IFI AUDIO SILENT POWER USB IPURIFIER PRO USB Filter
New
The USB iPurifier Pro from iFi Audio is a noise filter for USB ports. The successor to the iGalvanic 3.0, it also includes the feature of the iSilencer and iDefender for a unique and ever more powerful product aimed at audiophiles. Compact yet comprehensive, the iPurifier Pro protects the signal from USB interference to ensure high-quality transmission.
Reference : 21588
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 14-04-2026.
iFi Audio Silent Power USB iPurifier Pro USB Filter
IPURIFIER PRO USB
Although the iPurifier Pro USB incorporates a wide range of features to reduce noise, it does not compromise on speed, allowing data transfer speeds of 10Gbit per second.
USB iPurifier Pro Graph
iFi Audio USB iPurifier Pro: Features and functionality
Thanks to its galvanic isolation, the USB iPurifier Pro isolates the input and output circuits, eliminating parasitic currents that could cause noise and jitter. The active noise reduction (ANC) function duplicates parasitic noise and reverses the phase to eliminate it, restoring a clean, noise-free signal. Finally, to avoid ground loops, IsoGround technology provides grounding via its 4mm port (compatible with the iFi Audio GroundHog+, sold separately).
Product typeUSB filter
Input1x USB-C
1x USB-B 3.0
Output1x USB-A 3.0 (Power and Data)
1x USB-A 3.0 (Power only)
External power inputUSB-C 5V
Data speed10Gbit/s
USB standard3.0
Grounding portYes
Dimensions42.8 x 23.2 x 96mm
Weight108g
Package1x iPurifier Pro USB
1x USB-C to USB-C Cable (0.5m)
1x USB 3.0 Cable (0.5m)
IFI AUDIO SILENT POWER USB IPURIFIER PRO USB Filter USB-B / USB-C to USB-A
The USB iPurifier Pro from iFi Audio is a noise filter for USB ports. The successor to the iGalvanic 3.0, it also includes the feature of the...
