SMSL PO100 PRO USB Interface XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
The SMSL PO100 PRO presents itself as an extremely powerful and incredibly compact USB interface. Despite its small size, the PO100 PRO is based on an architecture using high quality components to ensure a faithful and precise sound reproduction. It also offers a complete connectivity to answer most of the connection needs, with USB-C as input and coaxial, optical and I2S via HDMI as output.
4.8 / 5
Reference : 17036
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 20-05-2025.
SMSL PO100 PRO
SMSL PO100 PRO Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
SMSL PO100AK Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
XMOS XU316 USB Interface
The USB-C input of the PO100 PRO is associated with a third generation XMOS XU316 high-end USB interface. This one, in addition to allowing a transparent sound reproduction, ensures the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512.
MQA Decoder
The SMSL PO100 PRO is able to decode MQA (Master Quality Authenticated) audio files. These files allow to enjoy a sound as close as possible to the original studio recording.
I2S & UAC Modes
The SMSL PO100 PRO provides two UAC modes and two I2S modes. These modes allow to maximize the compatibility of the interface with other devices. The UAC modes can be useful when used with a console such as PS5 or Nintendo Switch, while the I2S modes can correct compatibility issues in a HiFI installation.
Technical characteristics
Product typeUSB Interface
USB Interface chipXMOS XU316
Input1* USB-C
Outputs1* I2S via HDMI
1* Coaxial
1* Optical Toslink
USB Transmission modeAsynchronous
USB CompatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 or later
Linux
Android
iOS
THD+N (No-Weighting)0.000008% (141.7dB)
Supported sampling ratesI2S : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Jitter75ps
Supply voltage5V 200mA via USB-C
Dimensions (L*P*H)80*60*13mm
Weight75g
Shell materialAluminum
Package1x SMSL PO100 PRO
1x USB-A to USB-C cable
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
9 reviews
Petit boîtier parfait ?
Ça y ressemble !!
Connecté au Mac Mini en USB il a été immédiatement reconnu par Audirvana, décode tous les formats (Mqa compris) et il est relié à mon Dac en Spdif.
Il est très plat ce qui m’a permis de le glisser sous mon Dac.
Envoi rapide et sécurisé.
This review has been posted for SMSL PO100 PRO USB Interface XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA
Excellent !
Sort un flux digital de bien meilleure qualité que la sortie optique intégrée à mon Macbook 2015 que je croyais pourtant déjà excellente.
Perfekt
Ich verwende den USB-Adapter so, wie er bei cheap-audio-men empfohlen wurde. Er kommt zwischen dem WIIM ultra und einem DAC (smsl d400 ex) zum Einsatz. Er erwirkt ein unglaublichen Gewinn.
Not noticeable SQ improvement on my laptop
The device didn't bring any noticeable difference in terms of sound quality in my existing laptop configuration. Sound quality using direct USB cable to DAC and using USB over SMSL PO100 to DAC gave almost the same SQ results.
Rather save the money and by something like Wiim Pro or Wiim Pro Plus for audio streaming purposes.
 (7)
Recommend
Great device!
The SMSL PO100 PRO presents itself as an extremely powerful and incredibly compact USB interface. Despite its small size, the PO100 PRO is based on...
