IFI AUDIO ISILENCER+ EMI RFI Noise Suppressor Male USB-C to Female USB-A
The iFi Audio iSilencer+ applies effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and EMI / RFI interference for clear, accurate and faithful sound reproduction.
Reference : 14475
59,00 €tax incl.
49,17 € tax excl.
iFi Audio iSilencer+ Suppresseur de Bruit EMI RFI USB-C Mâle vers USB-C Femelle
The connection of audio devices via USB, while it allows high-resolution and bit-perfect data to be passed through, was not created specifically for audio, however. It therefore carries both data and power, which means that there is potential electrical noise from, for example, the power supply of your computer. The iFi Audio iSilencer+ solves this problem by applying effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and EMI/RFI interference for clear, accurate and faithful sound reproduction, while improving bass.
The iSilencer+ can also be used on an unused USB port of a computer or DAC to reduce EMI interference. Each additional unit doubles this noise suppression capability.
In this version, the iSilencer+ has a female USB-A input and a male USB-C output.
An improved version
The iSilencer+ is a direct enhancement of the iDefender 3.0, now taking advantage of the Active Noise Cancellation 2 technology as well as the REbalance technology to remove distortion.
The circuit has also been improved, now incorporating low ESR tantalum capacitors for better input and output filtering. The filtering capacity has thus been multiplied by 10.
Active Noise Cancellation 2 technology actively suppresses incoming noise, using similar operation to noise cancelling headphones. A signal identical to the incoming electrical noise is generated with an inverted phase, in order to perform this noise cancellation.
This method is particularly effective in eliminating noise at low and mid frequencies, while passive filtering takes care of interference at high frequencies. This clever combination is therefore more effective than simple passive filtering.
Thus, the measured noise is 100x or 40dB lower than what a conventional filter can offer.
REbalance
REbalance technology allows the signal to be rebalanced to correct problems caused by jitter. As a result, the digital signal received by the DAC is identical to that of the source, regardless of the format being played back.
USB 3.0 SuperSpeed
The USB 3.0 SuperSpeed standard allows faster transfer of audio data, while remaining backward compatible with previous standards. The iDefender+ is equipped with gold-plated connectors for excellent conductivity and resistance to oxidation.
Product typeUSB Noise suppressor
Input1x Female USB-A
Output1x Male USB-C
USB StandardSuperSpeed 3.0
Contacts platingGold
Total dimensions50 x 20 x 9mm
OutputUSB
Max sampling rateNC
Interface chipNC
The iFi Audio iSilencer+ applies effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and...
