1 kHz to 768 kHz for PCM and from DSD64 to DSD512 for DSD. This conversion allows, for example, a 44.1 kHz PCM stream from a CD player to be transformed into a DSD512 signal for the DAC, without the need for the SACD format.
Vezzoso DPC Deluxe: Low-noise power supply
The Vezzoso DPC Deluxe interface uses two transformers to isolate the input and output sections, limiting interference and ensuring a clean power supply. Filter capacitors with a total value of 100,000 µF stabilise the voltage, complemented by ultra-low-noise LDO regulators dedicated to each circuit. Finally, signal processing is handled by a precision DPC (-150 dB), combined with fast output logic to ensure a stable and accurate digital signal.
Product typeDigital interface (DDC)
Inputs1x BNC
1x XLR AES
2x Coaxial
2x USB-B
1x HDMI I2S
1x BNC for clock signal
Outputs1x Stereo HDMI I2S
1x Stereo XLR AES
2x Coaxial
2x BNC
Supported sampling ratesBNC / AES / Coaxial : PCM 32bit 768kHz / DSD256
I2S / USB : PCM 32bit 768kHz / DSD512
Dimensions448 x 288 x 78mm
Weight8.3kg
Package1x Vezzoso DPC Deluxe
1x Power cord
VEZZOSO DPC DELUXE: HDMI connection diagram
InputAES/EBU
InputBNC
InputClock (BNC)
InputI2S via HDMI
OutputI2S LVDS via HDMI
OutputBNC
OutputCoaxial SPDIF
OutputAES/EBU
Max sampling rateDSD512
Max sampling rate768kHz
Interface chipXMOS XU216
VEZZOSO DPC DELUXE Digital Interface DDC USB I2S SPDIF AES 32bit 384kHz DSD512
The Vezzoso DPC Deluxe is a digital interface designed to optimise the digital audio signal before its analogue conversion. Placed between a...
