By buying this product you get 35 loyalty points
USB XMOS XU208 Digital Interface 32bit 384khz DSD512 SPDIF AES/EBU I2S HDMI LVDS
The Singxer SU-1 is a high-performance digital USB interface at an affordable price. It integrates high-end components such as an XMOS USB interface, FPGA or dual clock, allowing it to offer high audio performance while having a panel of output connectors to cover the majority of needs.
In a device like the Singxer SU-1, the quality of the USB interface module is extremely important. The brand therefore offers an excellent interface module based on an XMOS Xcore-200 USB chip. This 32-bit microcontroller, recognized by audiophiles, offers first-class performance with a low latency system and capable of performing several tasks at once for a processing capacity of up to 1000 MIPS.
To satisfy the majority of user needs, the Singxer SU-1 offers a wide range of outputs. There is SPDIF with a BNC output and a Coaxial RCA output, but also AES/EBU, I2S via HDMI and even an MCLK/WCK clock output.
To ensure perfect signal synchronization and therefore an ultra-low jitter, the SU-1 carries two excellent Crystek CCHD-575 clocks. These are Crystek clocks to reach the lowest jitter.
Product type | USB digital interface |
USB interface chip | XMOS XU208 |
Supported sampling rate | PCM via SPDIF & AES/EBU : Up to 192kHz PCM via I2S & WCLK : Up to 384kHz DSD via SPDIF & AES/EBU : DSD64 DoP Mode DSD via I2S : Native DSD512 |
FPGA | Xilinx |
Clocks | 2x Crystek CCHD-575 |
Input | 1x USB-B 2.0 |
Outputs | 1x Coaxial SPDIF (RCA) 1x BNC 1x I2S via HDMI 1x AES/EBU 1x MCLK/WCK (Clock) |
OS Compatibility | Windows XP, 7, 8, 10 - Drivers installation needed MacOS 10.6 and later Linux with UAC2 kernel Android 4.2 and later - OTG Support |
I2S Compatibility | Audio-GD : Native DSD support / DoP (All switch OFF) Holo Audio : DSD Auto-detect (All switch OFF) PS AUDIO : DSD Auto-detect (All switch OFF) Gustard (Switch 3/6 ON) |
Color | Black |
Dimensions |
Output | I2S LVDS via HDMI |
Output | Coaxial SPDIF |
Output | XLR |
Output | BNC |
Max sampling rate | 384kHz |
Max sampling rate | DSD512 |
Color | Black |
