TOPPING HS02 USB Audio Isolator 32bit 768kHz DSD512
The Topping HS02 is a high performance USB isolator with maximum compatibility to enjoy a cleaner signal on many devices. Its fully isolated design means that it will not introduce new interference if an auxiliary power supply is used and the audio signal is perfectly isolated from any ground loop.
4.8 / 5
Reference : 17310
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 06-05-2025.
Topping HS02
Topping HS02 Isolateur USB 32bit 768kHz DSD512
The Topping HS02 is a high performance USB isolator with maximum compatibility to enjoy a cleaner signal on many devices. Its fully isolated design means that it will not introduce new interference if an auxiliary power supply is used and the audio signal is perfectly isolated from any ground loop. The HS02 features dual input and output connectivity: USB-B and USB-C on the input side, USB-A and USB-C on the output side. On each side, a switch allows to select the desired input and output. The isolator also supports high sampling rates, up to PCM 32bit 768kHz and DSD512.
HS02
HS01
Connectors
Two inputs
Two outputs
One input
One output
Auxiliary power isolation
Yes
No
Audio signal isolation voltage
> 1500KVrms
> 1000KVrms
Delay
0.073µs
0.29µs
Product typeUSB Isolator
Inputs1* USB-B
1* USB-C
Outputs1* USB-A
1* USB-C
Supported samplinf ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Audio signal isolation voltage> 1500KVrms
Delay0.073µs
Suplpy voltage5VDC
Dimensions59*38*18mm
Package1* Topping HS02
1* USB cable
OutputUSB
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipNC
5 reviews
excellent
.. with babyface pro, need to upgrade the cable that comes with
This review has been posted for TOPPING HS02 USB Audio Isolator 32bit 768kHz DSD512
Parfait , mais !!!
Produits qui annonce réellement ce qu'il doit faire , Full Spec , par contre je n'ai pas essayé avec 1500 volts pour tester l'isolation .
Je l'ai associé avec l'E1DA cosmos ADC et j'ai eu quelque soucis .
La charge (E1DA cosmos) n'est pas suffisante , il faut absolument
charger la sortie de l'HS02 si vous ne voulez pas avoir des ruptures de signal (min 10 ma), c'est pour cela que je ne mets que 4 étoiles .
[ il existe un PB avec l'alimentation interne , sans plus]
Ravi
Utilisé en remplacement d'un iFi Audio iDefender 3 que je trouvais trop "décapant" et sonnant trop "digital". Le Topping HS02 effectue le même travail en mieux, c'est-à-dire supprimer la composante 5V du signal USB, pour les DAC disposant de leur propre source d'alimentation. Il est également doté d'une fonction d'isolation galvanique.*
Cela fait environ 15 jours que je l'utilise et le son se bonifie progressivement depuis 3 ou 4 jours, apportant davantage d'enveloppe, de chair à la musique qui se retrouve davantage centrée sur le médium.
Les aigus sonnent également "charnus" (on distingue le son intrinsèque des clochettes et triangles et pas seulement un tintement aigu). Et enfin les graves semblent plus présents, plus "ronds". Tout cela est très agréable car plus proche de la vérité, du "vrai son" des instruments et de l'ensemble.
* Attention : Si votre DAC ou streamer en aval intègre déjà une isolation galvanique, il se peut que le Topping HS02 ne fonctionne pas, bloquant purement et simplement la totalité du signal (pas de musique, silence complet). La chose est précisée dans le manuel d'utilisation.
Great product. Checked with Topping dm7 and RME Babyface, significant improvement of sq in both cases.
Magnifiuqe sorry for my French
I used ifi reclocker, used pc as a source and was very unhappy with harsh and lifeless sound.
This bad boy makes music sound as good as from my phone and this means: Music full of life, depth and devoid of digital harshness.
The Topping HS02 is a high performance USB isolator with maximum compatibility to enjoy a cleaner signal on many devices. Its fully isolated design...
